Well, so far this is a few hours of work, and a reasonable POC starting point. There is no reason it couldn't return other types of values, again using Set Variable as the mechanism to do so. I'll look into that. Integer and Decimal values would be easy. You can pass any type as the param, so we're only talking about the Return String action, like adding Return Integer and Return Decimal. I'm not sure returning Boolean matters and not sure at all about DateTime.
I mostly care about number types, less so about decimal. I agree that Boolean probably doesnāt make sense. I confess that Iāve never used datetime, and I donāt know whether it would be important to others.
I am in love with this idea.
I have numerous rules that have output from numerous formats, the common denominator is that i want them to output to a human form, a string.
If i understand what the output request is.
Notify
Speak
Print?
