Hi,
I got a few Xiaomi Aqara, RTCGQ11LM, Zigbee Motion Sensors and I am trying to set them up to turn some hue lights on. Howeverm it doesn't seem to trigger.
The devices paired with HE, but it is seen as "Device", not as a motion sensor:
Data
endpointId: 01
application:
softwareBuild: 3000-0001
inClusters: 0000,FFFF,0406,0400,0500,0001,0003
outClusters: 0000,0019
model: lumi.sensor_motion.aq2
manufacturer: LUMI
I can see the device logs and they look like this:
dev:1002020-01-17 09:08:33.936 am infoZigbee parsed:[raw:A7800100004201FF421D0121350C0328130421A81305214F00062401000000000A210000641001, dni:A780, endpoint:01, cluster:0000, size:42, attrId:FF01, encoding:42, command:0A, value:!5(!¨!O$
!d, clusterInt:0, attrInt:65281]
dev:1072020-01-17 08:54:06.893 am infoZigbee parsed:[raw:20CA0100004A01FF42210121B30B03281D0421A81305213A00062401000000000A2100006410000B210300, dni:20CA, endpoint:01, cluster:0000, size:4A, attrId:FF01, encoding:42, command:0A, value:!³(!¨!:$
!d!, clusterInt:0, attrInt:65281]
dev:1002020-01-17 08:18:26.522 am infoZigbee parsed:[raw:A7800100004201FF421D0121350C0328140421A81305214F00062401000000000A210000641001, dni:A780, endpoint:01, cluster:0000, size:42, attrId:FF01, encoding:42, command:0A, value:!5(!¨!O$
Since it is not seen as Motion Sensor, it is also not visible in the Rule Machine and Zone Motion Controllers. I tried to make them visible by setting the device type to Generic Zigbee Motion Sensor, which works, but I get an error in the logs after this, whenever the device triggers, so this doesn't work either.
However, I did set up the Rule Machine and triggers and then changed the device type back to Device, but that does not work either.
In the Rule Machine I set up the trigger on "Motion Sensor" "changed" to be the event.
Any ideas if and how I could make this work?
Thanks.
