Z-Wave JS and "Qubino 2 Relay Module" driver
Hello,
I would like to report a possible compatibility issue between Z-Wave JS
and the built-in "Qubino 2 Relay Module" driver.
Symptoms:
After switching from legacy Z-Wave to Z-Wave JS, an On command
physically turns the connected light on, but the corresponding child
device state changes back to Off almost immediately.
The light remains physically on.
Running Refresh restores the correct On state.
An Off command physically turns the light off correctly.
Example from the child device Events:
17:35:13.678 — command-on, source: Computer view
17:35:13.965 — switch on, type: physical
17:35:14.221 — switch off, type: digital
17:35:14.223 — switch off, type: digital
Can you turn on debug logging and trigger it again? .. Then paste the logs here..
Me too.
I just installed a Qubino Flush 2 Relay on a C8 Pro, running 2.5.3.111.
There seems to be some sort of an issue - when I manually (from the device page) try and turn the parent on (or off) it just isn't responsive. However, on a child device, if it's off and then I try and turn it on, it seems to cycle (or flash) between on and off.
Something strange is going on.
I've attached the logs
