Hello there,
Hoping to get some ideas to resolve the numerous issues I'm having with my zwave network and hubitat. I have a c5 which I bought in Dec 2019, the first 6 months or so everything worked beautifully minimal delay processing commands and all devices were responsive and checking in regularly. But slowly over the last 3 months or so devices have fallen off the network or fail to send updates to the hub at all, I've rebuilt the network, added more powered switches/repeaters ran network repairs nothing improves.
Infrastructure explanation:
1400sqf house
5 x Inovelli LZW30-SN all switches are with 25ft over each other and no more than 1 interior wall between each neighbor switch.
8 x Inovelli LZW42 Color Bulbs
1 x Honeywell T6 Pro Z-Wave Thermastat
2 x Schlage BE468 deadbolts
5 x HomeSeer HS-DS100+ Z-Wave Door / Window Sensor
4 x Inovelli LZW60 Multi Sensor
2 x First Alert ZCOMBO
Mains powered devices such as switches generally have no issues, bulbs work but commands can sometimes be delayed 15-20seconds. Sometimes bulb commands have to be resent due to failure to process.
Battery powered devices by and large don't work, I can typically send commands such as set point to the thermastat and the device will apply it. But the thermastat never updates the hub with temp/humidity/fan/running status.
Door/windows sensors just no longer send updates.
Smoke alarms fail to send their weekly battery %.
Door locks are stuck "unlocked" and won't send commands back to the hub.
Multi-sensor will periodically send temp reports but nothing else(1-3 times a day).
I've exclude and re-included basically every device, I've moved the hub closer to the devices I'd be testing with(such as the thermostat or locks) and that device will start responding after some arbitrary time frame(1-3 days). But then other devices will just completely drop off/stop responding.
I've updated the FW of all my switches to latest beta(think it's Stable now) and bulbs. With no improvements.
At this point I'm kinda at the end of my rope, I've invested too much money and more importantly time into this project. Maybe this community will have some off the wall ideas I could try before I give it up and try a hub from a different manufacture(before just selling off this stuff and going back to dumb infra).
Thanks,
