Why is HE zigbee info exposure so limited?
I was cleaning up a few unused/old devices from my Hub today, and one that appeared to be serving little to no purpose was my Zigbee Mesh Extender. Everywhere I looked it was no logs, no events, no activity. I did see that there were over 1000 messages sent in the zigbee settings under hub settings, but there was no info describing what triggered them/what that went to/what info was being communicated. I was about to remove it, since HE showed no activity, no routes, etc. when I discovered the Zigbee Monitor Driver by @garyjmilne (Y’all this driver is insanely useful and exposes ten times the amount of zigbee information I was even aware of. HIGHLY recommend downloading for use on your most central/highest traffic zigbee device. Thank you Gary!!).
After I finished reviewing things with my newfound zigbee information exposure and finished my clean up, I started wondering why on earth I had to go looking for a user made app to exposure some of the most basic, helpful, and sometimes necessary information for one of this devices most used protocols.
Why the heck isn’t all this info natively available? All we get is an incomplete graph and a table of message counts with most recent time stamp, info that’s not very useful and can be misleading due to the lack of all other information and the suggestion that this info is comprehensive. I had no idea how much info I was missing and I’m just dumbfounded that there’s so much info available that isn’t included in any of HE’s native exposure for Zigbee. Have I missed something major? Is any of this info available and accessible by default in HE? If so I’ll gladly amend my feedback, but after more than a year of working with home automation through HE I have never found more than what the Zigbee details in the device settings expose.
I really hope HE will correct this in the near future and add a significant and verbose increase of information exposure for zigbee details.
It would be helpful to describe the specific information you are looking for. That way, someone can address your question better. Thanks!
Alrighty, here you go. I couldn’t post screenshots of the full output because it would’ve required over 20 screenshots (on mobile). Instead, I simply marked how many “pages” of information was provided in each category, where one page means the information you can capture on one screenshot of an iPhone 16. I also obfuscated device names or any device identifying information in a way that still allows you to see the volume of information that was in that field, but not the value.
Bear in mind that this is the information I can collect on one single device with this driver, out of the dozens and dozens of Zigbee devices I have on my system
Interesting! I can't tell what all of that data would be or where it's coming from, but my guess is that you can get the "raw" data from various sources on the hub:
  • /hub/zigbee/getChildAndRouteInfo (or /hub/zigbee/getChildAndRouteInfoJson if you want it in a format more easily consumed by an app)
  • /hub/zigbeeDetails/json
My guess is that the driver mostly looks at the first endpoint over time and stores things that way, making a best guess about your network based on that history; and that it uses the second to match things up, like DNIs with device names and whatnot. But I am not familiar with the inner workings and am guessing based on what it looks like your screenshot may provide.
Zigbee networks are in a constant state of change, and aside from some routers that allow reporting this information, the hub doesn't know as much about routers more than one "hop" away from the hub, so that's why I'm assuming this driver looks at things over time to make these guesses (as the routers the hub talks to directly may change over time). The hub isn't trying to hide this information from you but maybe isn't as keen to make the best-guess picture readily available beyond the tools already there. :slight_smile:
Some (all? I don't know the spec requirements) Zigbee routers will also respond to commands to fetch information about neighbors, children, etc. Some drivers, like the built-in Ikea ones (probably because they know this is a manufacturer/device that does), display this data. It is likely possible for a custom driver, perhaps this one (so maybe another source for its data), to do the same, assuming, of course, device support. So for those devices where the drivers don't, that's maybe one thing you can't get as easily, though some data is available from the sources above.
But it looks like a good chunk of the long data above is from the hub sources you can fetch at any time, just in a more "raw" format than you see in this custom code, and perhaps some aggreation over time.
I can't answer your original question with any more certainty other than that, given the almost 9 years the platform has been public, support staff must have rarely found it helpful enough for most end users to make more apparent. That's probably why things like this have been added over time (they have been -- little to none of the above was there back in the day!) for the occasional use they have but are maybe not as full-fledged with built-in UIs as you were hoping. But I'm glad you found something that helped you!
I’m glad you brought that up because I discovered those url paths in my hunt for info, and was mildly annoyed that I had been unaware of them this whole time, and that could be my own fault. I’m not the type who reads every page of the device documentation when I set up a new device, so maybe Hubitat provides those links in its introductory material, but I had never seen those links provided anywhere, and I certainly had never known I could find more information about my hub using URL links that weren’t integrated into the hub UI that I log into every day. If those were a clickable buttons in the zigbee details, that would be very, very helpful too.
However, I don’t think that they provide this much information because I remember one of those links, I think the parent and child route info one, was an incredibly short amount of information. Definitely not as verbose as what this driver reveals.
I also failed to mention that I noticed after I responded to you that the screenshots I sent you were taken when I had the driver settings at its least verbose. Some of them were even off entirely. It can provide even more information than I showed you.
