deleted by Dale - to hard to read
I did a copy and paste for the driver. I'm not sure that's the best to post it here. I'm looking for someone to take a look at this and see if you see any glaring problems. I'm trying to make it so that it might work with more than one brand of shade. I have 3 different brands in two houses.
It's working well with the new Alexa plus. I am running a rule in Hubitat for all the actions and not exposing the actual driver to Alexa.
You can highlight all the code and then use "preformatted text" on the + button.
If it is working, I'm not sure what you need reviewed. You can also use other AI agents to look over the code, and make suggestions.
Man you were right on that one. I didn't know about how well some of the AI's worked. I found Gemini 3.7 and it is great. I talked it over and she helped me out with all Alexa problems. Thanks. I deleted the first post as I don't need any other help with it.
