Working HEM code?
I have been having fits with my Gen5 HEM. I can't seem to find a real reliable driver for it. Everything I find seems to be old stuff. HELP!
Have you tried the built-in driver?
I didn't know that there was one. I just tried it and it's actually acting even worse! Maybe I will have remove and redo the device.
I'm using the one from Taylor Vierrether and it's been rock solid for me. What is yours doing or not doing?
It's reporting total amps every 10 seconds or so. The total amps is also more than the sum of the two clamps. Everything else doesn't change no matter what I do for settings. It's very frustrating.
does it change if you refresh the page? And who's driver are you using?
Nothing happens if I hit any buttons at all. This was actually on Taylor's driver. I switched to the native one and I get similar behavior. I'm thinking deleting and re adding device is needed.
Definitely worth a try, sounds like it's gotten into a wonky state...
