Keep getting this error when trying to import driver from website url ? Any ideas why
Do you have a link to this driver ?
You don’t need a separate driver. It’s now been included in the most recent hub firmware release.
There is a list of compatible devices, and even previously, Yoolax roller shades appeared on it, but perhaps a new driver was needed for their blinds.
Regardless, make sure your hub’s firmware is up to date, and then I’d suggest removing and re-pairing the blinds.
I tried is installing this driver and it won’t control shades when I press close or open is there a step I am missing ?
You might be missing a step, it's hard to tell.
Please confirm that you have updated the hub's firmware.
And also confirm you are no longer attempting to install a custom driver.
To repeat: installing a custom driver is no longer necessary, because
Trying to install and use a custom driver at this point is likely to confuse matters further. So I recommend not continuing down that route.
Yes I updated the hub before doing anything and I will try removing the entire device and starting over I didn’t use a custom driver the second time around
Everything is working perfectly thank you all for all your help!!!
So looks like the Siri functions don’t work well at all could this be because it’s still in beta ? Also once Alexa is connected to the shades as well the Apple HomeKit or hubitat is unable to control them is this normal ?
