I want to correct something from earlier. I am on 3.1.0a.
Anyway here are two logs regarding the spa/pool mode and the actuators. In prior versions both actuators moved when engaging spa/pool mode.
Here is the log when Spa/Pool (Switch 4) = OFF
dev:2572018-12-12 08:18:58.536 am debug Commands:
0 [ [name:airTempFreeze, value:76, unit:F, displayed:true, isStateChange:true]] - String Command
1 [ [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true]] - String Command
2 [ [name:clock, value:16:19, displayed:false, descriptionText:PE653 Clock: 16:19]] - String Command
dev:2572018-12-12 08:18:58.535 am debug<<<<< rspFlg=true dly:1500/1500
<<<<< Event: [name:airTempFreeze, value:76, unit:F, displayed:true, isStateChange:true]
<<<<< Event: [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true]
<<<<< Event: [name:clock, value:16:19, displayed:false, descriptionText:PE653 Clock: 16:19]
dev:2572018-12-12 08:18:58.533 am debug Event necessary. name:clock evt: "16:19" ==> dev:(null)
dev:2572018-12-12 08:18:58.519 am trace - 13: Map: [name:clock, value:16:19, displayed:false, descriptionText:PE653 Clock: 16:19]
dev:2572018-12-12 08:18:58.518 am trace - l -> [name:clock, value:16:19, displayed:false, descriptionText:PE653 Clock: 16:19]
dev:2572018-12-12 08:18:58.516 am debug Event necessary. name:airTempSolar evt: "0" ==> dev:(null)
dev:2572018-12-12 08:18:58.496 am trace - 12: Map: [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:58.494 am trace - l -> [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:58.492 am debug Event necessary. name:airTempFreeze evt: "76" ==> dev:(null)
dev:2572018-12-12 08:18:58.479 am trace - 11: Map: [name:airTempFreeze, value:76, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:58.477 am trace - l -> [name:airTempFreeze, value:76, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:58.475 am debug Event unnecessary. name:temperature evt: "66" ==> dev:(66)
dev:2572018-12-12 08:18:58.467 am trace - 10: Map: [name:temperature, value:66, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:58.465 am trace - l -> [name:temperature, value:66, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:58.462 am debug Event unnecessary. name:poolSpaMode evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.443 am trace - 9: Map: [name:poolSpaMode, value:off, isStateChange:true, displayed:true, descriptionText:(poolSpaMode set to off)]
dev:2572018-12-12 08:18:58.439 am trace - l -> [name:poolSpaMode, value:off, isStateChange:true, displayed:true, descriptionText:(poolSpaMode set to off)]
dev:2572018-12-12 08:18:58.435 am debug Event unnecessary. name:swVSP4 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.418 am trace - 8: Map: [name:swVSP4, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP4 set to off)]
dev:2572018-12-12 08:18:58.417 am trace - l -> [name:swVSP4, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP4 set to off)]
dev:2572018-12-12 08:18:58.416 am debug Event unnecessary. name:swVSP3 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.415 am trace - 7: Map: [name:swVSP3, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP3 set to off)]
dev:2572018-12-12 08:18:58.413 am trace - l -> [name:swVSP3, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP3 set to off)]
dev:2572018-12-12 08:18:58.412 am debug Event unnecessary. name:swVSP2 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.384 am trace - 6: Map: [name:swVSP2, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP2 set to off)]
dev:2572018-12-12 08:18:58.383 am trace - l -> [name:swVSP2, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP2 set to off)]
dev:2572018-12-12 08:18:58.382 am debug Event unnecessary. name:swVSP1 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.342 am debug Commands:
dev:2572018-12-12 08:18:58.341 am debug<<<<< rspFlg=true dly:1500/1500
dev:2572018-12-12 08:18:58.245 am trace - 5: Map: [name:swVSP1, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP1 set to off)]
dev:2572018-12-12 08:18:58.244 am debug Event necessary. name:clock evt: "16:19" ==> dev:(null)
dev:2572018-12-12 08:18:58.243 am trace - l -> [name:swVSP1, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP1 set to off)]
dev:2572018-12-12 08:18:58.242 am debug Event unnecessary. name:switch5 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.215 am trace - 13: Map: [name:clock, value:16:19, displayed:false, descriptionText:PE653 Clock: 16:19]
dev:2572018-12-12 08:18:58.214 am trace - l -> [name:clock, value:16:19, displayed:false, descriptionText:PE653 Clock: 16:19]
dev:2572018-12-12 08:18:58.212 am debug Event necessary. name:airTempSolar evt: "0" ==> dev:(null)
dev:2572018-12-12 08:18:58.211 am trace - 4: Map: [name:switch5, value:off, isStateChange:true, displayed:true, descriptionText:(switch5 set to off)]
dev:2572018-12-12 08:18:58.210 am trace - l -> [name:switch5, value:off, isStateChange:true, displayed:true, descriptionText:(switch5 set to off)]
dev:2572018-12-12 08:18:58.209 am debug Event unnecessary. name:switch4 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.195 am trace - 3: Map: [name:switch4, value:off, isStateChange:true, displayed:true, descriptionText:(switch4 set to off)]
dev:2572018-12-12 08:18:58.194 am trace - l -> [name:switch4, value:off, isStateChange:true, displayed:true, descriptionText:(switch4 set to off)]
dev:2572018-12-12 08:18:58.193 am trace - 12: Map: [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:58.192 am debug Event unnecessary. name:switch3 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.191 am trace - l -> [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:58.190 am debug Event necessary. name:airTempFreeze evt: "76" ==> dev:(null)
dev:2572018-12-12 08:18:58.189 am trace - 2: Map: [name:switch3, value:off, isStateChange:true, displayed:true, descriptionText:(switch3 set to off)]
dev:2572018-12-12 08:18:58.188 am trace - l -> [name:switch3, value:off, isStateChange:true, displayed:true, descriptionText:(switch3 set to off)]
dev:2572018-12-12 08:18:58.186 am debug Event unnecessary. name:switch2 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.152 am trace - 11: Map: [name:airTempFreeze, value:76, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:58.151 am trace - l -> [name:airTempFreeze, value:76, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:58.150 am debug Event unnecessary. name:temperature evt: "66" ==> dev:(66)
dev:2572018-12-12 08:18:58.149 am trace - 10: Map: [name:temperature, value:66, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:58.148 am trace - l -> [name:temperature, value:66, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:58.147 am debug Event unnecessary. name:poolSpaMode evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.146 am trace - 9: Map: [name:poolSpaMode, value:off, isStateChange:true, displayed:true, descriptionText:(poolSpaMode set to off)]
dev:2572018-12-12 08:18:58.145 am trace - l -> [name:poolSpaMode, value:off, isStateChange:true, displayed:true, descriptionText:(poolSpaMode set to off)]
dev:2572018-12-12 08:18:58.144 am trace - 1: Map: [name:switch2, value:off, isStateChange:true, displayed:true, descriptionText:(switch2 set to off)]
dev:2572018-12-12 08:18:58.142 am debug Event unnecessary. name:swVSP4 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.141 am trace - l -> [name:switch2, value:off, isStateChange:true, displayed:true, descriptionText:(switch2 set to off)]
dev:2572018-12-12 08:18:58.140 am debug Event unnecessary. name:switch1 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.128 am trace - 8: Map: [name:swVSP4, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP4 set to off)]
dev:2572018-12-12 08:18:58.127 am trace - l -> [name:swVSP4, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP4 set to off)]
dev:2572018-12-12 08:18:58.126 am debug Event unnecessary. name:swVSP3 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.118 am trace - 7: Map: [name:swVSP3, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP3 set to off)]
dev:2572018-12-12 08:18:58.117 am trace - l -> [name:swVSP3, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP3 set to off)]
dev:2572018-12-12 08:18:58.115 am debug Event unnecessary. name:swVSP2 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.106 am trace - 6: Map: [name:swVSP2, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP2 set to off)]
dev:2572018-12-12 08:18:58.105 am trace - l -> [name:swVSP2, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP2 set to off)]
dev:2572018-12-12 08:18:58.103 am debug Event unnecessary. name:swVSP1 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.087 am trace - 5: Map: [name:swVSP1, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP1 set to off)]
dev:2572018-12-12 08:18:58.086 am trace - l -> [name:swVSP1, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP1 set to off)]
dev:2572018-12-12 08:18:58.085 am debug Event unnecessary. name:switch5 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.082 am trace - 4: Map: [name:switch5, value:off, isStateChange:true, displayed:true, descriptionText:(switch5 set to off)]
dev:2572018-12-12 08:18:58.081 am trace - l -> [name:switch5, value:off, isStateChange:true, displayed:true, descriptionText:(switch5 set to off)]
dev:2572018-12-12 08:18:58.080 am debug Event unnecessary. name:switch4 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.079 am trace - 0: Map: [name:switch1, value:off, isStateChange:true, displayed:true, descriptionText:(switch1 set to off)]
dev:2572018-12-12 08:18:58.078 am trace - l -> [name:switch1, value:off, isStateChange:true, displayed:true, descriptionText:(switch1 set to off)]
dev:2572018-12-12 08:18:58.076 am debug+++++ delayBetweenLog parm[14] dly=1500 responseFlg=true
dev:2572018-12-12 08:18:58.075 am trace - 3: Map: [name:switch4, value:off, isStateChange:true, displayed:true, descriptionText:(switch4 set to off)]
dev:2572018-12-12 08:18:58.074 am trace - l -> [name:switch4, value:off, isStateChange:true, displayed:true, descriptionText:(switch4 set to off)]
dev:2572018-12-12 08:18:58.073 am debug Event unnecessary. name:switch3 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.044 am debug----- createMultipleEvents: devObj = Switch 6
dev:2572018-12-12 08:18:58.031 am trace - 2: Map: [name:switch3, value:off, isStateChange:true, displayed:true, descriptionText:(switch3 set to off)]
dev:2572018-12-12 08:18:58.030 am trace - l -> [name:switch3, value:off, isStateChange:true, displayed:true, descriptionText:(switch3 set to off)]
dev:2572018-12-12 08:18:58.029 am debug Event unnecessary. name:switch2 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:58.028 am trace - 1: Map: [name:switch2, value:off, isStateChange:true, displayed:true, descriptionText:(switch2 set to off)]
dev:2572018-12-12 08:18:58.026 am trace - l -> [name:switch2, value:off, isStateChange:true, displayed:true, descriptionText:(switch2 set to off)]
dev:2572018-12-12 08:18:58.025 am debug+++++ createMultipleEvents( endpoint:6, name:poolSpaMode, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:58.024 am debug----- createMultipleEvents: devObj = Switch 10
dev:2572018-12-12 08:18:58.013 am debug Event unnecessary. name:switch1 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:57.992 am debug+++++ createMultipleEvents( endpoint:10, name:swVSP4, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.989 am trace - 0: Map: [name:switch1, value:off, isStateChange:true, displayed:true, descriptionText:(switch1 set to off)]
dev:2572018-12-12 08:18:57.987 am trace - l -> [name:switch1, value:off, isStateChange:true, displayed:true, descriptionText:(switch1 set to off)]
dev:2572018-12-12 08:18:57.984 am debug----- createMultipleEvents: devObj = Switch 9
dev:2572018-12-12 08:18:57.983 am debug+++++ delayBetweenLog parm[14] dly=1500 responseFlg=true
dev:2572018-12-12 08:18:57.960 am debug----- createMultipleEvents: devObj = Switch 6
dev:2572018-12-12 08:18:57.944 am debug+++++ createMultipleEvents( endpoint:6, name:poolSpaMode, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.928 am debug----- createMultipleEvents: devObj = Switch 10
dev:2572018-12-12 08:18:57.917 am debug+++++ createMultipleEvents( endpoint:9, name:swVSP3, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.902 am debug----- createMultipleEvents: devObj = Switch 8
dev:2572018-12-12 08:18:57.900 am debug+++++ createMultipleEvents( endpoint:8, name:swVSP2, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.899 am debug+++++ createMultipleEvents( endpoint:10, name:swVSP4, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.898 am debug----- createMultipleEvents: devObj = Switch 7
dev:2572018-12-12 08:18:57.897 am debug----- createMultipleEvents: devObj = Switch 9
dev:2572018-12-12 08:18:57.896 am debug+++++ createMultipleEvents( endpoint:7, name:swVSP1, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.871 am debug----- createMultipleEvents: devObj = Switch 5
dev:2572018-12-12 08:18:57.869 am debug+++++ createMultipleEvents( endpoint:5, name:switch5, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.861 am debug----- createMultipleEvents: devObj = Switch 4
dev:2572018-12-12 08:18:57.853 am debug+++++ createMultipleEvents( endpoint:9, name:swVSP3, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.835 am debug+++++ createMultipleEvents( endpoint:4, name:switch4, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.823 am debug----- createMultipleEvents: devObj = Switch 3
dev:2572018-12-12 08:18:57.819 am debug----- createMultipleEvents: devObj = Switch 8
dev:2572018-12-12 08:18:57.817 am debug+++++ createMultipleEvents( endpoint:3, name:switch3, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.803 am debug----- createMultipleEvents: devObj = Switch 2
dev:2572018-12-12 08:18:57.802 am debug+++++ createMultipleEvents( endpoint:8, name:swVSP2, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.791 am debug+++++ createMultipleEvents( endpoint:2, name:switch2, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.790 am debug----- createMultipleEvents: devObj = Pool Light
dev:2572018-12-12 08:18:57.789 am debug----- createMultipleEvents: devObj = Switch 7
dev:2572018-12-12 08:18:57.787 am debug+++++ createMultipleEvents( endpoint:7, name:swVSP1, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.786 am debug+++++ createMultipleEvents( endpoint:1, name:switch1, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.785 am debugpayload for switches is 0
dev:2572018-12-12 08:18:57.784 am debug+++++ process84Event payload: [5, 64, 2, 2, -124, 0, 0, 0, 0, 0, 2, 1, 66, 76, 0, 16, 19, 1, 0, 0, 0, 3, 4, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
dev:2572018-12-12 08:18:57.773 am debug----- createMultipleEvents: devObj = Switch 5
dev:2572018-12-12 08:18:57.772 am debugManufacturerProprietary event, [1]:40 [4]:84 payload: 05 40 02 02 84 00 00 00 00 00 02 01 42 4C 00 10 13 01 00 00 00 03 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
dev:2572018-12-12 08:18:57.770 am trace<<< Incoming: [zw device: 38, command: 9100, payload: 05 40 02 02 84 00 00 00 00 00 02 01 42 4C 00 10 13 01 00 00 00 03 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
dev:2572018-12-12 08:18:57.633 am debug+++++ createMultipleEvents( endpoint:5, name:switch5, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.588 am debug----- createMultipleEvents: devObj = Switch 4
dev:2572018-12-12 08:18:57.581 am debug Commands:
0 [ [name:heater, value:off, isStateChange:true, displayed:true, descriptionText:Heater is off]] - String Command
dev:2572018-12-12 08:18:57.580 am debug<<<<< rspFlg=true dly:1500/1500
<<<<< Event: [name:heater, value:off, isStateChange:true, displayed:true, descriptionText:Heater is off]
dev:2572018-12-12 08:18:57.579 am debug Event necessary. name:heater evt: "off" ==> dev:(null)
dev:2572018-12-12 08:18:57.578 am debug+++++ createMultipleEvents( endpoint:4, name:switch4, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.543 am debug----- createMultipleEvents: devObj = Switch 3
dev:2572018-12-12 08:18:57.531 am trace - 0: Map: [name:heater, value:off, isStateChange:true, displayed:true, descriptionText:Heater is off]
dev:2572018-12-12 08:18:57.530 am trace - l -> [name:heater, value:off, isStateChange:true, displayed:true, descriptionText:Heater is off]
dev:2572018-12-12 08:18:57.529 am debug+++++ delayBetweenLog parm[1] dly=1500 responseFlg=true
dev:2572018-12-12 08:18:57.527 am debug+++++ createMultipleEvents( endpoint:3, name:switch3, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.525 am debug+++++ process87Event payload: [5, 64, 2, 2, -121, 0, 0, 0, 0, 0, 0, 7, 0, 0, 0, 0, 0, 16, 4, 0, 0, 0, 0, 0, 16, 19, 1, 1, 0, 0, 32, 0, 0, 0, 0, 0, 0, 0, 0, 0]
dev:2572018-12-12 08:18:57.515 am debug----- createMultipleEvents: devObj = Switch 2
dev:2572018-12-12 08:18:57.493 am debugManufacturerProprietary event, [1]:40 [4]:87 payload: 05 40 02 02 87 00 00 00 00 00 00 07 00 00 00 00 00 10 04 00 00 00 00 00 10 13 01 01 00 00 20 00 00 00 00 00 00 00 00 00
dev:2572018-12-12 08:18:57.492 am trace<<< Incoming: [zw device: 38, command: 9100, payload: 05 40 02 02 87 00 00 00 00 00 00 07 00 00 00 00 00 10 04 00 00 00 00 00 10 13 01 01 00 00 20 00 00 00 00 00 00 00 00 00 ]
dev:2572018-12-12 08:18:57.490 am debug+++++ createMultipleEvents( endpoint:2, name:switch2, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.459 am debug----- createMultipleEvents: devObj = Pool Light
dev:2572018-12-12 08:18:57.396 am debug+++++ createMultipleEvents( endpoint:1, name:switch1, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:57.395 am debugpayload for switches is 0
dev:2572018-12-12 08:18:57.393 am debug+++++ process84Event payload: [5, 64, 2, 2, -124, 0, 0, 0, 0, 0, 2, 1, 66, 76, 0, 16, 19, 1, 0, 0, 0, 3, 4, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
dev:2572018-12-12 08:18:57.366 am debugManufacturerProprietary event, [1]:40 [4]:84 payload: 05 40 02 02 84 00 00 00 00 00 02 01 42 4C 00 10 13 01 00 00 00 03 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
dev:2572018-12-12 08:18:57.363 am trace<<< Incoming: [zw device: 38, command: 9100, payload: 05 40 02 02 84 00 00 00 00 00 02 01 42 4C 00 10 13 01 00 00 00 03 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
dev:2572018-12-12 08:18:57.283 am debug Commands:
dev:2572018-12-12 08:18:57.272 am debug<<<<< rspFlg=true dly:1500/1500
dev:2572018-12-12 08:18:57.270 am debug Event necessary. name:clock evt: "16:19" ==> dev:(null)
dev:2572018-12-12 08:18:57.226 am trace - 13: Map: [name:clock, value:16:19, displayed:false, descriptionText:PE653 Clock: 16:19]
dev:2572018-12-12 08:18:57.225 am trace - l -> [name:clock, value:16:19, displayed:false, descriptionText:PE653 Clock: 16:19]
dev:2572018-12-12 08:18:57.224 am debug Event necessary. name:airTempSolar evt: "0" ==> dev:(null)
dev:2572018-12-12 08:18:57.211 am debug Commands:
dev:2572018-12-12 08:18:57.210 am debug<<<<< rspFlg=true dly:1500/1500
dev:2572018-12-12 08:18:57.203 am debug Event necessary. name:clock evt: "16:19" ==> dev:(null)
dev:2572018-12-12 08:18:57.202 am trace - 13: Map: [name:clock, value:16:19, displayed:false, descriptionText:PE653 Clock: 16:19]
dev:2572018-12-12 08:18:57.200 am trace - l -> [name:clock, value:16:19, displayed:false, descriptionText:PE653 Clock: 16:19]
dev:2572018-12-12 08:18:57.199 am trace - 12: Map: [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:57.198 am debug Event necessary. name:airTempSolar evt: "0" ==> dev:(null)
dev:2572018-12-12 08:18:57.197 am trace - l -> [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:57.196 am debug Event necessary. name:airTempFreeze evt: "76" ==> dev:(null)
dev:2572018-12-12 08:18:57.022 am trace - 12: Map: [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:57.021 am trace - l -> [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:57.020 am debug Event necessary. name:airTempFreeze evt: "76" ==> dev:(null)
dev:2572018-12-12 08:18:57.019 am trace - 11: Map: [name:airTempFreeze, value:76, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:57.018 am trace - l -> [name:airTempFreeze, value:76, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:57.017 am debug Event unnecessary. name:temperature evt: "66" ==> dev:(66)
dev:2572018-12-12 08:18:57.016 am trace - 10: Map: [name:temperature, value:66, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:57.014 am trace - l -> [name:temperature, value:66, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:57.013 am debug Event unnecessary. name:poolSpaMode evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.981 am trace - 11: Map: [name:airTempFreeze, value:76, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:56.980 am trace - l -> [name:airTempFreeze, value:76, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:56.979 am debug Event unnecessary. name:temperature evt: "66" ==> dev:(66)
dev:2572018-12-12 08:18:56.978 am trace - 9: Map: [name:poolSpaMode, value:off, isStateChange:true, displayed:true, descriptionText:(poolSpaMode set to off)]
dev:2572018-12-12 08:18:56.977 am trace - l -> [name:poolSpaMode, value:off, isStateChange:true, displayed:true, descriptionText:(poolSpaMode set to off)]
dev:2572018-12-12 08:18:56.975 am debug Event unnecessary. name:swVSP4 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.974 am trace - 10: Map: [name:temperature, value:66, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:56.962 am trace - l -> [name:temperature, value:66, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:56.961 am debug Event unnecessary. name:poolSpaMode evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.960 am trace - 8: Map: [name:swVSP4, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP4 set to off)]
dev:2572018-12-12 08:18:56.954 am trace - l -> [name:swVSP4, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP4 set to off)]
dev:2572018-12-12 08:18:56.942 am debug Event unnecessary. name:swVSP3 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.941 am trace - 9: Map: [name:poolSpaMode, value:off, isStateChange:true, displayed:true, descriptionText:(poolSpaMode set to off)]
dev:2572018-12-12 08:18:56.940 am trace - l -> [name:poolSpaMode, value:off, isStateChange:true, displayed:true, descriptionText:(poolSpaMode set to off)]
dev:2572018-12-12 08:18:56.938 am debug Event unnecessary. name:swVSP4 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.937 am trace - 7: Map: [name:swVSP3, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP3 set to off)]
dev:2572018-12-12 08:18:56.936 am trace - l -> [name:swVSP3, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP3 set to off)]
dev:2572018-12-12 08:18:56.935 am debug Event unnecessary. name:swVSP2 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.934 am trace - 8: Map: [name:swVSP4, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP4 set to off)]
dev:2572018-12-12 08:18:56.933 am trace - l -> [name:swVSP4, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP4 set to off)]
dev:2572018-12-12 08:18:56.931 am trace - 6: Map: [name:swVSP2, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP2 set to off)]
dev:2572018-12-12 08:18:56.930 am debug Event unnecessary. name:swVSP3 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.929 am trace - l -> [name:swVSP2, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP2 set to off)]
dev:2572018-12-12 08:18:56.928 am debug Event unnecessary. name:swVSP1 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.859 am trace - 5: Map: [name:swVSP1, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP1 set to off)]
dev:2572018-12-12 08:18:56.858 am trace - l -> [name:swVSP1, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP1 set to off)]
dev:2572018-12-12 08:18:56.857 am debug Event unnecessary. name:switch5 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.855 am trace - 7: Map: [name:swVSP3, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP3 set to off)]
dev:2572018-12-12 08:18:56.854 am trace - l -> [name:swVSP3, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP3 set to off)]
dev:2572018-12-12 08:18:56.853 am debug Event unnecessary. name:swVSP2 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.839 am trace - 4: Map: [name:switch5, value:off, isStateChange:true, displayed:true, descriptionText:(switch5 set to off)]
dev:2572018-12-12 08:18:56.838 am trace - l -> [name:switch5, value:off, isStateChange:true, displayed:true, descriptionText:(switch5 set to off)]
dev:2572018-12-12 08:18:56.836 am debug Event unnecessary. name:switch4 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.835 am trace - 6: Map: [name:swVSP2, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP2 set to off)]
dev:2572018-12-12 08:18:56.834 am trace - l -> [name:swVSP2, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP2 set to off)]
dev:2572018-12-12 08:18:56.822 am debug Event unnecessary. name:swVSP1 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.821 am trace - 5: Map: [name:swVSP1, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP1 set to off)]
dev:2572018-12-12 08:18:56.820 am trace - l -> [name:swVSP1, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP1 set to off)]
dev:2572018-12-12 08:18:56.818 am debug Event unnecessary. name:switch5 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.817 am trace - 3: Map: [name:switch4, value:off, isStateChange:true, displayed:true, descriptionText:(switch4 set to off)]
dev:2572018-12-12 08:18:56.816 am trace - l -> [name:switch4, value:off, isStateChange:true, displayed:true, descriptionText:(switch4 set to off)]
dev:2572018-12-12 08:18:56.815 am trace - 4: Map: [name:switch5, value:off, isStateChange:true, displayed:true, descriptionText:(switch5 set to off)]
dev:2572018-12-12 08:18:56.814 am debug Event unnecessary. name:switch3 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.813 am trace - l -> [name:switch5, value:off, isStateChange:true, displayed:true, descriptionText:(switch5 set to off)]
dev:2572018-12-12 08:18:56.811 am debug Event unnecessary. name:switch4 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.592 am trace - 3: Map: [name:switch4, value:off, isStateChange:true, displayed:true, descriptionText:(switch4 set to off)]
dev:2572018-12-12 08:18:56.591 am trace - l -> [name:switch4, value:off, isStateChange:true, displayed:true, descriptionText:(switch4 set to off)]
dev:2572018-12-12 08:18:56.585 am trace - 2: Map: [name:switch3, value:off, isStateChange:true, displayed:true, descriptionText:(switch3 set to off)]
dev:2572018-12-12 08:18:56.583 am trace - l -> [name:switch3, value:off, isStateChange:true, displayed:true, descriptionText:(switch3 set to off)]
dev:2572018-12-12 08:18:56.582 am debug Event unnecessary. name:switch2 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.581 am debug Event unnecessary. name:switch3 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.578 am trace - 1: Map: [name:switch2, value:off, isStateChange:true, displayed:true, descriptionText:(switch2 set to off)]
dev:2572018-12-12 08:18:56.577 am trace - l -> [name:switch2, value:off, isStateChange:true, displayed:true, descriptionText:(switch2 set to off)]
dev:2572018-12-12 08:18:56.576 am debug Event unnecessary. name:switch1 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.573 am trace - 0: Map: [name:switch1, value:off, isStateChange:true, displayed:true, descriptionText:(switch1 set to off)]
dev:2572018-12-12 08:18:56.572 am trace - l -> [name:switch1, value:off, isStateChange:true, displayed:true, descriptionText:(switch1 set to off)]
dev:2572018-12-12 08:18:56.570 am debug+++++ delayBetweenLog parm[14] dly=1500 responseFlg=true
dev:2572018-12-12 08:18:56.562 am trace - 2: Map: [name:switch3, value:off, isStateChange:true, displayed:true, descriptionText:(switch3 set to off)]
dev:2572018-12-12 08:18:56.559 am trace - l -> [name:switch3, value:off, isStateChange:true, displayed:true, descriptionText:(switch3 set to off)]
dev:2572018-12-12 08:18:56.557 am debug Event unnecessary. name:switch2 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.555 am debug----- createMultipleEvents: devObj = Switch 6
dev:2572018-12-12 08:18:56.494 am trace - 1: Map: [name:switch2, value:off, isStateChange:true, displayed:true, descriptionText:(switch2 set to off)]
dev:2572018-12-12 08:18:56.492 am trace - l -> [name:switch2, value:off, isStateChange:true, displayed:true, descriptionText:(switch2 set to off)]
dev:2572018-12-12 08:18:56.490 am debug Event unnecessary. name:switch1 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:56.484 am trace - 0: Map: [name:switch1, value:off, isStateChange:true, displayed:true, descriptionText:(switch1 set to off)]
dev:2572018-12-12 08:18:56.483 am trace - l -> [name:switch1, value:off, isStateChange:true, displayed:true, descriptionText:(switch1 set to off)]
dev:2572018-12-12 08:18:56.482 am debug+++++ delayBetweenLog parm[14] dly=1500 responseFlg=true
dev:2572018-12-12 08:18:56.466 am debug+++++ createMultipleEvents( endpoint:6, name:poolSpaMode, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:56.464 am debug----- createMultipleEvents: devObj = Switch 6
dev:2572018-12-12 08:18:56.463 am debug----- createMultipleEvents: devObj = Switch 10
dev:2572018-12-12 08:18:56.460 am debug+++++ createMultipleEvents( endpoint:6, name:poolSpaMode, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:56.457 am debug----- createMultipleEvents: devObj = Switch 10
dev:2572018-12-12 08:18:56.450 am debug+++++ createMultipleEvents( endpoint:10, name:swVSP4, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:56.383 am debug+++++ createMultipleEvents( endpoint:10, name:swVSP4, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:56.374 am debug----- createMultipleEvents: devObj = Switch 9
dev:2572018-12-12 08:18:56.371 am debug----- createMultipleEvents: devObj = Switch 9
dev:2572018-12-12 08:18:56.367 am debug+++++ createMultipleEvents( endpoint:9, name:swVSP3, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:56.365 am debug----- createMultipleEvents: devObj = Switch 8
dev:2572018-12-12 08:18:56.293 am debug+++++ createMultipleEvents( endpoint:8, name:swVSP2, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:56.292 am debug+++++ createMultipleEvents( endpoint:9, name:swVSP3, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:56.286 am debug----- createMultipleEvents: devObj = Switch 8
dev:2572018-12-12 08:18:56.279 am debug----- createMultipleEvents: devObj = Switch 7
dev:2572018-12-12 08:18:56.273 am debug+++++ createMultipleEvents( endpoint:8, name:swVSP2, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:56.094 am debug+++++ createMultipleEvents( endpoint:7, name:swVSP1, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:56.086 am debug----- createMultipleEvents: devObj = Switch 7
dev:2572018-12-12 08:18:56.078 am debug----- createMultipleEvents: devObj = Switch 5
dev:2572018-12-12 08:18:56.070 am debug+++++ createMultipleEvents( endpoint:7, name:swVSP1, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:55.996 am debug+++++ createMultipleEvents( endpoint:5, name:switch5, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:55.990 am debug----- createMultipleEvents: devObj = Switch 5
dev:2572018-12-12 08:18:55.986 am debug----- createMultipleEvents: devObj = Switch 4
dev:2572018-12-12 08:18:55.980 am debug+++++ createMultipleEvents( endpoint:5, name:switch5, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:55.976 am debug----- createMultipleEvents: devObj = Switch 4
dev:2572018-12-12 08:18:55.966 am debug+++++ createMultipleEvents( endpoint:4, name:switch4, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:55.789 am debug----- createMultipleEvents: devObj = Switch 3
dev:2572018-12-12 08:18:55.786 am debug+++++ createMultipleEvents( endpoint:3, name:switch3, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:55.785 am debug+++++ createMultipleEvents( endpoint:4, name:switch4, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:55.780 am debug----- createMultipleEvents: devObj = Switch 3
dev:2572018-12-12 08:18:55.771 am debug----- createMultipleEvents: devObj = Switch 2
dev:2572018-12-12 08:18:55.757 am debug+++++ createMultipleEvents( endpoint:3, name:switch3, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:55.747 am debug----- createMultipleEvents: devObj = Switch 2
dev:2572018-12-12 08:18:55.746 am debug+++++ createMultipleEvents( endpoint:2, name:switch2, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:55.745 am debug+++++ createMultipleEvents( endpoint:2, name:switch2, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:55.727 am debug----- createMultipleEvents: devObj = Pool Light
dev:2572018-12-12 08:18:55.721 am debug----- createMultipleEvents: devObj = Pool Light
dev:2572018-12-12 08:18:55.717 am debug+++++ createMultipleEvents( endpoint:1, name:switch1, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:55.707 am debug+++++ createMultipleEvents( endpoint:1, name:switch1, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:55.706 am debugpayload for switches is 0
dev:2572018-12-12 08:18:55.705 am debug+++++ process84Event payload: [5, 64, 2, 2, -124, 0, 0, 0, 0, 0, 2, 1, 66, 76, 0, 16, 19, 1, 0, 0, 0, 3, 4, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
dev:2572018-12-12 08:18:55.700 am debugpayload for switches is 0
dev:2572018-12-12 08:18:55.699 am debug+++++ process84Event payload: [5, 64, 2, 2, -124, 0, 0, 0, 0, 0, 2, 1, 66, 76, 0, 16, 19, 1, 0, 0, 0, 3, 4, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
dev:2572018-12-12 08:18:55.698 am debugManufacturerProprietary event, [1]:40 [4]:84 payload: 05 40 02 02 84 00 00 00 00 00 02 01 42 4C 00 10 13 01 00 00 00 03 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
dev:2572018-12-12 08:18:55.697 am debugManufacturerProprietary event, [1]:40 [4]:84 payload: 05 40 02 02 84 00 00 00 00 00 02 01 42 4C 00 10 13 01 00 00 00 03 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
dev:2572018-12-12 08:18:55.695 am trace<<< Incoming: [zw device: 38, command: 9100, payload: 05 40 02 02 84 00 00 00 00 00 02 01 42 4C 00 10 13 01 00 00 00 03 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
dev:2572018-12-12 08:18:55.693 am trace<<< Incoming: [zw device: 38, command: 9100, payload: 05 40 02 02 84 00 00 00 00 00 02 01 42 4C 00 10 13 01 00 00 00 03 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
dev:2572018-12-12 08:18:51.375 am debug Commands:
0 [ 600604250100 ] - String Command
1 [ delay 1000 ] - String Command
2 [ 910005400102870301 ] - String Command
3 [ delay 1000 ] - String Command
4 [ 910005400101830101 ] - String Command
dev:2572018-12-12 08:18:51.362 am debug----- executeCommands final set:
dev:2572018-12-12 08:18:51.361 am debug Commands:
dev:2572018-12-12 08:18:51.360 am debug+++++ executeCommands
dev:2572018-12-12 08:18:51.358 am debug+++++ setChanState(4, 0)
dev:2572018-12-12 08:18:50.975 am debug Commands:
0 [ [name:switch4, value:off, isStateChange:true, displayed:true, descriptionText:(switch4 set to off)]] - String Command
1 [ [name:poolSpaMode, value:off, isStateChange:true, displayed:true, descriptionText:(poolSpaMode set to off)]] - String Command
2 [ [name:temperature, value:66, unit:F, displayed:true, isStateChange:true]] - String Command
3 [ [name:airTempFreeze, value:76, unit:F, displayed:true, isStateChange:true]] - String Command
4 [ [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true]] - String Command
5 [ [name:clock, value:16:19, displayed:false, descriptionText:PE653 Clock: 16:19]] - String Command
dev:2572018-12-12 08:18:50.973 am debug<<<<< rspFlg=true dly:1500/1500
<<<<< Event: "off" to child: 38-ep4:Switch 4
<<<<< Event: [name:switch4, value:off, isStateChange:true, displayed:true, descriptionText:(switch4 set to off)]
<<<<< Event: "off" to child: 38-ep6:Switch 6
<<<<< Event: [name:poolSpaMode, value:off, isStateChange:true, displayed:true, descriptionText:(poolSpaMode set to off)]
<<<<< Event: [name:temperature, value:66, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:50.972 am debug Event necessary. name:clock evt: "16:19" ==> dev:(null)
dev:2572018-12-12 08:18:50.956 am debug Commands:
dev:2572018-12-12 08:18:50.954 am debug<<<<< rspFlg=true dly:1500/1500
dev:2572018-12-12 08:18:50.953 am debug Event necessary. name:heater evt: "off" ==> dev:(null)
dev:2572018-12-12 08:18:50.892 am trace - 0: Map: [name:heater, value:off, isStateChange:true, displayed:true, descriptionText:Heater is off]
dev:2572018-12-12 08:18:50.890 am trace - l -> [name:heater, value:off, isStateChange:true, displayed:true, descriptionText:Heater is off]
dev:2572018-12-12 08:18:50.889 am debug+++++ delayBetweenLog parm[1] dly=1500 responseFlg=true
dev:2572018-12-12 08:18:50.883 am debug+++++ process87Event payload: [5, 64, 2, 2, -121, 0, 0, 0, 0, 0, 0, 7, 0, 0, 0, 0, 0, 16, 4, 0, 0, 0, 0, 0, 16, 19, 1, 1, 0, 0, 32, 0, 0, 0, 0, 0, 0, 0, 0, 0]
dev:2572018-12-12 08:18:50.881 am trace - 15: Map: [name:clock, value:16:19, displayed:false, descriptionText:PE653 Clock: 16:19]
dev:2572018-12-12 08:18:50.880 am trace - l -> [name:clock, value:16:19, displayed:false, descriptionText:PE653 Clock: 16:19]
dev:2572018-12-12 08:18:50.879 am debugManufacturerProprietary event, [1]:40 [4]:87 payload: 05 40 02 02 87 00 00 00 00 00 00 07 00 00 00 00 00 10 04 00 00 00 00 00 10 13 01 01 00 00 20 00 00 00 00 00 00 00 00 00
dev:2572018-12-12 08:18:50.878 am debug Event necessary. name:airTempSolar evt: "0" ==> dev:(null)
dev:2572018-12-12 08:18:50.877 am trace<<< Incoming: [zw device: 38, command: 9100, payload: 05 40 02 02 87 00 00 00 00 00 00 07 00 00 00 00 00 10 04 00 00 00 00 00 10 13 01 01 00 00 20 00 00 00 00 00 00 00 00 00 ]
dev:2572018-12-12 08:18:50.876 am trace - 14: Map: [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:50.874 am trace - l -> [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:50.873 am debug Event necessary. name:airTempFreeze evt: "76" ==> dev:(null)
dev:2572018-12-12 08:18:50.650 am trace - 13: Map: [name:airTempFreeze, value:76, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:50.649 am trace - l -> [name:airTempFreeze, value:76, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:50.648 am debug Event necessary. name:temperature evt: "66" ==> dev:(65)
dev:2572018-12-12 08:18:50.602 am trace - 12: Map: [name:temperature, value:66, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:50.601 am trace - l -> [name:temperature, value:66, unit:F, displayed:true, isStateChange:true]
dev:2572018-12-12 08:18:50.599 am debug Event necessary. name:poolSpaMode evt: "off" ==> dev:(on)
dev:2572018-12-12 08:18:50.529 am trace - 11: Map: [name:poolSpaMode, value:off, isStateChange:true, displayed:true, descriptionText:(poolSpaMode set to off)]
dev:2572018-12-12 08:18:50.527 am trace - l -> [name:poolSpaMode, value:off, isStateChange:true, displayed:true, descriptionText:(poolSpaMode set to off)]
dev:2572018-12-12 08:18:50.526 am trace - 10: String: Note:Event: "off" to child: 38-ep6:Switch 6
dev:2572018-12-12 08:18:50.525 am trace - l -> Note:Event: "off" to child: 38-ep6:Switch 6
dev:2572018-12-12 08:18:50.524 am debug Event unnecessary. name:swVSP4 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:50.517 am trace - 9: Map: [name:swVSP4, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP4 set to off)]
dev:2572018-12-12 08:18:50.516 am trace - l -> [name:swVSP4, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP4 set to off)]
dev:2572018-12-12 08:18:50.515 am debug Event unnecessary. name:swVSP3 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:50.445 am trace - 8: Map: [name:swVSP3, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP3 set to off)]
dev:2572018-12-12 08:18:50.444 am trace - l -> [name:swVSP3, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP3 set to off)]
dev:2572018-12-12 08:18:50.443 am debug Event unnecessary. name:swVSP2 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:50.440 am trace - 7: Map: [name:swVSP2, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP2 set to off)]
dev:2572018-12-12 08:18:50.438 am trace - l -> [name:swVSP2, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP2 set to off)]
dev:2572018-12-12 08:18:50.437 am debug Event unnecessary. name:swVSP1 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:50.373 am trace - 6: Map: [name:swVSP1, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP1 set to off)]
dev:2572018-12-12 08:18:50.372 am trace - l -> [name:swVSP1, value:off, isStateChange:true, displayed:true, descriptionText:(swVSP1 set to off)]
dev:2572018-12-12 08:18:50.371 am debug Event unnecessary. name:switch5 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:50.370 am trace - 5: Map: [name:switch5, value:off, isStateChange:true, displayed:true, descriptionText:(switch5 set to off)]
dev:2572018-12-12 08:18:50.368 am trace - l -> [name:switch5, value:off, isStateChange:true, displayed:true, descriptionText:(switch5 set to off)]
dev:2572018-12-12 08:18:50.367 am debug Event necessary. name:switch4 evt: "off" ==> dev:(on)
dev:2572018-12-12 08:18:50.366 am trace - 4: Map: [name:switch4, value:off, isStateChange:true, displayed:true, descriptionText:(switch4 set to off)]
dev:2572018-12-12 08:18:50.364 am trace - l -> [name:switch4, value:off, isStateChange:true, displayed:true, descriptionText:(switch4 set to off)]
dev:2572018-12-12 08:18:50.363 am trace - 3: String: Note:Event: "off" to child: 38-ep4:Switch 4
dev:2572018-12-12 08:18:50.362 am trace - l -> Note:Event: "off" to child: 38-ep4:Switch 4
dev:2572018-12-12 08:18:50.357 am debug Event unnecessary. name:switch3 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:50.356 am trace - 2: Map: [name:switch3, value:off, isStateChange:true, displayed:true, descriptionText:(switch3 set to off)]
dev:2572018-12-12 08:18:50.354 am trace - l -> [name:switch3, value:off, isStateChange:true, displayed:true, descriptionText:(switch3 set to off)]
dev:2572018-12-12 08:18:50.350 am debug Event unnecessary. name:switch2 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:50.344 am trace - 1: Map: [name:switch2, value:off, isStateChange:true, displayed:true, descriptionText:(switch2 set to off)]
dev:2572018-12-12 08:18:50.343 am trace - l -> [name:switch2, value:off, isStateChange:true, displayed:true, descriptionText:(switch2 set to off)]
dev:2572018-12-12 08:18:50.341 am debug Event unnecessary. name:switch1 evt: "off" ==> dev:(off)
dev:2572018-12-12 08:18:50.301 am trace - 0: Map: [name:switch1, value:off, isStateChange:true, displayed:true, descriptionText:(switch1 set to off)]
dev:2572018-12-12 08:18:50.299 am trace - l -> [name:switch1, value:off, isStateChange:true, displayed:true, descriptionText:(switch1 set to off)]
dev:2572018-12-12 08:18:50.291 am debug+++++ delayBetweenLog parm[16] dly=1500 responseFlg=true
dev:2572018-12-12 08:18:50.283 am debugrespType:84 differences:3
__ __ --- --- --- --- --- --- --- --- 08 --- --- 11 12 --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- --- ---
new-: 05 40 02 02 84 00 00 00 00 00 02 01 42 4C 00 10 13 01 00 00 00 03 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
old-- : 05 40 02 02 84 00 00 00 08 00 02 00 41 4C 00 10 12 01 00 00 00 03 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
dev:2572018-12-12 08:18:50.266 am debug<<<<< Child Event necessary: name:38-ep6:poolSpaMode evt: "off" ==> dev (on)
dev:2572018-12-12 08:18:50.263 am debug----- createMultipleEvents: devObj = Switch 6
dev:2572018-12-12 08:18:50.258 am debug+++++ createMultipleEvents( endpoint:6, name:poolSpaMode, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:50.253 am debug----- createMultipleEvents: devObj = Switch 10
dev:2572018-12-12 08:18:50.250 am debug+++++ createMultipleEvents( endpoint:10, name:swVSP4, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:50.187 am debug----- createMultipleEvents: devObj = Switch 9
dev:2572018-12-12 08:18:50.180 am debug+++++ createMultipleEvents( endpoint:9, name:swVSP3, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:50.177 am debug----- createMultipleEvents: devObj = Switch 8
dev:2572018-12-12 08:18:50.167 am debug+++++ createMultipleEvents( endpoint:8, name:swVSP2, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:50.104 am debug----- createMultipleEvents: devObj = Switch 7
dev:2572018-12-12 08:18:50.092 am debug+++++ createMultipleEvents( endpoint:7, name:swVSP1, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:50.086 am debug----- createMultipleEvents: devObj = Switch 5
dev:2572018-12-12 08:18:50.029 am debug+++++ createMultipleEvents( endpoint:5, name:switch5, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:50.025 am debug<<<<< Child Event necessary: name:38-ep4:switch4 evt: "off" ==> dev (on)
dev:2572018-12-12 08:18:50.001 am debug----- createMultipleEvents: devObj = Switch 4
dev:2572018-12-12 08:18:49.990 am debug+++++ createMultipleEvents( endpoint:4, name:switch4, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:49.984 am debug----- createMultipleEvents: devObj = Switch 3
dev:2572018-12-12 08:18:49.925 am debug+++++ createMultipleEvents( endpoint:3, name:switch3, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:49.905 am debug----- createMultipleEvents: devObj = Switch 2
dev:2572018-12-12 08:18:49.898 am debug+++++ createMultipleEvents( endpoint:2, name:switch2, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:49.835 am debug----- createMultipleEvents: devObj = Pool Light
dev:2572018-12-12 08:18:49.755 am debug+++++ createMultipleEvents( endpoint:1, name:switch1, externalParm:0, myParm:off)
dev:2572018-12-12 08:18:49.739 am debugpayload for switches is 0
dev:2572018-12-12 08:18:49.737 am debug+++++ process84Event payload: [5, 64, 2, 2, -124, 0, 0, 0, 0, 0, 2, 1, 66, 76, 0, 16, 19, 1, 0, 0, 0, 3, 4, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
dev:2572018-12-12 08:18:49.673 am debugManufacturerProprietary event, [1]:40 [4]:84 payload: 05 40 02 02 84 00 00 00 00 00 02 01 42 4C 00 10 13 01 00 00 00 03 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
dev:2572018-12-12 08:18:49.643 am trace<<< Incoming: [zw device: 38, command: 9100, payload: 05 40 02 02 84 00 00 00 00 00 02 01 42 4C 00 10 13 01 00 00 00 03 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
dev:2572018-12-12 08:18:49.181 am debug Commands:
dev:2572018-12-12 08:18:49.177 am debug----- executeCommands final set:
dev:2572018-12-12 08:18:49.174 am debug Commands:
dev:2572018-12-12 08:18:49.166 am debug+++++ executeCommands
dev:2572018-12-12 08:18:49.069 am debug+++++ setChanState(4, 0)
