I have several Leviton Zwave+ switches I'd like to update the firmware for. So far I've done the following:
Bought Z-Flash utility
Connected my Nortek Zwave stick and added the right drivers.
Enabled the stick in zwave and added to hubitat, It currently shows up as "device". Is that right, or should it be detecting as a secondary controller?
When Z-Flash searches for devices it seems to find two of my other zwave switches but most of my devices including the Leviton switches it errors out with:
"Error getting version information for node 3, Send failed."
A few months ago, when I spoke with Leviton and asked for an update procedure, then sent me a loaner AeoTec ZStick, and a whole bunch of .exe files. There was a exe file for each zwave model that they had. The exe file brought up a slimmed down, customized version of PC Controller, and then found and updated all switches on the network that were that particular model.
If you want me to send you those exe files, please let me know.
Bryan's superb tool, utilizes an OTZ file for each device, as the source for upgraded firmware. I could not really separate out a OTZ file in what Leviton sent me, so I couldn't use it.
