I would defer to anything BobbD suggests but...
You might try safely shutting down your hub, removing power for 30 seconds (try not to use the connector on the hub but rather disconnect at the power source), and then restarting.
Shutdown the hub from the settings menu. Unplug for 5 mins (at the wall not the hub). Power back up. Wait a day or so.
Well, patience and walking away paid off.
After a restart, hings rerouted and most found their way back to the hub.
To be fair, one of the Jasco/Ge outlet devices was moved. But I also moved two "Mobile" outlets closer to final locations and they did indeed find their way home again.
I may be able to build a dashboard soon!
Have you updated to the latest z-wave stack?
Yes. I did the firmware and Z-wave update.
The two new Ring Extenders V2 seem to be smoothing things out.
