Hi all, any tips appreciated. GE Enbrighten Dual Outlet not responding. Able to add to hub and automatically adds as type "Device". I change to type Jasco Z-wave Dual Outlet. Eventually shows two child devices, Dimmer-1 and Dimmer-2. However I am unable to turn on/turn off, change level on either outlet. Have excluded, done factor reset, included a few times now. No change. Looking in logs, shows the commands I am giving directly via the device page, Able to turn the device off/on manually at the actual outlet. Device was working fine on Smartthings before I migrated over. Hub updated. Everything else working ok.
@joelreedbaskin_hubit Yes, I have the same issue here. If I change the type to Generic Z-Wave Plus Outlet or Generic Z-Wave Outlet, it works just for just controlling both of the two switches together. Switch 1 and Switch 2 (child devices) can not work separately. That might be the driver issue of Jasco Z-wave Dual Outlet. Anyone else has some comments on this?
The smart switch contains two grounded Z-Wave-controlled outlets allowing remote operation of two devices at the same time (cannot be controlled individually).
So I would say that you can't operate these individually.
I just bought a couple of these (55249) and ran into this issue. I has to be a bug in the driver, as it configures a single-switch device as a two-switch device. I've contacted Hubitat support to see about getting this fixed.
Also confirm this is a bug, I use the generic zwave outlet driver and it works fine (on off both outlets). The Jasco driver doesn't do much / no events reported either.
Device was previously on Abode controller and individual control of switches worked fine.
I've got the same issue with my dual outlet and my Data section looks identical to @jbondc above, except mine has S2 security setup. Checking to see if there's any updates on this. Thanks!
