Z-Wave "locked up" and required full power cycle (C8, 2.4.0.150)
Devices stopped working in our house and upon inspection, our C8 (running 2.4.0.150) seemed to have had its Z-Wave subsystem "lock up".
When I logged into the web UI, I first noticed a "Last cloud backup failed. Failed steps: Z-Wave" notification (as well as a new platform avail - .151). When I tried to open the Z-Wave section of Settings, it was just a blank page (other than the header).
I went ahead and let it do the platform update, thinking that might work, but after rebooting on 2.4.0.151 I still was unable to use any devices, and Z-Wave was still completely dead.
I did a full power cycle (shutdown -> unplug -> wait -> replug) and everything seems ok once again.
I am just concerned this might happen while I'm not at home, and therefore unable to do anything about it.
Is this a known (recurring?) problem?
Can the firmware be updated to allow a full hard-power-cycle on the Z-Wave interface via software in case this happens again or in a situation where the hub is not easily physically reachable? I understand the desire to keep the Z-Wave subsystem "alive" during reboots to make things faster, but I feel it would be beneficial to be able to power cycle it via software in the cases like this.
Thanks!
I think the only real solution to this is to use a wifi plug on the Hubitat hub itself. After shutting it down, you would need to go into the app for the wifi plug on your phone and turn the power off for 30 seconds, then turn it back on.
For a full automation of this, it would need a routine in Alexa or Google that has the wifi switch connected. The Alexa/Google routine would first tell Hubitat to shutdown, by changing the state of a virtual switch, then it would wait for a bit, and then turn off the power to the hub, then wait 30s, and then turn the power back on. On Hubitat, when the virtual switch is flipped by Alexa/Google, then have it do the hub shutdown in a rule.
just had the same issue w .151. seems like an update broke the zwave functionality. Firmware update doesnt do anything either, stuck
Yeah, I mean, I know hacky ways to "work around" this, but:
  1. This shouldn't be happening, so I assume there is a bug somewhere, perhaps in the Z-Wave firmware?
  2. There really should be a way to actually hard-power-cycle the Z-Wave subsystem to be able to resolve these sorts of issues remotely and without needing to use some additional 3rd party device to do a hard power cycle.
I'm unsure if there is any debugging info or troubleshooting steps I can take if I see this happen again - thus my post here in case someone from Hubitat can chime in :slight_smile:
That only should do something IF you have a C7, and IF you didn't already apply the one update that was available well over a couple years ago.
Well not really. I have a c8. it happened to me where the zwave system was not loading like i showed in my screen shot. i had to turn off, power cycle and while the upgrade zwave was showing prepower cycle, it is gone now. Will see of it happens again but that was not on c7.
Since it is doing a full power off at the source, I'm not sure how the hub could ever turn itself back on. I think this would require an actual hardware change on a new hub design to keep some component powered while everything else on the hub gets powered down internally by that component, so that it can turn it back on.
I agree, the need for the work-around shouldn't be needed, as Zwave should just stay working. "What broke my Zwave" is a very common topic here, I even have a post out there from when my Zwave was locking up, but I found the devices that were causing the problem and I got it fixed by replacing them. There seems to be just too many reason why ZWave can go down, though.
What I mean is, when the hardware (the entire Hubitat device) is/was being designed, there should have been some thought put into "what if this 3rd-party component locks up". Meaning - some sort of ability to "power cycle" that without needing to physically unplug and re-plug the device.
You could likely use a MOSFET (or other transistor) or even a tiny DIP relay to do this sort of thing.
Perhaps this can be considered for the C9 (or whatever)? :slight_smile:
That said, I don't know what vendor Hubitat is using for its onboard Z-Wave controller - but they should consider reaching out to the vendor to see what they recommend in order to "power cycle" that component without having to hard power cycle the entire device. Point is: I'm sure there is a Vcc input that can be cycled on the Z-Wave section of circuitry to at least do this.
Probably not something that can be retro-fitted to existing hardware, since it seems like that was not part of the hardware design.
This current situation just really sucks for any remote deployments or other situations where hard-cycling the power is difficult.
Sigh, this just happened again. I'm on 2.4.0.151 now/still.
I noticed some automations didn't seem to be running, and I was unable to control devices from the app.
The latest "last message" is 2:15am last night.
Looking at the "past logs", the last Z-Wave related message is around that time, too.
(2:15am is when the Scheduled backups run -- did this cause some problem?)
Before rebooting, the "Z-Wave" page would open and show things just fine (seemingly).
I did a "warm reboot" and now the "Z-Wave" page is now blank and still nothing works.
Doing a full cold-boot (power cycle) has restored things to operational once again.
I have a rule to catch "Z-Wave crashed", but that didn't trigger, since I didn't get an email, so I'm not sure how to detect this automatically otherwise.
This is not sustainable, and it's really frustrating. This sort of thing needs to be much more reliable; it should have its own hardware watchdog that runs, if nothing else.
Are there any debug logs or anything I can send to Hubitat to help diagnose?
For now while this issue is affecting you, turn off automated Cloud backups. You really only need to take a cloud backup if you've added or removed devices, something which generally isn't happening very often.
Take a cloud backup if you remove or add new devices. Schedule Local backups every couple days (or daily if you're making significant automation or settings changes frequently).
HE staff are working on issues like these in the current platform beta.
Oh - are cloud backups causing this, then? Good to know.
Thanks, I'll try to remember to take manual cloud backups when I change things (which isn't too often, but sometimes).
Yeah I made that same request in another thread. In the day job, we do this on all hardware modules , especially the radios in products; always have a way to bounce them and reset them independent of the main SoC.
I'm also a bit frustrated that the "Location -> zwaveCrashed" rule I have didn't trigger. This seems extra-bad, since it clearly did crash - or at least lock up.
At the absolute very least, there needs to at least be a way to "find out" when this sort of thing happens, without just suddenly realizing nothing is working.
That said, this "locking up / crashing" is something new to my device in the last few months... never had an issue like this before, even with cloud backups on since forever.
Exactly how does that work? It doesn't depend on Z-wave, does it? :slight_smile:
For myself, I haven't found a way to send an e-mail notification. Pushover, yes.
While it hasn't happened to me in quite a while, I still back up only once a week, or manually if the mood strikes, and at a time when I'll be home to observe and correct. As opposed to getting up in the middle of the night or morning or whatever and nothing works. It might put a little pause in rule actuations, but I haven't seen a problem with it.
