I am looking to display a high low temperature on a Dashboard. I have created a virtual device defined as a "virtual temp sensor". I can manually set the value of this device in it's properties page and I can display it on a Dashboard. I have global variables that update to save hi/low temps.
However I cannot set the value of the virtual temp sensor with rule machine based on another device or variable as best I can tell.
Use a Custom Action to set the temperature of the virtual temp sensor. That allows using a variable to do so.
Thanks - I'll give it a try.
It would be nice to have a custom tile which can display more that one attribute, unless there is a way that I am not aware of? What I would like to do is display this:
(MS paint hack!)
But the closest I can get is shown below which looks a but messy. It is difficult to read on a small display as there is so much text that you are forced to use a tiny font and then it is to small to read
Take a look here
Awesome app by @Cobra
Yes a very good and useful app.
