@bcopeland is it or will it be possible to update the firmware of a LR device while in LR mode? The app only shows mesh devices currently.
Also using JS
Also using JS
I've been able to update devices paired LR (and mesh), but the built-in updater can be very finicky in any/all cases.
I had the updater app recently not list the desired target device for some reason... IIRC, I just kept cycling through the "remove fw file / remove updater app / reboot HE / install app / load fw file / attempt update" process until it finally worked.
I've been on JS since its beta, FWIW.
I also don't have any LR choices with the built in app, only mesh.
I am on latest Z-Wave stuff.
edit: If I recall, I think the workaround used to be to switch the device to mesh, update firmware, and then switch back to LR. I don't know if this still works, if indeed I remember correctly.
Since LR is here to stay, this should be fixed.
They have LR devices on the UK, now?!!
No its on a american site.
