Hi all, I have some questions about adding z-wave to my system. First a quick overview of my current architecture:
- Hubitat C7 (I also have a C5, not currently online)
- Lutron Caseta (pro hub) with >20 switches and picos.
- Philips Hue hub with ~35 bulbs
- A few other miscellaneous integrations (Withings, SleepNumber, Ecobee etc.)
- Happy and responsive Zigbee mesh with at least one Ikea outlet or repeater in every room/zone. (I have immediate response all the way to my property lines.)
- Now planning to install door/window and multi-sensors throughout, but no devices currently online
- Long-term plans include irrigation, cameras, Plex/AppleTV/Sonos integrations
- Actively avoiding all voice-control. If I ever have to have it, will be using HomeKit/Siri.
I had been avoiding Z-wave, but had trouble finding a dimmable Zigbee outlet with a three-prong plug (needed for outdoor string lights). I'm also trying to stay Ikea-only for my Zigbee repeaters since they were cheap and apparently best-practice if I ended up with some of the cheaper/flakier sensors, e.g., Xiaomi, Aqara.
I picked up one experimental Z-wave device (Ministon Energy Monitoring Plug MP21ZP) that paired without issue and responds as quickly as my Zigbee outlets. I have ordered two more Ministons (dimmable 3-prong outlets) for the string lights. If needed, I'll be installing in-wall Z-wave outlets to build out a mesh.
Since I was firing up Z-wave anyway, it opened up the better options for multi-sensors, and I've got a Zooz 4-in-1 arriving today for testing, but just found the "doesn't work with the C7" issues while reading posts yesterday.
I see my options as:
- Abandon Z-wave except for the above-mentioned plugs
- Return the Zooz and find different Z-wave multi-sensors
- Fire up the C5 and pair the Zooz with it, then use hub-mesh to integrate
I would already have gone with Zigbee for the multi-sensors, but they aren't as "multi" and I'm trying to avoid have a gajillion things on the walls and ceiling (SAF).
At this point, I'm figuring that I have the C5, so why not use it? The Zooz does everything I need for my general sensor net and I can add specialty things as needed.
So at long last, here are my specific questions:
- Is there a performance penalty to using hub-mesh if I fire up the C5?
- If no, would I continue to write all of my rules/apps on the C7 and just use the C5 as a device handler, or is there an advantage to offloading some things to the C5? I'm not currently having performance problems with the C7.
- Is there any advantage to putting all Z-wave on the C5?
- If I do use the C5 for all Zooz/Z-wave, and later add 700-series devices to the C7, will I then have two Z-wave meshes? If so, will that cause problems?
Sorry for the lengthy post and multiple questions, but I haven't spent much money on sensors yet. I want to make smart architecture choices before I head down any particular path, and would love some expert opinions!
UPDATE: Right after I submitted this post, my delivery showed up - apparently I already decided to get Z-wave in-wall outlets (Leviton ZW15R). So that brings up a final question: It turns out that this model is 700 series.
5. Will I later need to build out a 700-series mesh, or will older repeaters support the newer devices without an issue? More directly, should I send these back and wait for 700-series in-wall outlets?)
