Thought that i would try out ordering cheap devices from Ali Express.
The Xiaomi buttons were well reviewed, so ordered two.
Now, I cannot find a driver to get them to work!
Have tried the Xiaomi Button driver (no luck) and the driver set from OLL.
No good so far.
Any suggestions?
aaiyar
2
What's the model number? Perhaps it is supported by @chirpy's driver for Xiaomi Mijia/Aqara devices.
The model number of the device is: WXKG01LM
aaiyar
4
That should work with @chirpy's driver.
This is what I get with @chirpy driver:
It seems like any driver I use, I get the numberOfButtons:0
Any ideas?
Is there a configure or initialise command in the driver? If so you might need to click on that button.
There is a configure button, but nothing happens.
Another driver I tried stated there were 5 buttons, but again, nothing worked.
Thanks for that.
I think I found the issue - the first button wasn't identified correctly.
Will re-pair the first one, then try that driver.
This driver works for me. Thank You. I could not get this device added until I installed this driver manually. The Aqara button works good so far.
