Z-Wave Metering Outlet - TKB Driver UK Outlet
I'm not sure wether I have reinvented the wheel here..... if someone else has already done this and I've missed the point feel free to point me in the right direction.
I'm new to HE, I've pretty much thrown a 4+ year old ST installation in the bin/trash, migration has been an impatient process for me, I simply couldn't bear the delays and issues I've had with ST recently, especially with the user base I have here :-). All has gone well but I'l left with three issues (aside form the usual fine tuning):
  1. I have a load of Fibaro FGMS-001 that joins as a 'Device' and then join securely (I don't want the secure join), it's slow, my repeaters aren't relaying it correctly (I think) and the batteries drain in no time.
  2. Fibaro FGK-101 contact sensors, can't find a driver. So they are useless I believe.
  3. I have a lot of TKB TZ69E and TZ88 metering sockets that work well with a generic z-wave outlet driver but the has no metering capability.
This post is therefore about 3! So, I've ported one from ST. I've not done a huge amount of testing with it but I can turn the outlet on and off and the power displays when the something is drawing power......
I've not cleaned up the code so it has numerous fingerprints in it but apply this to a TKB TZ69E works!
Time to get the Tumble Dryer notification back on-line!!!
metadata {
	definition (name: "Z-Wave Metering Switch", namespace: "smartthings", author: "SmartThings", ocfDeviceType: "oic.d.switch", runLocally: true, minHubCoreVersion: '000.017.0012', executeCommandsLocally: false, genericHandler: "Z-Wave") {
		capability "Energy Meter"
		capability "Actuator"
		capability "Switch"
		capability "Power Meter"
		capability "Refresh"
		capability "Configuration"
		capability "Sensor"
		capability "Light"
		capability "Health Check"
		command "reset"
		fingerprint inClusters: "0x25,0x32", deviceJoinName: "Switch"
		fingerprint mfr: "0086", prod: "0003", model: "0012", deviceJoinName: "Aeotec Switch" //Aeotec Micro Smart Switch
		fingerprint mfr: "021F", prod: "0003", model: "0087", deviceJoinName: "Dome Outlet", ocfDeviceType: "oic.d.smartplug" //Dome On/Off Plug-in Switch
		fingerprint mfr: "0086", prod: "0103", model: "0060", deviceJoinName: "Aeotec Outlet", ocfDeviceType: "oic.d.smartplug"  //US //Aeotec Smart Switch 6
		fingerprint mfr: "0086", prod: "0003", model: "0060", deviceJoinName: "Aeotec Outlet", ocfDeviceType: "oic.d.smartplug"  //EU //Aeotec Smart Switch 6
		fingerprint mfr: "0086", prod: "0203", model: "0060", deviceJoinName: "Aeotec Outlet", ocfDeviceType: "oic.d.smartplug"  //AU //Aeotec Smart Switch 6
		fingerprint mfr: "0086", prod: "0103", model: "0074", deviceJoinName: "Aeotec Switch" //Aeotec Nano Switch
		fingerprint mfr: "0086", prod: "0003", model: "0074", deviceJoinName: "Aeotec Switch" //Aeotec Nano Switch
		fingerprint mfr: "0086", prod: "0203", model: "0074", deviceJoinName: "Aeotec Switch" //AU //Aeotec Nano Switch
		fingerprint mfr: "014F", prod: "574F", model: "3535", deviceJoinName: "GoControl Outlet", ocfDeviceType: "oic.d.smartplug" //GoControl Wall-Mounted Outlet
		fingerprint mfr: "014F", prod: "5053", model: "3531", deviceJoinName: "GoControl Outlet", ocfDeviceType: "oic.d.smartplug" //GoControl Plug-in Switch
		fingerprint mfr: "0063", prod: "4F44", model: "3031", deviceJoinName: "GE Switch" //GE Direct-Wire Outdoor Switch
		fingerprint mfr: "0258", prod: "0003", model: "0087", deviceJoinName: "NEO Coolcam Outlet", ocfDeviceType: "oic.d.smartplug" //NEO Coolcam Power plug
		fingerprint mfr: "010F", prod: "0602", model: "1001", deviceJoinName: "Fibaro Outlet", ocfDeviceType: "oic.d.smartplug" // EU //Fibaro Wall Plug ZW5
		fingerprint mfr: "010F", prod: "1801", model: "1000", deviceJoinName: "Fibaro Outlet", ocfDeviceType: "oic.d.smartplug"// UK //Fibaro Wall Plug ZW5
		fingerprint mfr: "0086", prod: "0003", model: "004E", deviceJoinName: "Aeotec Switch" //EU //Aeotec Heavy Duty Smart Switch
		fingerprint mfr: "0086", prod: "0103", model: "004E", deviceJoinName: "Aeotec Switch" //US //Aeotec Heavy Duty Smart Switch
		//zw:L type:1001 mfr:0258 prod:0003 model:1087 ver:3.94 zwv:4.05 lib:03 cc:5E,72,86,85,59,5A,73,70,25,27,71,32,20 role:05 ff:8700 ui:8700
		fingerprint mfr: "0258", prod: "0003", model: "1087", deviceJoinName: "NEO Coolcam Outlet", ocfDeviceType: "oic.d.smartplug"  //EU //NEO Coolcam Power Plug
		fingerprint mfr: "027A", prod: "0101", model: "000D", deviceJoinName: "Zooz Switch" //Zooz Power Switch
		fingerprint mfr: "0159", prod: "0002", model: "0054", deviceJoinName: "Qubino Outlet", ocfDeviceType: "oic.d.smartplug" //Qubino Smart Plug
		fingerprint mfr: "0371", prod: "0003", model: "00AF", deviceJoinName: "Aeotec Outlet", ocfDeviceType: "oic.d.smartplug"  //EU //Aeotec Smart Switch 7
		fingerprint mfr: "0371", prod: "0103", model: "00AF", deviceJoinName: "Aeotec Outlet", ocfDeviceType: "oic.d.smartplug"  //US //Aeotec Smart Switch 7
		fingerprint mfr: "0060", prod: "0004", model: "000B", deviceJoinName: "Everspring Outlet", ocfDeviceType: "oic.d.smartplug"  //US //Everspring Smart Plug
		fingerprint mfr: "031E", prod: "0002", model: "0001", deviceJoinName: "Inovelli Switch" //US //Inovelli Switch Red Series
		fingerprint mfr: "0154", prod: "0003", model: "000A", deviceJoinName: "POPP Outlet", ocfDeviceType: "oic.d.smartplug" //EU //POPP Smart Outdoor Plug
		fingerprint mfr: "010F", prod: "1F01", model: "1000", deviceJoinName: "Fibaro Outlet", ocfDeviceType: "oic.d.smartplug" //EU //Fibaro walli Outlet //Fibaro Outlet
	// simulator metadata
	simulator {
		status "on":  "command: 2003, payload: FF"
		status "off": "command: 2003, payload: 00"
		for (int i = 0; i <= 10000; i += 1000) {
			status "power  ${i} W": new hubitat.zwave.Zwave().meterV1.meterReport(
				scaledMeterValue: i, precision: 3, meterType: 4, scale: 2, size: 4).incomingMessage()
		for (int i = 0; i <= 100; i += 10) {
			status "energy	${i} kWh": new hubitat.zwave.Zwave().meterV1.meterReport(
				scaledMeterValue: i, precision: 3, meterType: 0, scale: 0, size: 4).incomingMessage()
		// reply messages
		reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
		reply "200100,delay 100,2502": "command: 2503, payload: 00"
	// tile definitions
	tiles(scale: 2) {
		multiAttributeTile(name:"switch", type: "generic", width: 6, height: 4, canChangeIcon: true){
			tileAttribute("device.switch", key: "PRIMARY_CONTROL") {
				attributeState("on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#00A0DC", nextState:"turningOff")
				attributeState("off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff", nextState:"turningOn")
				attributeState("turningOn", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc", nextState:"turningOff")
				attributeState("turningOff", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn")
		valueTile("power", "device.power", width: 2, height: 2) {
			state "default", label:'${currentValue} W'
		valueTile("energy", "device.energy", width: 2, height: 2) {
			state "default", label:'${currentValue} kWh'
		standardTile("reset", "device.energy", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "default", label:'reset kWh', action:"reset"
		standardTile("refresh", "device.power", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
		main(["switch","power","energy"])
		details(["switch","power","energy","refresh","reset"])
def installed() {
	log.debug "installed()"
	// Device-Watch simply pings if no device events received for 32min(checkInterval)
	initialize()
	if (zwaveInfo?.mfr?.equals("0063") || zwaveInfo?.mfr?.equals("014F")) { // These old GE devices have to be polled. GoControl Plug refresh status every 15 min.
		runEvery15Minutes("poll", [forceForLocallyExecuting: true])
def updated() {
	initialize()
		unschedule("poll", [forceForLocallyExecuting: true])
	try {
		if (!state.MSR) {
			response(zwave.manufacturerSpecificV2.manufacturerSpecificGet().format())
	} catch (e) {
		log.debug e
def initialize() {
	sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
def getCommandClassVersions() {
		0x20: 1,  // Basic
		0x32: 3,  // Meter
		0x56: 1,  // Crc16Encap
		0x70: 1,  // Configuration
		0x72: 2,  // ManufacturerSpecific
// parse events into attributes
	log.debug "parse() - description: "+description
	def result = null
	if (description != "updated") {
		def cmd = zwave.parse(description, commandClassVersions)
		if (cmd) {
			result = zwaveEvent(cmd)
			log.debug("'$description' parsed to $result")
		} else {
			log.debug("Couldn't zwave.parse '$description'")
	result
def handleMeterReport(cmd){
	if (cmd.meterType == 1) {
		if (cmd.scale == 0) {
			createEvent(name: "energy", value: cmd.scaledMeterValue, unit: "kWh")
		} else if (cmd.scale == 1) {
			createEvent(name: "energy", value: cmd.scaledMeterValue, unit: "kVAh")
		} else if (cmd.scale == 2) {
			createEvent(name: "power", value: Math.round(cmd.scaledMeterValue), unit: "W")
def zwaveEvent(hubitat.zwave.commands.meterv3.MeterReport cmd) {
	log.debug "v3 Meter report: "+cmd
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd)
	log.debug "Basic report: "+cmd
	def value = (cmd.value ? "on" : "off")
	def evt = createEvent(name: "switch", value: value, type: "physical", descriptionText: "$device.displayName was turned $value")
	if (evt.isStateChange) {
		[evt, response(["delay 3000", meterGet(scale: 2).format()])]
	} else {
		evt
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
	log.debug "Switch binary report: "+cmd
	createEvent(name: "switch", value: value, type: "digital", descriptionText: "$device.displayName was turned $value")
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
	def result = []
	def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
	log.debug "msr: $msr"
	updateDataValue("MSR", msr)
	result << createEvent(descriptionText: "$device.displayName MSR: $msr", isStateChange: false)
def zwaveEvent(hubitat.zwave.Command cmd) {
	log.debug "${device.displayName}: Unhandled: $cmd"
def on() {
	encapSequence([
		zwave.basicV1.basicSet(value: 0xFF),
		zwave.switchBinaryV1.switchBinaryGet(),
		meterGet(scale: 2)
	], 3000)
def off() {
	encapSequence([
		zwave.basicV1.basicSet(value: 0x00),
		meterGet(scale: 2)
	], 3000)
 * PING is used by Device-Watch in attempt to reach the Device
def ping() {
	log.debug "ping()"
	refresh()
def poll() {
	sendHubCommand(refresh())
def refresh() {
	log.debug "refresh()"
	encapSequence([
		meterGet(scale: 0),
		meterGet(scale: 2)
def configure() {
	log.debug "configure()"
	def result = []
	log.debug "Configure zwaveInfo: "+zwaveInfo
	if (zwaveInfo.mfr == "0086") {	// Aeon Labs meter
		result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 80, size: 1, scaledConfigurationValue: 2)))	// basic report cc
		result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 12)))	// report power in watts
		result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 300)))	 // every 5 min
	} else if (zwaveInfo.mfr == "010F" && zwaveInfo.prod == "1801" && zwaveInfo.model == "1000") { // Fibaro Wall Plug UK
		result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 11, size: 1, scaledConfigurationValue: 2))) // 2% power change results in report
		result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 13, size: 2, scaledConfigurationValue: 5*60))) // report every 5 minutes
	} else if (zwaveInfo.mfr == "014F" && zwaveInfo.prod == "5053" && zwaveInfo.model == "3531") {
		result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 13, size: 2, scaledConfigurationValue: 15))) //report kWH every 15 min
	} else if (zwaveInfo.mfr == "0154" && zwaveInfo.prod == "0003" && zwaveInfo.model == "000A") {
		result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 25, size: 1, scaledConfigurationValue: 1))) //report every 1W change
	result << response(encap(meterGet(scale: 0)))
	result << response(encap(meterGet(scale: 2)))
	result
def reset() {
	encapSequence([
		meterReset(),
		meterGet(scale: 0)
def meterGet(map)
	return zwave.meterV2.meterGet(map)
def meterReset()
	return zwave.meterV2.meterReset()
 * Security encapsulation support:
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
	def encapsulatedCommand = cmd.encapsulatedCommand(commandClassVersions)
	if (encapsulatedCommand) {
		log.debug "Parsed SecurityMessageEncapsulation into: ${encapsulatedCommand}"
		zwaveEvent(encapsulatedCommand)
	} else {
		log.warn "Unable to extract Secure command from $cmd"
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
	def version = commandClassVersions[cmd.commandClass as Integer]
	def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
	def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
		log.debug "Parsed Crc16Encap into: ${encapsulatedCommand}"
	} else {
		log.warn "Unable to extract CRC16 command from $cmd"
private secEncap(hubitat.zwave.Command cmd) {
	log.debug "encapsulating command using Secure Encapsulation, command: $cmd"
	zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
private crcEncap(hubitat.zwave.Command cmd) {
	log.debug "encapsulating command using CRC16 Encapsulation, command: $cmd"
	zwave.crc16EncapV1.crc16Encap().encapsulate(cmd).format()
private encap(hubitat.zwave.Command cmd) {
	if (zwaveInfo?.zw?.contains("s")) {
		secEncap(cmd)
	} else if (zwaveInfo?.cc?.contains("56")){
		crcEncap(cmd)
	} else {
		log.debug "no encapsulation supported for command: $cmd"
		cmd.format()
private encapSequence(cmds, Integer delay=250) {
	delayBetween(cmds.collect{ encap(it) }, delay)
I've a TKB and some Delevco's (re-badged) and using a simlar driver to yours. Works very well. They are great budget UK z-wave metering plugs. Shame they are not that easy to hold of, without going oversea's.
No idea for no. 1 personally, but believe from other posts that you can set inclusion to not use secure join, if you want.
For no. 2 the contact sensors do work. I have 4 fibaro contact sensors. 2 of the old version, 2 of the newer. Not sure which way round they are but two work on the fibaro driver and two work as a generic z wave contact sensor. None of them were easy to pair but persevere and they will work.
For no. 3 I have 4 devolo outputs that look the same as the tkb ones. 2 are joined as fibaro outputs and 2 are joined as aeon outputs, all of which report power, so you may be able to switch to a built in driver if you wanted, it's trial and error.
  1. Has been resolved here: Secondary Controller using Z-Wave - PC controller
  2. Depends on the FW in the contact sensor. the originals don't seem to work. Door/Windows sensors with an FGK-10x product number on the label seem to work with a driver available in the forum.
  3. Noted. Thanks!
Welcome to the other side @brumster, I have recently moved over to hubitat too and have spent the last two months dismantling my large smartthings installation. I remember you from years back when I worked on orvibo and xiaomi sensors. I don't think you'll regret it, things just seem to work so much faster and more consistently on this platform.
hah! Good to speak again! Loving it, fast, reliable, config is easier from a browser, built in dashboard and for the stuff I can't get simply working with Rule Machine (not a lot) there's WebCore. The only thing I've really missed is the ability to load a slow phone app and be presented with a long list that of devices that I can fairly quickly change the state of....... seriously, that's it. Everything else is better. Device support is amazing. And I still have those Orvibo/Xiaomi sensors working that we had some pain with, their interrogation was simple and the Orvibo stuff works natively!
In short I'm well happy. Wish I'd have done it sooner!
Good to see you @a4refillpad
BTW if you use my original orvibo ST device handler you'll get battery levels reporting correctly.
Thanks for #3 @brumster I'll try it. I have a TKB TZ69E and currently been using the Aeotec Smart Switch 6 driver which at least did report power properly unlike generic Z-wave.
Edit: working thanks! If you plan to update it, a nice feature in the Aeotec driver is %/absolute threshold reporting for the power usage to cut down data flow.
It's not mine :slight_smile: it's a lift of the DTH from SmartThings :slight_smile:
I have it working with a TZ69 as well. :+1:
