HI Keith, not sure what you mean by "poll device page".
But using the buttons: POLL and UDATED on the device page I get this (below).
Cheers Bruce
dev:9932020-06-12 09:14:11.529 debug+++++ delayBetweenLog parm[9] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:11.516 warnChild Device handler not found: 19-ep12: thermostatMode
dev:9932020-06-12 09:14:11.506 warnChild Device handler not found: 19-ep11: thermostatMode
dev:9932020-06-12 09:14:11.497 warnChild Device handler not found: 19-ep12: temperature
dev:9932020-06-12 09:14:11.487 warnChild Device handler not found: 19-ep11: temperature
dev:9932020-06-12 09:14:11.404 debugManufacturerProprietary event, [1]:40 [4]:84 payload: 05 40 02 01 84 00 00 00 00 01 00 00 00 12 0A 00 00 00 00 03 01 00 00 00 00 00
dev:9932020-06-12 09:14:11.276 debug+++++ delayBetweenLog parm[9] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:11.264 warnChild Device handler not found: 19-ep12: thermostatMode
dev:9932020-06-12 09:14:11.255 warnChild Device handler not found: 19-ep11: thermostatMode
dev:9932020-06-12 09:14:11.247 warnChild Device handler not found: 19-ep12: temperature
dev:9932020-06-12 09:14:11.235 warnChild Device handler not found: 19-ep11: temperature
dev:9932020-06-12 09:14:11.163 debugManufacturerProprietary event, [1]:40 [4]:84 payload: 05 40 02 01 84 00 00 00 00 01 00 00 00 12 0A 00 00 00 00 03 01 00 00 00 00 00
dev:9932020-06-12 09:14:10.709 debug+++++ delayBetweenLog parm[9] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:10.698 warnChild Device handler not found: 19-ep12: thermostatMode
dev:9932020-06-12 09:14:10.689 warnChild Device handler not found: 19-ep11: thermostatMode
dev:9932020-06-12 09:14:10.680 warnChild Device handler not found: 19-ep12: temperature
dev:9932020-06-12 09:14:10.670 warnChild Device handler not found: 19-ep11: temperature
dev:9932020-06-12 09:14:10.589 debugManufacturerProprietary event, [1]:40 [4]:84 payload: 05 40 02 01 84 00 00 00 00 01 00 00 00 12 0A 00 00 00 00 03 01 00 00 00 00 00
dev:9932020-06-12 09:14:10.467 debug+++++ delayBetweenLog parm[9] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:10.439 warnChild Device handler not found: 19-ep12: thermostatMode
dev:9932020-06-12 09:14:10.435 debug+++++ delayBetweenLog parm[9] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:10.428 warnChild Device handler not found: 19-ep11: thermostatMode
dev:9932020-06-12 09:14:10.422 warnChild Device handler not found: 19-ep12: thermostatMode
dev:9932020-06-12 09:14:10.418 warnChild Device handler not found: 19-ep12: temperature
dev:9932020-06-12 09:14:10.413 warnChild Device handler not found: 19-ep11: thermostatMode
dev:9932020-06-12 09:14:10.408 warnChild Device handler not found: 19-ep11: temperature
dev:9932020-06-12 09:14:10.404 warnChild Device handler not found: 19-ep12: temperature
dev:9932020-06-12 09:14:10.394 warnChild Device handler not found: 19-ep11: temperature
dev:9932020-06-12 09:14:10.313 debugManufacturerProprietary event, [1]:40 [4]:84 payload: 05 40 02 01 84 00 00 00 00 01 00 00 00 12 0A 00 00 00 00 03 01 00 00 00 00 00
dev:9932020-06-12 09:14:10.298 debugManufacturerProprietary event, [1]:40 [4]:84 payload: 05 40 02 01 84 00 00 00 00 01 00 00 00 12 0A 00 00 00 00 03 01 00 00 00 00 00
dev:9932020-06-12 09:14:10.249 debug<<<<< rspFlg=true dly:1000/1000 <<<<< Event: [name:airTempSolar, value:10, unit:F, displayed:true, isStateChange:true]
dev:9932020-06-12 09:14:10.245 debug<<<<< rspFlg=true dly:1000/1000 <<<<< Event: [name:airTempSolar, value:10, unit:F, displayed:true, isStateChange:true]
dev:9932020-06-12 09:14:10.178 debug+++++ delayBetweenLog parm[9] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:10.174 debug+++++ delayBetweenLog parm[9] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:10.167 warnChild Device handler not found: 19-ep12: thermostatMode
dev:9932020-06-12 09:14:10.163 warnChild Device handler not found: 19-ep12: thermostatMode
dev:9932020-06-12 09:14:10.158 warnChild Device handler not found: 19-ep11: thermostatMode
dev:9932020-06-12 09:14:10.154 warnChild Device handler not found: 19-ep11: thermostatMode
dev:9932020-06-12 09:14:10.149 warnChild Device handler not found: 19-ep12: temperature
dev:9932020-06-12 09:14:10.145 warnChild Device handler not found: 19-ep12: temperature
dev:9932020-06-12 09:14:10.140 warnChild Device handler not found: 19-ep11: temperature
dev:9932020-06-12 09:14:10.136 warnChild Device handler not found: 19-ep11: temperature
dev:9932020-06-12 09:14:10.062 debugManufacturerProprietary event, [1]:40 [4]:84 payload: 05 40 03 01 84 00 00 00 00 01 00 00 00 12 0A 00 00 00 00 03 01 00 00 00 00 00
dev:9932020-06-12 09:14:10.058 debugManufacturerProprietary event, [1]:40 [4]:84 payload: 05 40 02 01 84 00 00 00 00 01 00 00 00 12 0A 00 00 00 00 03 01 00 00 00 00 00
dev:9932020-06-12 09:14:08.584 debug+++++ delayBetweenLog parm[0] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:08.195 debug+++++ delayBetweenLog parm[0] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:08.110 debug+++++ delayBetweenLog parm[0] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:07.179 debug+++++ delayBetweenLog parm[0] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:07.150 debug+++++ delayBetweenLog parm[0] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:06.949 debug+++++ delayBetweenLog parm[0] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:06.024 debug+++++ delayBetweenLog parm[0] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:06.021 debug+++++ delayBetweenLog parm[0] dly=1000 responseFlg=true
dev:9932020-06-12 09:14:01.608 debug<<<<< rspFlg=false dly:1000/1000 <<<<< Cmd to Device: ConfigurationSet(configurationValue:[1, 2], defaultValue:false, parameterNumber:1, reserved11:0, size:2) --> 700401020102, delay 1000 <<<<< Cmd to Device: ConfigurationSet(configurationValue:[0, 0, 0, 0], defaultValue:false, parameterNumber:3, reserved11:0, size:4) --> 7004030400000000, delay 1000 <<<<< Cmd to Device: ConfigurationSet(configurationValue:[255], defaultValue:false, parameterNumber:2, reserved11:0, size:1) --> 70040201FF, delay 1000 <<<<< Cmd to Device: ConfigurationSet(configurationValue:[0], defaultValue:false, parameterNumber:22, reserved11:0, size:1) --> 7004160100, delay 1000 <<<<< Cmd to Device: ConfigurationGet(parameterNumber:1) --> 700501, delay 1000 <<<<< Cmd to Device: ConfigurationGet(parameterNumber:2) --> 700502, delay 1000 <<<<< Cmd to Device: ConfigurationGet(parameterNumber:3) --> 700503, delay 1000 <<<<< Cmd to Device: ConfigurationGet(parameterNumber:22) --> 700516, delay 1000 <<<<< HubAction: 910005400102870301, delay 1000 <<<<< HubAction: 910005400101830101
dev:9932020-06-12 09:14:01.547 debug+++++ delayBetweenLog parm[10] dly=1000 responseFlg=false
dev:9932020-06-12 09:14:01.502 debugstate key: spaSetpointTemp, value: 0.0
dev:9932020-06-12 09:14:01.498 debugstate key: poolSetpointTemp, value: 0.0
dev:9932020-06-12 09:14:01.489 debugstate key: scale, value: 1
dev:9932020-06-12 09:14:01.482 debugstate key: lightCircuitsList, value:
dev:9932020-06-12 09:14:01.475 debugstate key: schedules, value:
dev:9932020-06-12 09:14:01.467 debugstate key: precision, value: 1
dev:9932020-06-12 09:14:01.413 debug+++++ updated() DTH:Ver 4.0.0 state.Versioninfo=null state.ManufacturerInfo=null
