As the title says, I have had a Yale Assure Sl ( Z-wave module ) lock for a few months now. I wanted to look up which codes were programmed as I wanted to change one but forgot its position. Previously when I clicked getCodes, the available lock codes would display in the UI. Now, it does nothing. Well not nothing, the request gets sent but nothing shows up.
There is a but of status on the side that says lockCodes, but it is al in mixed up alphanumerics. I assume these are hashed versions of the lock codes, but I don't se a way to de-encrypt them and get the position like the getCodes command used to return and display.
Driver details? I was not using a driver for the lock as I could not find one that matched the model I was using. I might not have looked hard enough, or just missed it, but if you have a link to a driver I could use I would apply it.
Also if there is another area for driver details let me know. I am still getting used to hubitat and haven't found all the buttons.
Pardon the ignorant question, but where would I find the generic driver? Nothing exists in the Driver Codes section that has that name. I know that the yale lock defaults to Generic Lock, but never saw a specific driver that controlled this so I just assumed it was part of the platform code somewhere inaccessible.
Driver Code is for Community Developed code.. there's also built-in Drivers and Apps.
Just go to the Device Info page for your device and pick a driver from the drop down lost. If you have code in Driver Code section, those drivers would appear at the end of the drop down list. Everything else is Built-In.
A combination of this and finding that there is an app called Lock Code Manager, helped me solve the problem. Switching back to the Generic Z-Wave Lock type also brought up the option to decrypt the lock codes.
