So I've been trying to figure out why z-wave has issues with hubitat.
Here is a log of just 2 devices being turned off via the alexa skill. They are Honeywell Z-wave Plus Switches. Is this verbosity expected? The Craft Room Light reports itself on 40 time. is this why the z-wave stops working on hubitat? And its not just the craft room light.
dev:972019-07-10 01:20:06.764 am infoCraft Room Alcove is on [physical]
dev:972019-07-10 01:20:06.758 am infoBasicReport value: 255
dev:972019-07-10 01:20:06.755 am debugparse description: zw device: 16, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:06.446 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:06.440 am infoBasicReport value: 255
dev:962019-07-10 01:20:06.436 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:06.311 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:06.305 am infoBasicReport value: 255
dev:962019-07-10 01:20:06.301 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:06.234 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:06.226 am infoBasicReport value: 255
dev:962019-07-10 01:20:06.223 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:06.162 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:06.159 am infoBasicReport value: 255
dev:962019-07-10 01:20:06.143 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:06.072 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:06.068 am infoBasicReport value: 255
dev:962019-07-10 01:20:06.053 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:06.033 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:06.026 am infoBasicReport value: 255
dev:962019-07-10 01:20:06.023 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:05.997 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:05.990 am infoBasicReport value: 255
dev:962019-07-10 01:20:05.987 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:05.857 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:05.850 am infoBasicReport value: 255
dev:962019-07-10 01:20:05.846 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:05.811 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:05.804 am infoBasicReport value: 255
dev:962019-07-10 01:20:05.801 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:05.731 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:05.725 am infoBasicReport value: 255
dev:962019-07-10 01:20:05.721 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:05.403 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:05.392 am infoBasicReport value: 255
dev:962019-07-10 01:20:05.385 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:972019-07-10 01:20:05.337 am infoCraft Room Alcove is on [physical]
dev:972019-07-10 01:20:05.329 am infoBasicReport value: 255
dev:972019-07-10 01:20:05.325 am infoCraft Room Alcove is on [physical]
dev:972019-07-10 01:20:05.316 am debugparse description: zw device: 16, command: 2003, payload: FF , isMulticast: false
dev:972019-07-10 01:20:05.300 am infoBasicReport value: 255
dev:972019-07-10 01:20:05.293 am debugparse description: zw device: 16, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:05.289 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:05.273 am infoBasicReport value: 255
dev:972019-07-10 01:20:05.263 am infoCraft Room Alcove is on [physical]
dev:962019-07-10 01:20:05.259 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:972019-07-10 01:20:05.254 am infoBasicReport value: 255
dev:972019-07-10 01:20:05.245 am debugparse description: zw device: 16, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:05.239 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:05.232 am infoBasicReport value: 255
dev:962019-07-10 01:20:05.228 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:972019-07-10 01:20:05.177 am infoCraft Room Alcove is on [physical]
dev:972019-07-10 01:20:05.171 am infoBasicReport value: 255
dev:972019-07-10 01:20:05.168 am debugparse description: zw device: 16, command: 2003, payload: FF , isMulticast: false
dev:972019-07-10 01:20:04.850 am infoCraft Room Alcove is on [physical]
dev:972019-07-10 01:20:04.844 am infoBasicReport value: 255
dev:972019-07-10 01:20:04.840 am debugparse description: zw device: 16, command: 2003, payload: FF , isMulticast: false
dev:972019-07-10 01:20:04.820 am infoCraft Room Alcove is on [physical]
dev:972019-07-10 01:20:04.814 am infoBasicReport value: 255
dev:972019-07-10 01:20:04.811 am debugparse description: zw device: 16, command: 2003, payload: FF , isMulticast: false
dev:972019-07-10 01:20:04.788 am infoCraft Room Alcove is on [physical]
dev:972019-07-10 01:20:04.781 am infoBasicReport value: 255
dev:972019-07-10 01:20:04.776 am debugparse description: zw device: 16, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:04.345 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:04.338 am infoBasicReport value: 255
dev:962019-07-10 01:20:04.333 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:03.980 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:03.974 am infoBasicReport value: 255
dev:962019-07-10 01:20:03.970 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:03.600 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:03.594 am infoBasicReport value: 255
dev:962019-07-10 01:20:03.590 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:03.309 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:03.303 am infoBasicReport value: 255
dev:962019-07-10 01:20:03.297 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:03.212 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:03.206 am infoBasicReport value: 255
dev:962019-07-10 01:20:03.203 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:03.114 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:03.108 am infoBasicReport value: 255
dev:962019-07-10 01:20:03.104 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:972019-07-10 01:20:02.995 am infoCraft Room Alcove is on [physical]
dev:972019-07-10 01:20:02.988 am infoBasicReport value: 255
dev:972019-07-10 01:20:02.981 am debugparse description: zw device: 16, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:02.877 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:02.872 am infoBasicReport value: 255
dev:962019-07-10 01:20:02.868 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:972019-07-10 01:20:02.815 am infoCraft Room Alcove is on [physical]
dev:972019-07-10 01:20:02.808 am infoBasicReport value: 255
dev:972019-07-10 01:20:02.805 am debugparse description: zw device: 16, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:02.784 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:02.778 am infoBasicReport value: 255
dev:962019-07-10 01:20:02.774 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:02.740 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:02.734 am infoBasicReport value: 255
dev:962019-07-10 01:20:02.730 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:972019-07-10 01:20:02.635 am infoCraft Room Alcove is on [physical]
dev:972019-07-10 01:20:02.627 am infoBasicReport value: 255
dev:972019-07-10 01:20:02.623 am debugparse description: zw device: 16, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:02.097 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:02.091 am infoBasicReport value: 255
dev:962019-07-10 01:20:02.087 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:01.845 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:01.839 am infoBasicReport value: 255
dev:962019-07-10 01:20:01.835 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:01.805 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:01.798 am infoBasicReport value: 255
dev:962019-07-10 01:20:01.792 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:01.769 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:01.763 am infoBasicReport value: 255
dev:962019-07-10 01:20:01.759 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:01.563 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:01.557 am infoBasicReport value: 255
dev:962019-07-10 01:20:01.553 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:01.235 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:01.229 am infoBasicReport value: 255
dev:962019-07-10 01:20:01.225 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:972019-07-10 01:20:00.683 am infoCraft Room Alcove is on [physical]
dev:972019-07-10 01:20:00.675 am infoBasicReport value: 255
dev:972019-07-10 01:20:00.671 am debugparse description: zw device: 16, command: 2003, payload: FF , isMulticast: false
dev:972019-07-10 01:20:00.530 am infoCraft Room Alcove was turned on[digital]
dev:972019-07-10 01:20:00.522 am infoBasicReport value: 255
dev:972019-07-10 01:20:00.518 am debugparse description: zw device: 16, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:00.214 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:00.208 am infoBasicReport value: 255
dev:962019-07-10 01:20:00.204 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:00.140 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:00.131 am infoBasicReport value: 255
dev:962019-07-10 01:20:00.126 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:20:00.075 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:20:00.066 am infoBasicReport value: 255
dev:962019-07-10 01:20:00.061 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:992019-07-10 01:19:59.782 am infoIron is off [physical]
dev:962019-07-10 01:19:59.141 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:19:59.136 am infoBasicReport value: 255
dev:962019-07-10 01:19:59.131 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:19:59.072 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:19:59.064 am infoBasicReport value: 255
dev:962019-07-10 01:19:59.060 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:19:58.706 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:19:58.699 am infoBasicReport value: 255
dev:962019-07-10 01:19:58.696 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:19:58.528 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:19:58.521 am infoBasicReport value: 255
dev:962019-07-10 01:19:58.518 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:19:58.190 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:19:58.181 am infoBasicReport value: 255
dev:962019-07-10 01:19:58.176 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
dev:962019-07-10 01:19:57.678 am infoCraft Room Light is on [physical]
dev:962019-07-10 01:19:57.670 am infoBasicReport value: 255
dev:962019-07-10 01:19:57.667 am debugparse description: zw device: 15, command: 2003, payload: FF , isMulticast: false
