Replacing my old yale x nest lock with something else as its having issues pairing. From what i've seen best options are Yale zwave/zigbee or Schlage. All the topics are a bit dated though, wanted to make sure nothing else has come out that changed the market. ATM planning on Yale Zwave linked below. currently have equal split of inovelli reds/blues so network shouldn't matter much. Would be nice to have finger print or NfC unlock but i can live with just the touch screen code.
I have two Yale's and they work well with my Hubitat hubs.
I have that exact lock and it works well for me too.
I have 3 of the keypad, rather than touchscreen, versions of that lock and once I RTFM to get the first one to pair correctly, they've been nearly flawless.
I got an alert the other day that one of the doors had failed to lock when the house went into Away mode, but when I checked the lock it was locked and the logs showed it showed it had locked right after the alert was sent.
yale YRD216 Zigbee with buttons. best lock ever. My 2 schlages are garbage BE469 & BE469ZP
