[Wiki] HTTP Features and Endpoints
push it. Tell us what it does.
I know for mine, it does this:
OMG not another mystery button... This is going to drive me crazy. The C5 has the same button.
I read on 'the Reddit', that's the forbidden Tick Tac. To only be eaten as an after meal treat of tide pods in the case your attic has run out of the forbidden cotton candy. J/K don't eat those things, its really a secret Turbo Button.
Finally we now know the secret, HE has an underlying 80286 CPU with the good old turbo button :grin:
The red pill or blue?
One pill makes you larger, and one pill makes you small
And the ones that Hubitt gives you, don't do anything at all...
Has anyone dabbled into making a stylish addon to add some of these links?
One more, getting hub mesh token
Doesn't work on my C7:
http://hubitat.local/device/showHubMeshToken
Use this link. You can replace hubitat.local with your hub's ip.
Alas, same result:
Is it a firmware dependent link?
Not sure what build they added it but it's definitely in 2.2.4.148.
Ok. Still on 2.2.3.148 so that would be the cause.
Will try to remember to report back here when i have upgraded later in time.
Yes. Hub Mesh is a new feature first made available in 2.2.4
"hubitat.local" won't dns resolve in a lot of environments.
It should resolve in any environment that supports mDNS which would include Windows 10 and most Linux distros..
Does anyone know of an URL to trigger a single node repair that still works in 2.2.4.158?
Have you tried the URLs mentioned in this recent post? (Since these are GETs, doing them in the browser should have the same effect--you can ignore the fact that the original question was about a Rule.)
https://community.hubitat.com/t/way-to-do-a-z-wave-repair-in-rm/59197/3?u=bertabcd1234
(EDIT: See below for a re-post of this information if the link above does not work for you. I didn't notice that this was in a beta forum that only users in that group can see.)
Exactly what I was looking for. Thank you.
Um,
