No matter what I try, everything gets skipped, can't figure it out
What in the sam hill am I missing?
Edit: Sorry if I offended anyone named sam or hill
I think it might be because your second IF is falling under your first IF.
Either put an END-IF before your second IF or change your second IF to an ELSE-IF but make sure it doesn't fall under your first IF.
IF that makes sense........
End If, easily added
I wouldn't have expected everything to be skipped due to a missing End-If but then again, I don't code
I'll check it again tonight
You now have two independent IF-THEN statements.
Before you had an IF-THEN statement nested inside another IF-THEN statement. In other words the second IF-THEN will never be evaluated as if the first IF-THEN is true, you will exit the rule.
If the second IF-THEN is true, you will never get to it as the first IF-THEN is false and therefore you will never get to the second IF-THEN.
You could make the first IF-THEN statement a simple condition which doesn't require an END-IF and removes two lines from your rule. It would look like
IF (NOT Mode is Sleep) Exit Rule
