There are a couple of community apps written to use power plugs for washing machine notification if you haven't already seen them. You might want to check those out.
Thanks I have a couple of Shelly plugs I preordered that should ship soon by recommendation on here but did not know about the apps.... I will check those out thanks for the tip...but I had high hopes for these things for even a mailbox or dishwasher but they aren’t even playing well with rules when they do trigger so I might play with it a bit more till I get my Shellys.... and if I don’t find good use I’ll return them.
There have been also some projects posted for mailbox alerts too!
@X-RayVision I use the drivers that were originally written by Marcus. They are no longer maintained but it does allow to set the sensitivity of the Aqara vibration sensor. Note it can be a bit fiddly. You set it in the driver but it may not change until you reset the device.
Oh wow....Can you link me? I can’t seem to find the vibration sensor.
@X-RayVision Of course. See post 1 in this chain for the individual links. [Release] Xiaomi / Aqara / Opple Drivers with Presence!
I don’t how I could not find it b4. Thanks! Just switching to this already seems more sensitive ... so once set, the sensitivity actually shows in current states? When it says to push the reset button it means the button on the actual sensor I assume tried that a couple times and did a disconnect and sensitivity didn’t seem to show up... I’ll keep fiddling.
Yes it can be a bit of a pain. I think last time I changed it, it had to delete the device and the search for it again. Also found that Aqara devices connect better we really close to the hub.
Hi guys,
I have some Aqara without neutral switch 1 and 2 button and work OK. Now I buy another 1 and look new designs and my V1 button is not working, if I press manually is working but from the application NO.
This is the difference
I suppose need new or change old driver, anybody have some idea how to fix this?
Thk,
N
I too have the same issue where there is no wet/dry status shown in the "Current States" section Hubitat.
4 out of 6 new water leak sensors are not reporting wet/dry status like this.
Driver:
- Xiaomi Aqara Leak Sensor - model SJCGQ11LM
- Device Driver for Hubitat Elevation hub
- Version 0.8
Log:
sys:12021-06-24 06:22:18.528 pm Zigbee Discovery Stopped
dev:212021-06-24 06:21:25.688 pm debugWater Leak sensor6: Creating event [name:battery, value:100, unit:%, descriptionText:Battery level is 100% (3.065 Volts)]
dev:212021-06-24 06:21:25.686 pm infoWater Leak sensor6: Battery level is 100% (3.065 Volts)
dev:212021-06-24 06:21:25.674 pm debugWater Leak sensor6: Battery parse string = 220121F90B0328260421A80105213F0006240100000000082106020A2159D1641000
dev:212021-06-24 06:21:25.672 pm debugWater Leak sensor6: Message payload: 220121F90B0328260421A80105213F0006240100000000082106020A2159D1641000
dev:212021-06-24 06:21:25.664 pm debugWater Leak sensor6: Parsing message: read attr - raw: C26C0100004A01FF42220121F90B0328260421A80105213F0006240100000000082106020A2159D1641000, dni: C26C, endpoint: 01, cluster: 0000, size: 4A, attrId: FF01, encoding: 42, command: 0A, value: 220121F90B0328260421A80105213F0006240100000000082106020A2159D1641000
dev:212021-06-24 06:21:24.845 pm debugWater Leak sensor6: Reset button was short-pressed
dev:212021-06-24 06:21:24.843 pm debugWater Leak sensor6: Message payload: 156C756D692E73656E736F725F776C65616B2E61713101002006
dev:212021-06-24 06:21:24.825 pm debugWater Leak sensor6: Parsing message: read attr - raw: C26C0100003A050042156C756D692E73656E736F725F776C65616B2E61713101002006, dni: C26C, endpoint: 01, cluster: 0000, size: 3A, attrId: 0005, encoding: 42, command: 0A, value: 156C756D692E73656E736F725F776C65616B2E61713101002006
dev:212021-06-24 06:21:24.792 pm errorjava.lang.NullPointerException: Cannot invoke method getAt() on null object on line 80 (parse)
dev:212021-06-24 06:21:24.770 pm debugWater Leak sensor6: Parsing message: catchall: 0000 0013 00 00 0040 00 C26C 00 00 0000 00 00 9F6CC258A5B706008D150080
sys:12021-06-24 06:21:24.558 pm Found Previously Joined Zigbee Device Water Leak sensor6
dev:212021-06-24 06:21:24.542 pm infoWater Leak sensor6: Configuring
sys:12021-06-24 06:21:18.516 pm Zigbee Discovery Running
Current States:
#### Current States
* battery : **100**
* batteryLastReplaced : **Wed Jun 23 19:30:54 EDT 2021**
* lastCheckinEpoch : **1624576340153**
* lastCheckinTime : **Jun 24, 2021 7:12:20 PM**
Hi,
I have the aqara outlet and I would like to know if there is a way of having a power-off memory in the case of an electrical cut-off. Thanks for any help!
First: kudos to anyone who has contributed to this solution.
Yesterday I received several WXKG11LM Aqara Buttons and installed them successfully. All seem to be working and awesome.
Question - when I view the device page, I see this:
It seems like I should be able to assign button numbers to the various actions, but I haven't found anything I can put in the fields that it will save. The buttons appear to be working without anything in the fields...I created a simple automation rule to key in on button 1, which is the button press. Anyone know if/how I can utilize double presses, holds, etc?
Thanks in advance,
Kris
What you're looking at is the "Commands" section of the device page, which is useful for manually running commands on the device, which might be helpful to test automations you've set up (elsewhere) that trigger based on those events or for devices--not so much these--that accept commands to see if the device responds as expected. In the case of buttons, most buttons really just send messages to the hub and don't accept commands (consider this in contrast to a switch, where "On" and "Off" are commands you might be able to send from the hub). The "Push," "Hold," etc. buttons you see on this page should just simulate a "virtual" button press (again, telling any apps/automations you have that look for these events that these events happened), but unless you've configured an automation somewhere, it won't do much.
Beyond that, these drivers likely have another oddity; they have apparently been abandoned, and Hubitat's button model requirements have slightly changed since they were introduced. It's possible they don't actually implement these commands (they're new-ish) and will just error out in the log instead. This isn't crucial unless you plan on "virtually" generating these events instead of actually pressing the button. (A quick glance at the code for one suggests it actually does implement it but will log a message to the effect of "LOL, this doesn't make sense," which is also kind of true...but unlike convention, it won't generate an event.)
Long story short, what I suspect you're looking for is an app like Button Controller or any of other various built-in or community options to create automations based on actual button events. On Hubitat, automations are created via so-called "apps," so you'll find these under "Apps" on the left-side menu (and Add Built-In App or Add User App, depending on what you have installed or not, etc.).
The fields do not "assign" buttons, they are meant to issue a press command exactly if the real button was pressed. However I've just noticed that they actually don't work (as @bertabcd1234 says it will generate an error message). Probably fixable if someone wanted to, however, as I never use this function it really doesn't bother me.
Oher than this they still work fine (another minor niggle is that the button driver does misrepresent the number of buttons available.)
Taking in to account what others have said about newer buttons may not work with these older drivers, I do have a button that works. I set the actions through Simple Automation Rules. As you can see on the two examples below you can assign different actions.
Dlsnet, I am having some trouble getting a BlitzWolf BW-IS3 working. What driver did you use?
Regards,
Anyone having issues re-pairing Aqara Temperature Humidity sensor ?? Mine isn't getting detected after a year with no issue.
New battery?
Yup that was it LOL
@veeceeoh I got some MCCGQ14LM contact sensors. What can I do to provide information for implementation of these decives?
