Hi, I have 12 WO15Z-1 outlets that I used to use with a Wink, and then a Wink 2. I believe they're actually Linear or Nortek-manufactured.
About 2y ago I switched to Hubitat and have loved it. I only recently got around to connecting the 12 outlets to Hubitat (they're for seasonal window candles) and am having some issues with 3 of the 12.
For the 9 that worked, I consistently was able to set the Hubitat to be in "Exclude Z-Wave" mode, and then double-tapped the button on the given outlet, waited to see the Hubitat excluded it, and then was able to add the outlet no issue.
For the life of me I cannot figure out how to get the remaining 3 to connect to Hubitat. I've obviously tried the same process as on the 9 that worked. I've since spent a good 2h attempting the following to get the remaining outlets into exclude mode:
-clicking the button 5 times fast, then holding it for 15s
-clicking the button 3 times fast, then holding for 3s, 5s, and 15s respectively
-clicking the button about 15 times out of frustration
-all of the above, but slightly faster and/or slower
-turning the breaker off to the outlet, waiting 30s, turning the breaker back on, and trying all of the above
Any other ideas? Thanks!
