It is no longer on this list, and even after selecting update in PC Controller and rebooting the HE hub, 0x19is still in the Z-Wave details list in the app.
Nothing I have read mentions how to remove a ghost node in the HE app when it is not in PC Controller.
Also make sure you are attempting to remove ID "25" in the PCS not "19" as it's in decimal on the device list in PCS not hex.. sorry I know it's probably very obvious but I thought I'd mention it just in case.
Thanks. I appreciate the info. I could do that, but it seems unnecessarily complicated for the z-wave folks to require a consumer to use such a complicated solution. It can't be that tough to build a solution that works on something as widely adopted as Macs, but these manufacturers just choose not to do it. I've run Parallels in the past, and it was a headache.
My system works well, and if I have a ghost node or two it's not going to be a huge deal. Going forward, I think I'll just keep building out the Lutron Caseta side of things. Simple and "just works" are my watchwords now. But I do appreciate the info, if not the unfortunate answer.
I have selected update on PC Controller, shut down then disconnected the hub from power for 10 minutes. When I select ‘Remove Failed’ I get an error message in PC Controller ‘remove failed node failed’ with a timestamp.
83 is not in the list of devices, but what HE states is 84 is actually a contact sensor on the front door, not a ‘SPECIFIC_TYPE_POWER_SWITCH_BINARY’
Well, it took them two years to even admit that there was a problem with the Z-Wave radio firmware. Z-Wave is a Silicon Labs captive creature. In my opinion, all (or almost all) of the C-7 Z-Wave issues are due to Silicon Labs firmware issues on the radio. Bryan Copeland (@bcopeland) has done a heroic job getting it to work as well as he has.
I would add to that list the very ironically named "Simplicity Studio" which is anything but simplistic. In fact I don't think they could have made it worse to use if they tried.
Is this coming from using the stick? One option may be to power down and unplug the hub for 5 mins and power it back up. Otherwise you should be able to mark them dead in the silabs software
