How did you do this Keith? Would there be any way to have the light off when the plug is in use?
@saxnix, you might want to use Momentary mode. The manual says that the light will turn off after 5 seconds.
Parameters 81, 83 and 84 control the LED mode, color and brightness.
81 is the mode: 0 = Energy mode (default), 1 = Momentary mode and 2 = Night light mode
83 is the RGB value for Night light mode. Red + Green + Blue. Default is Red = x1B, Green=x14, Blue=x1B. 1B141B Hex is 1774619 decimal.
84 is the LED brightness level in Energy or Momentary modes. Default is Green = x32, Yellow=x32, Red=x32. 323232 Hex is 3289650 decimal.
Ha ha, that's all over my head. . No clue what any of that means. Not a programmer, just fumbling my way through.
@saxnix direct message me, tell me what you want it to do and I'll play and the send back instructions.
Hey Keith,
do your Oomi's show more Clusters than this...
or does that only become visible AFTER unlocking them ??
Hi @njanda. Here are the clusters for mine:
yeah that's what I expected to see.
Thx
I wonder if being "locked' alters the Device Type, as yours are different also ?
Same manufacturer and Device ID
I don't have a pre-unlock screenshot and cannot tell from the logs but mine now has
inClusters: 0x5E,0x25,0x26,0x33,0x70,0x27,0x32,0x81,0x85,0x59,0x72,0x86,0x7A,0x73
@njanda. Mine were locked when I added them to Hubitat. It is more likely that the different Device Type is due to country or manufacturing versions.
@keith_munro, @Wounded - I excluded and then Included and it got associated correctly this time so now everything seems to be working as expected.
I've also unlocked the device using the Basic Zwave tool
It is now showing...
Thanks guys
@njanda - I need to go check mine again, output using aeotec 6 driver device type and manufacturer seem to be different on yours between screenshots
- deviceType: 515
- inClusters: 0x5E,0x25,0x26,0x33,0x70,0x27,0x32,0x81,0x85,0x59,0x72,0x86,0x7A,0x73
- outClusters: 0x5A,0x82
- deviceId: 96
- manufacturer: 362
I've got full config control so they are definately unlocked
did you unlock then exclude and add them again ?
G'day Keith, I Excluded then Included and then unlocked
I'm going to have a play and see if @srwhite's Zwave Repeater Driver could be used to check routing through these Oomi devices.
Let me know how you go with that please @njanda
Hey Keith,
It looks like the Oomi's are doing their thing;
I loaded up @srwhite's Iris Zwave Repeater driver and here's what I got .........
#### Current States
*** lastMsgRcvd : 2020-03-25 14:12:03: POWER LEVEL NODE TEST REPORT V1**
*** lastTest : SUCCESS 30 of 30 frames received.**
*** status : online**
I then set all logging to ON.
Pressed "interrogate Device" and got....
dev:20212020-03-25 02:16:51.217 pm infoDevice is online
dev:20212020-03-25 02:16:51.197 pm debugMANUFACTURER SPECIFIC V2: Manufacturer ID: 016A, Manufacturer Name: Fantem, Product Type ID: 0203, Product ID: 0060
dev:20212020-03-25 02:16:51.190 pm debugParsing zw device: 62, command: 7205, payload: 01 6A 02 03 00 60 , isMulticast: false
dev:20212020-03-25 02:16:51.043 pm traceSending command... ManufacturerSpecificGet()
dev:20212020-03-25 02:16:51.040 pm debugQuerying device for manufacturerSpecificV2 information...
dev:20212020-03-25 02:16:02.731 pm traceDevice Interrogation: Phase 0 of 6; Attempt 1 of 3...
dev:20212020-03-25 02:15:57.798 pm infoDevice is online
dev:20212020-03-25 02:15:57.791 pm debugASSOCIATION GROUP REPORT V2: Oomi-2 - WiFi controller in Group #1 with nodes: [1]
dev:20212020-03-25 02:15:57.787 pm debugParsing zw device: 62, command: 8503, payload: 01 05 00 01 , isMulticast: false
dev:20212020-03-25 02:15:57.739 pm traceDevice Interrogation: Phase 6 of 6; Attempt 1 of 3...
dev:20212020-03-25 02:15:57.709 pm traceSending command... AssociationGet(groupingIdentifier:1)
dev:20212020-03-25 02:15:52.809 pm infoDevice is online
dev:20212020-03-25 02:15:52.803 pm debugASSOCIATION GROUP NAME REPORT V1: Oomi-2 - WiFi controller belongs to group Lifeline
dev:20212020-03-25 02:15:52.798 pm traceReceived: AssociationGroupNameReport(groupingIdentifier:1, lengthOfName:8, name:[76, 105, 102, 101, 108, 105, 110, 101])
dev:20212020-03-25 02:15:52.776 pm debugParsing zw device: 62, command: 5902, payload: 01 08 4C 69 66 65 6C 69 6E 65 , isMulticast: false
dev:20212020-03-25 02:15:52.722 pm traceDevice Interrogation: Phase 5 of 6; Attempt 1 of 3...
dev:20212020-03-25 02:15:52.689 pm traceSending command... AssociationGroupNameGet(groupingIdentifier:1)
dev:20212020-03-25 02:15:47.901 pm infoDevice is online
dev:20212020-03-25 02:15:47.882 pm infoDevice is online
dev:20212020-03-25 02:15:47.872 pm debugMANUFACTURER SPECIFIC V2: Manufacturer ID: 016A, Manufacturer Name: Fantem, Product Type ID: 0203, Product ID: 0060
dev:20212020-03-25 02:15:47.792 pm debugParsing zw device: 62, command: 7205, payload: 01 6A 02 03 00 60 , isMulticast: false
dev:20212020-03-25 02:15:47.763 pm debugMANUFACTURER SPECIFIC V2: Manufacturer ID: 016A, Manufacturer Name: Fantem, Product Type ID: 0203, Product ID: 0060
dev:20212020-03-25 02:15:47.754 pm debugParsing zw device: 62, command: 7205, payload: 01 6A 02 03 00 60 , isMulticast: false
dev:20212020-03-25 02:15:47.705 pm traceDevice Interrogation: Phase 4 of 6; Attempt 1 of 3...
dev:20212020-03-25 02:15:47.668 pm traceSending command... ManufacturerSpecificGet()
dev:20212020-03-25 02:15:42.861 pm infoDevice is online
dev:20212020-03-25 02:15:42.842 pm debugFIRMWARE METADATA REPORT V1: Oomi-2 - WiFi controller is running firmware ID: 0000 with checksum: 97E9
dev:20212020-03-25 02:15:42.839 pm debugParsing zw device: 62, command: 7A02, payload: 01 6A 00 00 97 E9 , isMulticast: false
dev:20212020-03-25 02:15:42.795 pm infoDevice is online
dev:20212020-03-25 02:15:42.770 pm debugFIRMWARE METADATA REPORT V1: Oomi-2 - WiFi controller is running firmware ID: 0000 with checksum: 97E9
dev:20212020-03-25 02:15:42.765 pm debugParsing zw device: 62, command: 7A02, payload: 01 6A 00 00 97 E9 , isMulticast: false
dev:20212020-03-25 02:15:42.694 pm traceDevice Interrogation: Phase 3 of 6; Attempt 1 of 3...
dev:20212020-03-25 02:15:42.646 pm traceSending command... FirmwareMdGet()
dev:20212020-03-25 02:15:37.800 pm infoDevice is online
dev:20212020-03-25 02:15:37.755 pm debugVERSION REPORT V1: Oomi-2 - WiFi controller is running firmware version: 1.5, Z-Wave version: 4.5, Library type: 3
dev:20212020-03-25 02:15:37.751 pm debugParsing zw device: 62, command: 8612, payload: 03 04 05 01 05 60 00 , isMulticast: false
dev:20212020-03-25 02:15:37.655 pm traceDevice Interrogation: Phase 2 of 6; Attempt 1 of 3...
dev:20212020-03-25 02:15:37.621 pm traceSending command... VersionGet()
dev:20212020-03-25 02:15:32.732 pm infoDevice is online
dev:20212020-03-25 02:15:32.695 pm debugPOWER LEVEL REPORT V1: Transmit power for Oomi-2 - WiFi controller is NOMINAL.
dev:20212020-03-25 02:15:32.687 pm debugParsing zw device: 62, command: 7303, payload: 00 00 , isMulticast: false
dev:20212020-03-25 02:15:32.623 pm traceDevice Interrogation: Phase 1 of 6; Attempt 1 of 3...
dev:20212020-03-25 02:15:32.570 pm traceSending command... PowerlevelGet()
dev:20212020-03-25 02:15:32.537 pm traceInterrogating device...
I think it's all good.
As an addendum or follow up;
I've configured one of my Oomi's as a power switch for my WiFi router.
Using the "HTTP Present" App from @jwetzel1492, it pings a WiFi device I have.
See more info HERE
