Z-wave devices
Have 2 devices that I have tried to add that didn't discovery correctly:
  1. ACT/HomePro ZRW113 isolated relay switch - This just showed up as "Device". Nothing else on it. Manual for it https://www.smarthome-products.com/productspecs/ZRW113-S200.pdf.
  2. Inovelli NZW37 (no scene) (has the logo on it) - This got detected as a Zooz power strip.
    Data: deviceType: 45601
    inClusters: 0x5E,0x85,0x59,0x5A,0x72,0x60,0x8E,0x73,0x27,0x25,0x86
    firmwareVersion: 20.17
    deviceId: 9500
    manufacturer: 786
If there is another way submit device information or if there is a z-wave database lookup, please let me know.
Thanks,
Roy
Goto the Device Detail page for each device. About 1/2 way down there will be an option for Device Type. Change that to match your device. Many devices will be "Generic". For example, a Z-Wave switch should be changed to "Generic Z-Wave Switch".
The ZRW113 works after changing to Generic Z-Wave switch.
Anyone got an idea on the Inovelli dual plug?
https://github.com/InovelliUSA/Hubitat/blob/master/Drivers/inovelli-2-channel-smart-plug-nzw37.src/inovelli-2-channel-smart-plug-nzw37.groovy
Install the driver from Inovelli’s GitHub and go through the discovery process, which unfortunately I’ve forgotten. You should get parent device with two child devices, one for each channel.
