Z-Wave devices are not accessible after power outage related restart
Hubitat C7 hub. I have 2 Ring contact sensors and 4 Zooz water leak sensors paired to the hub. I use home assistant for automation using hubitat integration. After a recent power outage and restart of the hub, all 6 devices were showing up as unavailable on home assistant. Here are the steps I took to troubleshoot and nothing has worked so far.
  1. Reload home assistant hubitat integration. Reloads fine but device status is still unavailable.
  2. On Hubitat hub, devices seems to be paired. Z-wave details page shows checkmark next to all devices and at least battery status is getting updated regularly per logs.
  3. Using Maker API end-points, get device is working fine however, send device command returns "Device not found or not authorized to send that command"
  4. Restarted hubitat hub
  5. Rebuilt z-wave network
    None of these has worked so far. INow the only option to try is to re-pair all the devices. Before I go that route, I wanted to check
  6. If there are any other troubleshooting steps that I could perform?
  7. Is this expected behavior after a unplanned hub restart?
  8. Is this something specific to devices?
    This will help me create mitigation plan for future such incidents as I expand my home automation and security.
Thanks in advance and appreciate your help here.
Edit: Hub has the latest firmware. Maker API app is on latest version.
Did the hub lose power? Or did you shut it down gracefully during the power outage? If the hub lost power, I would start with reboot, with advanced options and select rebuild database.
You mentioned the restart, but did not mention if you did the reboot with rebuild option. It is possible that the database got corrupted if it lost power unexpectedly.
That might fix that.
Secondly, you mention maker API. Are you using the cloud endpoint or the local endpoint when you are testing? If testing with the cloud endpoint, try testing with the local (and make sure the IP address of the hub itself didn't change). If you don't have DHCP reservations on your hub, the address can change on the hub. The hubitat integration on HA uses the local address.
Just the two things I would start with.
Thanks for the reply. The hub lost power and restarted by itself. When I restarted the hub manually, I did not use rebuild database,
Hub has static IP (DHCP reservation). I am using local API endpoint with hub's IP.
I am wondering if the database was corrupt, would it still show the devices to be okay and actually logging?
I will try this rebuilding the database anyways and see if that helps.
Also, did you try directly controlling the devices directly from hubitat in the devices tab in the app or from a computer?
If they don't work from the devices tab, you might want to show logs of what is happening when you send commands from the devices tab.
So, the ring contact sensors are still not working in the sense not reporting when opened or closed. Zooz water leak sensors are updating the status wet/dry.
There isn't much in the logs (with debug mode enabled) for me at least to point to any issues.
2026-02-13 11:21:41.818 AM info
Room Window 1 battery is 100%
dev:412026-02-13 11:21:41.805 AM debug
Supervision Get - SessionID: 10, CC: 128, Command: 3
dev:412026-02-13 11:21:41.747 AM debug
parse:zw device: 09, command: 6C01, payload: 0A 05 80 03 64 00 00 , isMulticast: false
dev:412026-02-13 10:11:51.657 AM info
dev:412026-02-13 10:11:51.645 AM debug
Supervision Get - SessionID: 9, CC: 128, Command: 3
dev:412026-02-13 10:11:51.629 AM debug
parse:zw device: 09, command: 6C01, payload: 09 05 80 03 64 00 00 , isMulticast: false
dev:412026-02-13 09:02:01.818 AM info
dev:412026-02-13 09:02:01.806 AM debug
Supervision Get - SessionID: 8, CC: 128, Command: 3
dev:412026-02-13 09:02:01.791 AM debug
parse:zw device: 09, command: 6C01, payload: 08 05 80 03 64 00 00 , isMulticast: false
dev:412026-02-13 07:52:13.030 AM info
Room Window 1 tamper alert cover closed
dev:412026-02-13 07:52:13.026 AM debug
parse:zw device: 09, command: 7105, payload: 00 00 00 FF 07 00 01 03 , isMulticast: false
dev:412026-02-13 07:52:12.773 AM info
Room Window 1 contact became closed
dev:412026-02-13 07:52:12.713 AM debug
parse:zw device: 09, command: 7105, payload: 00 00 00 FF 07 00 01 02 , isMulticast: false
dev:412026-02-13 07:52:12.441 AM info
dev:412026-02-13 07:52:12.438 AM debug
parse:zw device: 09, command: 8003, payload: 64 00 00 , isMulticast: false
Screenshots are better than text. What happens when you click refresh on the device in the website or app? Anything?
Also, if these are all Zwave, a screenshot of the Zwave Details page (the table showing all the devices and their routing info) might help.
