Hi all
what information is needed,and, how do I find it
to get support for my yeelight YLXD01YL ceiling lights please??
still struggling to connect my Yeelights.
but tonight the wind was blowing "just" right LOL
I actually discovered (and got to work) my yeelight strip!!
and detected one on the YLXD01YL units, but it won't add
thanks for any help
Love and peace
Garry
Open live logging, and leave it open, in another window open the yeelight app and reselect the device that it rejected, after hitting done, the live logs will have the info I need to add the bulb to the app.
You also need to let me know what the device capabilities are...
dev:2892019-08-10 10:54:32.054 debugheartbeat- message sent...
dev:2892019-08-10 10:54:32.033 debugts- ct:1565430872029, lhb: 1565430752056, age: 119973
dev:2892019-08-10 10:54:32.030 debuggetReTry- reTryCount:0
dev:2892019-08-10 10:52:32.045 debugheartbeat- message sent...
dev:2892019-08-10 10:52:32.041 debugts- ct:1565430752031, lhb: 1565430632053, age: 119978
dev:2892019-08-10 10:52:32.032 debuggetReTry- reTryCount:0
app:2252019-08-10 10:51:40.191 warnunable to add model [ceiling1], we don't know what this device's capabilities are...
app:2252019-08-10 10:51:40.159 debugUpdated with settings: [selectedYeelights:[7C49EBB7434E]]
dev:2892019-08-10 10:50:32.039 debugheartbeat- message sent...
dev:2892019-08-10 10:50:32.037 debugts- ct:1565430632033, lhb: 1565430512053, age: 119980
dev:2892019-08-10 10:50:32.034 debuggetReTry- reTryCount:0
app:2252019-08-10 10:50:16.175 warnunable to add model [ceiling1], we don't know what this device's capabilities are...
app:2252019-08-10 10:50:16.100 debugUpdated with settings: [selectedYeelights:[7C49EBB7434E]]
dev:2892019-08-10 10:48:32.138 debugheartbeat- message sent...
dev:2892019-08-10 10:48:32.135 debugts- ct:1565430512034, lhb: 1565430392035, age: 119999
dev:2892019-08-10 10:48:32.112 debuggetReTry- reTryCount:0
--- Live Log Started, waiting for events ---
{7C49EBB7434E={deviceAddress=d893, name=, location=yeelight://192.168.168.205:55443, model=ceiling1, id=0x0000000005eb556c, networkAddress=C0A8A8CD, support=get_prop set_default set_power toggle set_bright set_scene cron_add cron_get cron_del start_cf stop_cf set_ct_abx set_name set_adjust adjust_bright adjust_ct, mac=7C49EBB7434E}}
Hi @mike.maxwell ! thanks for your help!
these are Yeelight ceiling lights
they dim, and have colour temperature setting, I believe there is a "moon" setting too that allows very low light control, (though not important I thought I had better mention it as it is a separate "mode")
love and peace
Garry
Perfect, to be clear though these are not color capable (red, green, blue ect)
Hi Mike!
thanks a lot, no these are colour temperature only
Love and peace
Garry
looks like you're on the road to recovery now @garry-heskimo
glad to see mike has you sorted.
Hi Steve!
looking forward to being able to turn off Smartthings once I can get my lights working
Hi there @mike.maxwell just wondering if there's any progress.. I know how busy you are, so it's just a gentle reminder
just so you know I am still interested
Love and Peace
Garry
support for that light will be in platform 2.1.4, coming to a hub near you sometime soon...
@mike.maxwell thank you so much
can't wait!
Love and peace
Garry
Hurray!
Hi Mike, Similar topic. I got a free Yeelight model YLDP13AYL when I bought a Nest mini. Hooked it up, installed app, remote enabled, etc.
HE Yeelight integration found it however it would not add the device due to the same error above:
app:9622019-12-08 12:09:02.113 pm [warn] unable to add model [color6], we don't know what this device's capabilities are...
Does this mean I have an unsupported color bulb? Will that be added one day too? Or is there a way in the app to make it look like another version of the color bulb (select it as a different Yeelight model)?
Hi Mike, digging up another one of the old post to report a bug. This light is only half working now in 2.2.8.141 on C7.
The YLXD01YL is a color temperature bulb, which used to work perfectly in older versions. in current version,
- if you select "Yeelight CT bulb" in device type, you get "set level" input but it does not work and reports an error.
- If you select "Yeelight Bulb" in device type, the "set level" works, but no longer the option to change color temperature
Full log below. All the error was generated with CT Bulb type, all the success set level was with basic bulb type.
dev:1642021-07-27 06:03:38.500 am infoKitchen Ceiling level was set to 100%
dev:1642021-07-27 06:03:34.920 am infoKitchen Ceiling level was set to 5%
dev:1642021-07-27 06:03:21.187 am errororg.codehaus.groovy.runtime.InvokerInvocationException: groovy.lang.MissingMethodException: No signature of method: java.lang.String.call() is applicable for argument types: (java.math.BigDecimal, java.lang.Integer) values: [50, 1000] Possible solutions: wait(), any(), wait(long, int), take(int), trim(), grep() (method setLevel)
dev:1642021-07-27 06:03:08.688 am errororg.codehaus.groovy.runtime.InvokerInvocationException: groovy.lang.MissingMethodException: No signature of method: java.lang.String.call() is applicable for argument types: (java.math.BigDecimal, java.lang.Integer) values: [5, 1000] Possible solutions: wait(), any(), wait(long, int), take(int), trim(), grep() (method setLevel)
dev:1642021-07-27 06:03:01.073 am infoKitchen Ceiling color is White
dev:1642021-07-27 06:03:01.061 am infoKitchen Ceiling color temperature is 4228°K
dev:1642021-07-27 06:03:01.057 am infoKitchen Ceiling level is at 100%
dev:1642021-07-27 06:03:01.052 am infoKitchen Ceiling is on
dev:1642021-07-27 06:02:39.480 am infoKitchen Ceiling level was set to 100%
dev:1642021-07-27 06:02:30.717 am errorjava.lang.NullPointerException: Cannot invoke method toInteger() on null object (method parse)
dev:1642021-07-27 06:02:30.704 am infoKitchen Ceiling level is at 10%
dev:1642021-07-27 06:02:30.699 am infoKitchen Ceiling is on
dev:1642021-07-27 06:02:28.867 am errorjava.lang.NullPointerException: Cannot invoke method toInteger() on null object (method parse)
dev:1642021-07-27 06:02:28.862 am infoKitchen Ceiling level is at 10%
