i have read and read and read these forums to try to get the keypad to pair.
Right now when i put in the batteries i get the green light flashing 3 times then stops for a few seconds and flashes again.
i have tried to hold down the button while putting in batteries (not sure when to release). Also tried to press the button 5 times after i put batteries in.
nothing seems to work when i try to pair it to zigbee.
I was able to get one to pair last weekend. I think what worked for me is after pressing the tamper switch as I inserted the batteries, I pressed a few buttons on the keypad as the Hubitat was in zigbee pairing mode. I was able to get home and away modes working but not night mode for some reason. I'll see if I can find the guides I used to connect them.
i start pushing the gray button before i enter the batteries and then hold it while adding all 4 batteries? then after the last one is entered how long until you let the gray button go?
