Could you suggest me a multisensor (presence and luminosity level) to put in my house? I want to create automation when I come back to home. I can’t use door sensor because my door is taller than the host.
The Zooz ZSE40s work with limitations. The light level is reported as 0-50. Which is not true lux. But it is generally good enough to determine light vs. dark. The larger issue is that they don't work with the Hubitat C7 out of the box. The only way to get them to work well with a C7 is to pair them via a secondary controller (z-stick and PC Controller software).
Actually, the Hue Motion Sensor does also report illuminance when paired to the Hubitat hub. Search the forum and you will see numerous very satisfied users. It also reports based on Lux changes, versus some other motion sensors that only report Lux when they detect a motion event.
Correct. Fine to leave the bulbs connected to the Hue bridge (in fact, that is the recommended approach.). Just pair the Hue motion sensor directly to the Hubitat hub and you should be good to go!
I was gifted a Fibaro from a very generous HE member and I have been very happy with it reporting Lux. Use it in the living room and the value is used to control lights all around the house
If having a motion and Lux sensor as separate devices is acceptable, I've had good luck with "Xiaomi Mijia Lux Sensor" It being Zigbee you don't have to worry about your national Z-Wave frequency.
