I created the following rule yesterday. It is supposed to work from an hour before sunset until sunset. The idea is to turn the lights on prior to sunset if it is already dark due to clouds. It worked fine yesterday evening, and when I woke up this morning, the lights were on and the logs are filled with delays/on per the rule. Wondering what I did incorrectly before I scrap this idea.
Please read this post on Manage or Create Conditions
To apply these to your rule, you need to add them using a conditional action.
Thank you. I thought I had an if then in the action part, but apparently I didn't. We'll see how it goes from here. Thanks again.
