I've been struggling with 2 of the 3 Inovelli Red Dimmers I bought. My goal was to upgrade the firmware and it's just been a brutal process. The first one was easy peasy. The other two are being a pain.
Issue w/ Dimmer 1
I had to force remove the dimmer from my Hub. I attempted to include it after factory resetting the switch, the dimmer was found and I unchecked S2 so I could upgrade the firmware (the firmware update keeps failing while using S2). Anyway, the device never finished adding itself and the inclusion timed out.
Issue w/ Dimmer 2
Everything about this one was looking good. I excluded it, factory reset the switch, included it without S2, upgraded the firmware, excluded it again, and then factory reset it. Now it's not letting me include the dimmer.
If I go into my Z-Wave devices I see some nodes that are blank (see below).
Any ideas?
