Using the iOS app, I try to login via Remote Admin. "Connect Using Remote Admin". I go to a blank page with the URL remoteaccess-aws-hubitat-com at the top, and eventually it just times out. I have a valid subscription.
Go to My Hubitat > Registered Hubs
Click Hub Details on your hub and check the Last Checkin info.
If that is stale the hub may be offline.
As @jtp10181 mentioned, under Hub Details there are two fields of interest: Last Check in shows when the hub was last connected to the cloud, and "Active?" tells you if the hub is currently connected:
Remote Admin service requires the hub to be connected to the cloud.
This topic has been marked solved by the community and subsequently closed. If the issue persists, or for further discussion on this topic, feel free to create a new thread under a different category to continue the conversation.
If you are logged in, click [HERE] to get started.
