Why is a fake switch made?
When you pair the Tuya switch, you get a fake switch. It wasn't like that before, but this has happened recently. The last fake switch is not used.
Why is that?
And when you pair the Aqara switches, you get nine more fake switches.
Both are three-gang switches, and only three normal buttons function normally on the dashboard.
aliexpress.com
10.88US $ 50% OFF|EU ZIGBEE 3.0 SMART SWITCH PUSH BUTTON LIGHT SWITCH MQTT...
Smarter Shopping, Better Living! Aliexpress.com
aliexpress.com
4.27US $ 21% OFF|EU SHIP AQARA D1 WALL SWITCH ZIGBEE SMART LIGHT WALL SWITCH...
The same is true of Tuya's other three-gang switches.
Summary
dev:53172022-09-29 11:42:06.726 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5903E0010810D03000, dni: 8B59, endpoint: 03, cluster: E001, size: 08, attrId: D010, encoding: 30, command: 0A, value: 00 | msgMap:[raw:8B5903E0010810D03000, dni:8B59, endpoint:03, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, valueParsed:0]
dev:53172022-09-29 11:42:06.663 pminfoOn/Off Button press - description:read attr - raw: 8B590300061C0000100001402100000240210000, dni: 8B59, endpoint: 03, cluster: 0006, size: 1C, attrId: 0000, encoding: 10, command: 0A, value: 0001402100000240210000 | parseMap:[raw:8B590300061C0000100001402100000240210000, dni:8B59, endpoint:03, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]], valueParsed:false]
dev:53172022-09-29 11:42:06.601 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5902E0010810D03000, dni: 8B59, endpoint: 02, cluster: E001, size: 08, attrId: D010, encoding: 30, command: 0A, value: 00 | msgMap:[raw:8B5902E0010810D03000, dni:8B59, endpoint:02, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, valueParsed:0]
dev:53172022-09-29 11:42:06.539 pminfoOn/Off Button press - description:read attr - raw: 8B590200061C0000100001402100000240210000, dni: 8B59, endpoint: 02, cluster: 0006, size: 1C, attrId: 0000, encoding: 10, command: 0A, value: 0001402100000240210000 | parseMap:[raw:8B590200061C0000100001402100000240210000, dni:8B59, endpoint:02, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]], valueParsed:false]
dev:53172022-09-29 11:42:06.469 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5901E0011010D0300030D03001, dni: 8B59, endpoint: 01, cluster: E001, size: 10, attrId: D010, encoding: 30, command: 0A, value: 0030D03001 | msgMap:[raw:8B5901E0011010D0300030D03001, dni:8B59, endpoint:01, cluster:E001, size:10, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, additionalAttrs:[[value:01, encoding:30, attrId:D030, consumedBytes:4, attrInt:53296]], valueParsed:0]
dev:53172022-09-29 11:42:06.406 pminfoOn/Off Button press - description:read attr - raw: 8B590100063C000010000140210000024021000001803001028030000050300100801000, dni: 8B59, endpoint: 01, cluster: 0006, size: 3C, attrId: 0000, encoding: 10, command: 0A, value: 000140210000024021000001803001028030000050300100801000 | parseMap:[raw:8B590100063C000010000140210000024021000001803001028030000050300100801000, dni:8B59, endpoint:01, cluster:0006, size:3C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386], [value:01, encoding:30, attrId:8001, consumedBytes:4, attrInt:32769], [value:00, encoding:30, attrId:8002, consumedBytes:4, attrInt:32770], [value:01, encoding:30, attrId:5000, consumedBytes:4, attrInt:20480], [value:00, encoding:10, attrId:8000, consumedBytes:4, attrInt:32768]], valueParsed:false]
dev:53172022-09-29 11:42:06.317 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 211 (method parse)
dev:53172022-09-29 11:42:06.255 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 211 (method parse)
dev:53172022-09-29 11:42:06.193 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5901E0002003D0420C414141414167414142414141, dni: 8B59, endpoint: 01, cluster: E000, size: 20, attrId: D003, encoding: 42, command: 0A, value: 0C414141414167414142414141 | msgMap:[raw:8B5901E0002003D0420C414141414167414142414141, dni:8B59, endpoint:01, cluster:E000, size:20, attrId:D003, encoding:42, command:0A, value:AAAAAgAABAAA, clusterInt:57344, attrInt:53251]
dev:53172022-09-29 11:42:02.523 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 211 (method parse)
dev:53172022-09-29 11:42:02.471 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 211 (method parse)
dev:53172022-09-29 11:42:00.307 pmerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_oh_lalabs_com_Zigbee___Generic_Switch__with_Presence__403.autoPoll() is applicable for argument types: () values: []
Possible solutions: toggle() (method autoPoll)
dev:53172022-09-29 11:41:51.658 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5903E0010810D03000, dni: 8B59, endpoint: 03, cluster: E001, size: 08, attrId: D010, encoding: 30, command: 0A, value: 00 | msgMap:[raw:8B5903E0010810D03000, dni:8B59, endpoint:03, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, valueParsed:0]
dev:53172022-09-29 11:41:51.593 pminfoOn/Off Button press - description:read attr - raw: 8B590300061C0000100001402100000240210000, dni: 8B59, endpoint: 03, cluster: 0006, size: 1C, attrId: 0000, encoding: 10, command: 0A, value: 0001402100000240210000 | parseMap:[raw:8B590300061C0000100001402100000240210000, dni:8B59, endpoint:03, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]], valueParsed:false]
dev:53172022-09-29 11:41:51.529 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5902E0010810D03000, dni: 8B59, endpoint: 02, cluster: E001, size: 08, attrId: D010, encoding: 30, command: 0A, value: 00 | msgMap:[raw:8B5902E0010810D03000, dni:8B59, endpoint:02, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, valueParsed:0]
dev:53172022-09-29 11:41:51.469 pminfoOn/Off Button press - description:read attr - raw: 8B590200061C0000100001402100000240210000, dni: 8B59, endpoint: 02, cluster: 0006, size: 1C, attrId: 0000, encoding: 10, command: 0A, value: 0001402100000240210000 | parseMap:[raw:8B590200061C0000100001402100000240210000, dni:8B59, endpoint:02, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]], valueParsed:false]
dev:53172022-09-29 11:41:51.407 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5901E0011010D0300030D03001, dni: 8B59, endpoint: 01, cluster: E001, size: 10, attrId: D010, encoding: 30, command: 0A, value: 0030D03001 | msgMap:[raw:8B5901E0011010D0300030D03001, dni:8B59, endpoint:01, cluster:E001, size:10, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, additionalAttrs:[[value:01, encoding:30, attrId:D030, consumedBytes:4, attrInt:53296]], valueParsed:0]
dev:53172022-09-29 11:41:51.341 pminfoOn/Off Button press - description:read attr - raw: 8B590100063C000010000140210000024021000001803001028030000050300100801000, dni: 8B59, endpoint: 01, cluster: 0006, size: 3C, attrId: 0000, encoding: 10, command: 0A, value: 000140210000024021000001803001028030000050300100801000 | parseMap:[raw:8B590100063C000010000140210000024021000001803001028030000050300100801000, dni:8B59, endpoint:01, cluster:0006, size:3C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386], [value:01, encoding:30, attrId:8001, consumedBytes:4, attrInt:32769], [value:00, encoding:30, attrId:8002, consumedBytes:4, attrInt:32770], [value:01, encoding:30, attrId:5000, consumedBytes:4, attrInt:20480], [value:00, encoding:10, attrId:8000, consumedBytes:4, attrInt:32768]], valueParsed:false]
dev:53172022-09-29 11:41:51.271 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 211 (method parse)
dev:53172022-09-29 11:41:51.213 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 211 (method parse)
dev:53172022-09-29 11:41:51.145 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5901E0002003D0420C414141414167414142414141, dni: 8B59, endpoint: 01, cluster: E000, size: 20, attrId: D003, encoding: 42, command: 0A, value: 0C414141414167414142414141 | msgMap:[raw:8B5901E0002003D0420C414141414167414142414141, dni:8B59, endpoint:01, cluster:E000, size:20, attrId:D003, encoding:42, command:0A, value:AAAAAgAABAAA, clusterInt:57344, attrInt:53251]
dev:53172022-09-29 11:41:50.116 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001000, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590300060800001000, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:41:50.112 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:41:50.054 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001000, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590200060800001000, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:41:50.033 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:41:49.997 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001000, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590100060800001000, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:41:49.973 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:41:49.890 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:41:49.887 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:41:49.884 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:41:49.882 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-01
dev:53172022-09-29 11:41:49.202 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001001, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590300060800001001, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:41:49.189 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:41:49.144 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001001, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590200060800001001, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:41:49.137 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:41:49.097 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001001, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590100060800001001, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:41:49.068 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:41:48.962 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:41:48.959 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:41:48.957 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:41:48.954 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-01
dev:53172022-09-29 11:41:47.253 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5903E0010810D03000, dni: 8B59, endpoint: 03, cluster: E001, size: 08, attrId: D010, encoding: 30, command: 0A, value: 00 | msgMap:[raw:8B5903E0010810D03000, dni:8B59, endpoint:03, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, valueParsed:0]
dev:53172022-09-29 11:41:47.145 pminfoOn/Off Button press - description:read attr - raw: 8B590300061C0000100001402100000240210000, dni: 8B59, endpoint: 03, cluster: 0006, size: 1C, attrId: 0000, encoding: 10, command: 0A, value: 0001402100000240210000 | parseMap:[raw:8B590300061C0000100001402100000240210000, dni:8B59, endpoint:03, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]], valueParsed:false]
dev:53172022-09-29 11:41:47.083 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5902E0010810D03000, dni: 8B59, endpoint: 02, cluster: E001, size: 08, attrId: D010, encoding: 30, command: 0A, value: 00 | msgMap:[raw:8B5902E0010810D03000, dni:8B59, endpoint:02, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, valueParsed:0]
dev:53172022-09-29 11:41:47.016 pminfoOn/Off Button press - description:read attr - raw: 8B590200061C0000100001402100000240210000, dni: 8B59, endpoint: 02, cluster: 0006, size: 1C, attrId: 0000, encoding: 10, command: 0A, value: 0001402100000240210000 | parseMap:[raw:8B590200061C0000100001402100000240210000, dni:8B59, endpoint:02, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]], valueParsed:false]
dev:53172022-09-29 11:41:46.958 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5901E0011010D0300030D03001, dni: 8B59, endpoint: 01, cluster: E001, size: 10, attrId: D010, encoding: 30, command: 0A, value: 0030D03001 | msgMap:[raw:8B5901E0011010D0300030D03001, dni:8B59, endpoint:01, cluster:E001, size:10, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, additionalAttrs:[[value:01, encoding:30, attrId:D030, consumedBytes:4, attrInt:53296]], valueParsed:0]
dev:53172022-09-29 11:41:46.889 pminfoOn/Off Button press - description:read attr - raw: 8B590100063C000010000140210000024021000001803001028030000050300100801000, dni: 8B59, endpoint: 01, cluster: 0006, size: 3C, attrId: 0000, encoding: 10, command: 0A, value: 000140210000024021000001803001028030000050300100801000 | parseMap:[raw:8B590100063C000010000140210000024021000001803001028030000050300100801000, dni:8B59, endpoint:01, cluster:0006, size:3C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386], [value:01, encoding:30, attrId:8001, consumedBytes:4, attrInt:32769], [value:00, encoding:30, attrId:8002, consumedBytes:4, attrInt:32770], [value:01, encoding:30, attrId:5000, consumedBytes:4, attrInt:20480], [value:00, encoding:10, attrId:8000, consumedBytes:4, attrInt:32768]], valueParsed:false]
dev:53172022-09-29 11:41:00.339 pmerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_oh_lalabs_com_Zigbee___Generic_Switch__with_Presence__403.autoPoll() is applicable for argument types: () values: []
dev:53172022-09-29 11:40:54.178 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001000, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590300060800001000, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:54.169 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:54.123 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001000, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590200060800001000, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:54.117 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:54.106 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001000, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590100060800001000, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:54.047 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:53.968 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:40:53.965 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:40:53.963 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:40:53.960 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-01
dev:53172022-09-29 11:40:53.093 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001001, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590200060800001001, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:53.088 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:52.432 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001000, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590300060800001000, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:52.428 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:52.382 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001000, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590200060800001000, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:52.377 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:52.322 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001000, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590100060800001000, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:52.317 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:52.233 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:40:52.230 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:40:52.227 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:40:52.225 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-01
dev:53172022-09-29 11:40:50.660 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001001, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590300060800001001, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:50.656 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:49.891 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001000, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590300060800001000, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:49.887 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:49.533 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001000, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590200060800001000, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:49.527 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:49.480 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001000, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590100060800001000, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:49.476 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:49.384 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:40:49.382 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:40:49.379 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:40:49.376 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-01
dev:53172022-09-29 11:40:48.374 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001001, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590300060800001001, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:48.361 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:47.624 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001001, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590200060800001001, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:47.619 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:46.837 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001001, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590100060800001001, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:46.818 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:44.290 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001000, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590300060800001000, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:44.286 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:44.168 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:44.118 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001000, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590100060800001000, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:44.111 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:44.032 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:40:44.029 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:40:44.026 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:40:44.024 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-01
dev:53172022-09-29 11:40:43.023 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001001, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590300060800001001, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:43.019 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:42.928 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001001, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590200060800001001, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:42.858 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001001, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590100060800001001, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:42.849 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:42.769 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:40:42.766 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:40:42.764 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:40:42.761 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-01
dev:53172022-09-29 11:40:41.372 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001000, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590300060800001000, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:41.369 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:41.284 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001000, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590200060800001000, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:41.281 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:41.234 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001000, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590100060800001000, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:41.229 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:41.144 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:40:41.141 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:40:41.139 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:40:41.136 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-01
dev:53172022-09-29 11:40:39.656 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001001, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590200060800001001, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:39.652 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:38.318 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001000, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590200060800001000, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:38.307 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:38.264 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001001, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590200060800001001, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:38.251 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:37.042 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001000, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590200060800001000, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:37.007 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001000, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590300060800001000, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:37.002 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:37.002 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:36.863 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001000, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590100060800001000, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:36.758 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:40:36.755 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:40:36.752 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:40:36.750 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-01
dev:53172022-09-29 11:40:34.878 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001001, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590100060800001001, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:34.873 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:33.834 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001000, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590300060800001000, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:33.826 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:33.804 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001000, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590200060800001000, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:33.772 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:33.720 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001000, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590100060800001000, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:33.715 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:33.627 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:40:33.624 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:40:33.621 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:40:33.619 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-01
dev:53172022-09-29 11:40:32.856 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001001, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590300060800001001, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:32.819 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:32.396 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001001, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590200060800001001, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:32.330 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001001, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590100060800001001, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:32.326 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:32.236 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:40:32.232 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:40:32.229 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:40:32.226 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-01
dev:53172022-09-29 11:40:31.154 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001000, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590300060800001000, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:31.129 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:31.057 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001000, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590200060800001000, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:31.034 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:30.990 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001000, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590100060800001000, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:30.983 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:30.891 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:40:30.887 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:40:30.884 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:40:30.881 pminfoSending command 0 to cluster 0x0006 for Child deviceNetworkId: 5317-01
dev:53172022-09-29 11:40:30.012 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001001, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590300060800001001, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:30.001 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:29.947 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001001, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590200060800001001, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:29.944 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:29.900 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001001, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590100060800001001, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:29.886 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:29.801 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:40:29.798 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:40:29.795 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:40:29.792 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-01
dev:53172022-09-29 11:40:29.469 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001000, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590100060800001000, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:29.445 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:28.995 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001000, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590200060800001000, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:28.981 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:28.378 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001000, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:8B590300060800001000, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:53172022-09-29 11:40:28.373 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:53172022-09-29 11:40:26.580 pminfoOn/Off Button press - description:read attr - raw: 8B590300060800001001, dni: 8B59, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590300060800001001, dni:8B59, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:26.539 pminfoOn/Off Button press - description:read attr - raw: 8B590200060800001001, dni: 8B59, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590200060800001001, dni:8B59, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:26.517 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 03 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:26.474 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 02 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:02, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:26.415 pminfoOn/Off Button press - description:read attr - raw: 8B590100060800001001, dni: 8B59, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:8B590100060800001001, dni:8B59, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:53172022-09-29 11:40:26.415 pminfoON/OFF CATCHALL CLUSTER EVENT - description:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100 | parseMap:[raw:catchall: 0104 0006 01 01 0040 00 8B59 00 00 0000 0B 01 0100, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[01, 00]]
dev:53172022-09-29 11:40:26.312 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-F2
dev:53172022-09-29 11:40:26.306 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-03
dev:53172022-09-29 11:40:26.303 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-02
dev:53172022-09-29 11:40:26.299 pminfoSending command 1 to cluster 0x0006 for Child deviceNetworkId: 5317-01
If these devices are supported by community drivers, you should ask this of the developers of those drivers.
Summary
dev:53172022-09-29 11:40:12.174 pminfoDo nothing - The device already exists
dev:53172022-09-29 11:40:12.151 pminfoMaking device with id 5317-F2 (name: Tuya Zigbee Metering Plug F2, label: T 화장실3G Sw F2)
dev:53172022-09-29 11:40:12.147 pminfoDo nothing - The device already exists
dev:53172022-09-29 11:40:12.124 pminfoMaking device with id 5317-03 (name: Tuya Zigbee Metering Plug 03, label: T 화장실3G Sw 03)
dev:53172022-09-29 11:40:12.119 pminfoDo nothing - The device already exists
dev:53172022-09-29 11:40:12.100 pminfoModel Name Received - description:read attr - raw: 8B590100001605004206545330303033, dni: 8B59, endpoint: 01, cluster: 0000, size: 16, attrId: 0005, encoding: 42, command: 01, value: 06545330303033 | parseMap:[raw:8B590100001605004206545330303033, dni:8B59, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0003, clusterInt:0, attrInt:5]
dev:53172022-09-29 11:40:12.090 pminfoMaking device with id 5317-02 (name: Tuya Zigbee Metering Plug 02, label: T 화장실3G Sw 02)
dev:53172022-09-29 11:40:12.024 pminfoDo nothing - The device already exists
dev:53172022-09-29 11:40:11.990 pminfoMaking device with id 5317-01 (name: Tuya Zigbee Metering Plug 01, label: T 화장실3G Sw 01)
dev:53172022-09-29 11:40:11.983 pminfoEndpoint Discovery Cluster Event- description:catchall: 0000 8005 00 00 0040 00 8B59 00 00 0000 00 00 5500598B04010203F2 | parseMap:[raw:catchall: 0000 8005 00 00 0040 00 8B59 00 00 0000 00 00 5500598B04010203F2, profileId:0000, clusterId:8005, clusterInt:32773, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:8B59, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[55, 00, 59, 8B, 04, 01, 02, 03, F2]]
dev:53172022-09-29 11:40:11.937 pminfoManufacturer Name Received - description:read attr - raw: 8B590100002A040042105F545A333030305F7564746D72617367, dni: 8B59, endpoint: 01, cluster: 0000, size: 2A, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F7564746D72617367 | parseMap:[raw:8B590100002A040042105F545A333030305F7564746D72617367, dni:8B59, endpoint:01, cluster:0000, size:2A, attrId:0004, encoding:42, command:01, value:_TZ3000_udtmrasg, clusterInt:0, attrInt:4]
dev:53172022-09-29 11:40:11.917 pminfoSKIPPING ping() since there has been events received during the last 25 minutes...
dev:53172022-09-29 11:40:11.802 pminfoRecovery feature ENABLED
dev:53172022-09-29 11:40:11.750 pminfogetDriverVersion() = v1.0.1.1123b
dev:53172022-09-29 11:40:11.747 pminfoupdated()
dev:53172022-09-29 11:40:00.325 pmerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_oh_lalabs_com_Zigbee___Generic_Switch__with_Presence__403.autoPoll() is applicable for argument types: () values: []
Possible solutions: toggle() (method autoPoll)
dev:53172022-09-29 11:39:56.090 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 211 (method parse)
dev:53172022-09-29 11:39:56.031 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 211 (method parse)
dev:53172022-09-29 11:39:55.201 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5903E0010810D03000, dni: 8B59, endpoint: 03, cluster: E001, size: 08, attrId: D010, encoding: 30, command: 0A, value: 00 | msgMap:[raw:8B5903E0010810D03000, dni:8B59, endpoint:03, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, valueParsed:0]
dev:53172022-09-29 11:39:55.139 pminfoOn/Off Button press - description:read attr - raw: 8B590300061C0000100001402100000240210000, dni: 8B59, endpoint: 03, cluster: 0006, size: 1C, attrId: 0000, encoding: 10, command: 0A, value: 0001402100000240210000 | parseMap:[raw:8B590300061C0000100001402100000240210000, dni:8B59, endpoint:03, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]], valueParsed:false]
dev:53172022-09-29 11:39:55.087 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5902E0010810D03000, dni: 8B59, endpoint: 02, cluster: E001, size: 08, attrId: D010, encoding: 30, command: 0A, value: 00 | msgMap:[raw:8B5902E0010810D03000, dni:8B59, endpoint:02, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, valueParsed:0]
dev:53172022-09-29 11:39:55.033 pminfoOn/Off Button press - description:read attr - raw: 8B590200061C0000100001402100000240210000, dni: 8B59, endpoint: 02, cluster: 0006, size: 1C, attrId: 0000, encoding: 10, command: 0A, value: 0001402100000240210000 | parseMap:[raw:8B590200061C0000100001402100000240210000, dni:8B59, endpoint:02, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]], valueParsed:false]
dev:53172022-09-29 11:39:54.979 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5901E0011010D0300030D03001, dni: 8B59, endpoint: 01, cluster: E001, size: 10, attrId: D010, encoding: 30, command: 0A, value: 0030D03001 | msgMap:[raw:8B5901E0011010D0300030D03001, dni:8B59, endpoint:01, cluster:E001, size:10, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, additionalAttrs:[[value:01, encoding:30, attrId:D030, consumedBytes:4, attrInt:53296]], valueParsed:0]
dev:53172022-09-29 11:39:54.917 pminfoOn/Off Button press - description:read attr - raw: 8B590100063C000010000140210000024021000001803001028030000050300100801000, dni: 8B59, endpoint: 01, cluster: 0006, size: 3C, attrId: 0000, encoding: 10, command: 0A, value: 000140210000024021000001803001028030000050300100801000 | parseMap:[raw:8B590100063C000010000140210000024021000001803001028030000050300100801000, dni:8B59, endpoint:01, cluster:0006, size:3C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386], [value:01, encoding:30, attrId:8001, consumedBytes:4, attrInt:32769], [value:00, encoding:30, attrId:8002, consumedBytes:4, attrInt:32770], [value:01, encoding:30, attrId:5000, consumedBytes:4, attrInt:20480], [value:00, encoding:10, attrId:8000, consumedBytes:4, attrInt:32768]], valueParsed:false]
dev:53172022-09-29 11:39:54.860 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 211 (method parse)
dev:53172022-09-29 11:39:54.838 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 211 (method parse)
dev:53172022-09-29 11:39:54.733 pminfoUnhandled Event IGNORE THIS - description:read attr - raw: 8B5901E0002003D0420C414141414167414142414141, dni: 8B59, endpoint: 01, cluster: E000, size: 20, attrId: D003, encoding: 42, command: 0A, value: 0C414141414167414142414141 | msgMap:[raw:8B5901E0002003D0420C414141414167414142414141, dni:8B59, endpoint:01, cluster:E000, size:20, attrId:D003, encoding:42, command:0A, value:AAAAAgAABAAA, clusterInt:57344, attrInt:53251]
dev:53172022-09-29 11:39:00.333 pmerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_oh_lalabs_com_Zigbee___Generic_Switch__with_Presence__403.autoPoll() is applicable for argument types: () values: []
dev:53172022-09-29 11:38:41.449 pminfoSKIPPING ping() since there has been events received during the last 25 minutes...
dev:53172022-09-29 11:38:41.334 pminfoRecovery feature ENABLED
dev:53172022-09-29 11:38:41.246 pminfogetDriverVersion() = v1.0.1.1123b
dev:53172022-09-29 11:38:40.792 pminfoSKIPPING ping() since there has been events received during the last 25 minutes...
dev:53172022-09-29 11:38:02.847 pmtracedescMap:[raw:catchall: 0000 0013 00 00 0040 00 3DFE 00 00 0000 00 00 22FE3D8BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[22, FE, 3D, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:38:02.844 pmdebugdescMap:[raw:catchall: 0000 0013 00 00 0040 00 3DFE 00 00 0000 00 00 22FE3D8BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[22, FE, 3D, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:38:00.274 pmerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: genericZigbeeMultiepSwitch.autoPoll() is applicable for argument types: () values: [] (method autoPoll)
dev:53172022-09-29 11:37:54.166 pmtracedescMap:[raw:catchall: 0000 0013 00 00 0040 00 3DFE 00 00 0000 00 00 1BFE3D8BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[1B, FE, 3D, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:37:54.163 pmdebugdescMap:[raw:catchall: 0000 0013 00 00 0040 00 3DFE 00 00 0000 00 00 1BFE3D8BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[1B, FE, 3D, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:37:37.717 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 3DFE 00 00 0000 00 00 3082, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[30, 82]]
dev:53172022-09-29 11:37:37.714 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 3DFE 00 00 0000 00 00 3082, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[30, 82]]
dev:53172022-09-29 11:37:37.705 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 3DFE 00 00 0000 00 00 2F00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[2F, 00]]
dev:53172022-09-29 11:37:37.703 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 3DFE 00 00 0000 00 00 2F00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[2F, 00]]
dev:53172022-09-29 11:37:37.699 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 3DFE 00 00 0000 00 00 2E00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[2E, 00]]
dev:53172022-09-29 11:37:37.696 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 3DFE 00 00 0000 00 00 2E00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[2E, 00]]
dev:53172022-09-29 11:37:37.535 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 3DFE 00 00 0000 00 00 2D00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[2D, 00]]
dev:53172022-09-29 11:37:37.532 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 3DFE 00 00 0000 00 00 2D00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[2D, 00]]
dev:53172022-09-29 11:37:37.431 pminfochild device exists
dev:53172022-09-29 11:37:37.426 pminfochild device exists
dev:53172022-09-29 11:37:37.423 pminfochild device exists
dev:53172022-09-29 11:37:37.420 pminfochild device exists
dev:53172022-09-29 11:37:37.414 pmdebugdescMap:[raw:catchall: 0000 8005 00 00 0040 00 3DFE 00 00 0000 00 00 2C00FE3D04010203F2, profileId:0000, clusterId:8005, clusterInt:32773, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[2C, 00, FE, 3D, 04, 01, 02, 03, F2]]
dev:53172022-09-29 11:37:36.807 pmtracedescMap:[raw:catchall: 0000 0013 00 00 0040 00 3DFE 00 00 0000 00 00 12FE3D8BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[12, FE, 3D, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:37:36.804 pmdebugdescMap:[raw:catchall: 0000 0013 00 00 0040 00 3DFE 00 00 0000 00 00 12FE3D8BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3DFE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[12, FE, 3D, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:37:36.726 pmwarnconfigure...
dev:53172022-09-29 11:37:16.353 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 6334 00 00 0000 00 00 2000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6334, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[20, 00]]
dev:53172022-09-29 11:37:16.350 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 6334 00 00 0000 00 00 2000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6334, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[20, 00]]
dev:53172022-09-29 11:37:16.251 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 6334 00 00 0000 00 00 2000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6334, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[20, 00]]
dev:53172022-09-29 11:37:16.248 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 6334 00 00 0000 00 00 2000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6334, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[20, 00]]
dev:53172022-09-29 11:37:14.134 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 6334 00 00 0000 00 00 2100, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6334, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[21, 00]]
dev:53172022-09-29 11:37:14.131 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 6334 00 00 0000 00 00 2100, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6334, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[21, 00]]
dev:53172022-09-29 11:37:13.850 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 6334 00 00 0000 00 00 2000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6334, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[20, 00]]
dev:53172022-09-29 11:37:13.847 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 6334 00 00 0000 00 00 2000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6334, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[20, 00]]
dev:53172022-09-29 11:37:13.736 pminfochild device exists
dev:53172022-09-29 11:37:13.732 pminfochild device exists
dev:53172022-09-29 11:37:13.729 pminfochild device exists
dev:53172022-09-29 11:37:13.726 pminfochild device exists
dev:53172022-09-29 11:37:13.718 pmdebugdescMap:[raw:catchall: 0000 8005 00 00 0040 00 6334 00 00 0000 00 00 1F00346304010203F2, profileId:0000, clusterId:8005, clusterInt:32773, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6334, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[1F, 00, 34, 63, 04, 01, 02, 03, F2]]
dev:53172022-09-29 11:37:13.201 pmtracedescMap:[raw:catchall: 0000 0013 00 00 0040 00 6334 00 00 0000 00 00 0734638BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6334, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[07, 34, 63, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:37:13.198 pmdebugdescMap:[raw:catchall: 0000 0013 00 00 0040 00 6334 00 00 0000 00 00 0734638BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6334, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[07, 34, 63, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:37:12.895 pmwarnconfigure...
dev:53172022-09-29 11:37:00.307 pmerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: genericZigbeeMultiepSwitch.autoPoll() is applicable for argument types: () values: [] (method autoPoll)
dev:53172022-09-29 11:36:50.587 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 79 (method parse)
dev:53172022-09-29 11:36:50.492 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 79 (method parse)
dev:53172022-09-29 11:36:49.588 pmtraceskipped descMap:[raw:D8D603E0010810D03000, dni:D8D6, endpoint:03, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264]
dev:53172022-09-29 11:36:49.586 pmdebugdescMap:[raw:D8D603E0010810D03000, dni:D8D6, endpoint:03, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264]
dev:53172022-09-29 11:36:49.535 pmdebugdescMap:[raw:D8D60300061C0000100001402100000240210000, dni:D8D6, endpoint:03, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]]]
dev:53172022-09-29 11:36:49.478 pmtraceskipped descMap:[raw:D8D602E0010810D03000, dni:D8D6, endpoint:02, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264]
dev:53172022-09-29 11:36:49.476 pmdebugdescMap:[raw:D8D602E0010810D03000, dni:D8D6, endpoint:02, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264]
dev:53172022-09-29 11:36:49.422 pmdebugdescMap:[raw:D8D60200061C0000100001402100000240210000, dni:D8D6, endpoint:02, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]]]
dev:53172022-09-29 11:36:49.362 pmtraceskipped descMap:[raw:D8D601E0011010D0300030D03001, dni:D8D6, endpoint:01, cluster:E001, size:10, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, additionalAttrs:[[value:01, encoding:30, attrId:D030, consumedBytes:4, attrInt:53296]]]
dev:53172022-09-29 11:36:49.360 pmdebugdescMap:[raw:D8D601E0011010D0300030D03001, dni:D8D6, endpoint:01, cluster:E001, size:10, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, additionalAttrs:[[value:01, encoding:30, attrId:D030, consumedBytes:4, attrInt:53296]]]
dev:53172022-09-29 11:36:49.307 pmdebugdescMap:[raw:D8D60100063C000010000140210000024021000001803001028030000050300100801000, dni:D8D6, endpoint:01, cluster:0006, size:3C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386], [value:01, encoding:30, attrId:8001, consumedBytes:4, attrInt:32769], [value:00, encoding:30, attrId:8002, consumedBytes:4, attrInt:32770], [value:01, encoding:30, attrId:5000, consumedBytes:4, attrInt:20480], [value:00, encoding:10, attrId:8000, consumedBytes:4, attrInt:32768]]]
dev:53172022-09-29 11:36:49.250 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 79 (method parse)
dev:53172022-09-29 11:36:49.196 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 79 (method parse)
dev:53172022-09-29 11:36:49.137 pmtraceskipped descMap:[raw:D8D601E0002003D0420C414141414167414142414141, dni:D8D6, endpoint:01, cluster:E000, size:20, attrId:D003, encoding:42, command:0A, value:AAAAAgAABAAA, clusterInt:57344, attrInt:53251]
dev:53172022-09-29 11:36:49.135 pmdebugdescMap:[raw:D8D601E0002003D0420C414141414167414142414141, dni:D8D6, endpoint:01, cluster:E000, size:20, attrId:D003, encoding:42, command:0A, value:AAAAAgAABAAA, clusterInt:57344, attrInt:53251]
dev:53172022-09-29 11:36:47.053 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 D8D6 00 00 0000 00 00 1682, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[16, 82]]
dev:53172022-09-29 11:36:47.050 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 D8D6 00 00 0000 00 00 1682, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[16, 82]]
dev:53172022-09-29 11:36:46.054 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 D8D6 00 00 0000 00 00 1300, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[13, 00]]
dev:53172022-09-29 11:36:46.051 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 D8D6 00 00 0000 00 00 1300, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[13, 00]]
dev:53172022-09-29 11:36:45.445 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 D8D6 00 00 0000 00 00 1300, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[13, 00]]
dev:53172022-09-29 11:36:45.442 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 D8D6 00 00 0000 00 00 1300, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[13, 00]]
dev:53172022-09-29 11:36:44.132 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 D8D6 00 00 0000 00 00 1400, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[14, 00]]
dev:53172022-09-29 11:36:44.129 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 D8D6 00 00 0000 00 00 1400, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[14, 00]]
dev:53172022-09-29 11:36:44.112 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 D8D6 00 00 0000 00 00 1500, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[15, 00]]
dev:53172022-09-29 11:36:44.108 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 D8D6 00 00 0000 00 00 1500, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[15, 00]]
dev:53172022-09-29 11:36:44.075 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 D8D6 00 00 0000 00 00 1400, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[14, 00]]
dev:53172022-09-29 11:36:44.072 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 D8D6 00 00 0000 00 00 1400, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[14, 00]]
dev:53172022-09-29 11:36:43.719 pminfochild device exists
dev:53172022-09-29 11:36:43.713 pminfochild device exists
dev:53172022-09-29 11:36:43.708 pminfochild device exists
dev:53172022-09-29 11:36:43.705 pminfochild device exists
dev:53172022-09-29 11:36:43.696 pmdebugdescMap:[raw:catchall: 0000 8005 00 00 0040 00 D8D6 00 00 0000 00 00 1100D6D804010203F2, profileId:0000, clusterId:8005, clusterInt:32773, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[11, 00, D6, D8, 04, 01, 02, 03, F2]]
dev:53172022-09-29 11:36:43.271 pmtracedescMap:[raw:catchall: 0000 0013 00 00 0040 00 D8D6 00 00 0000 00 00 00D6D88BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[00, D6, D8, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:36:43.264 pmdebugdescMap:[raw:catchall: 0000 0013 00 00 0040 00 D8D6 00 00 0000 00 00 00D6D88BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D8D6, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[00, D6, D8, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:36:43.237 pmwarnconfigure...
dev:53172022-09-29 11:36:01.476 pmdebugoff()
dev:53172022-09-29 11:36:00.315 pmerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: genericZigbeeMultiepSwitch.autoPoll() is applicable for argument types: () values: [] (method autoPoll)
dev:53172022-09-29 11:35:44.121 pmdebugoff()
dev:53172022-09-29 11:35:00.312 pmerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: genericZigbeeMultiepSwitch.autoPoll() is applicable for argument types: () values: [] (method autoPoll)
dev:53172022-09-29 11:34:00.545 pmerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: genericZigbeeMultiepSwitch.autoPoll() is applicable for argument types: () values: [] (method autoPoll)
dev:53172022-09-29 11:33:00.352 pmerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: genericZigbeeMultiepSwitch.autoPoll() is applicable for argument types: () values: [] (method autoPoll)
dev:53172022-09-29 11:32:18.225 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 D53F 00 00 0000 00 00 E982, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E9, 82]]
dev:53172022-09-29 11:32:18.222 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 D53F 00 00 0000 00 00 E982, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E9, 82]]
dev:53172022-09-29 11:32:15.861 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 D53F 00 00 0000 00 00 E800, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E8, 00]]
dev:53172022-09-29 11:32:15.857 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 D53F 00 00 0000 00 00 E800, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E8, 00]]
dev:53172022-09-29 11:32:15.682 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 D53F 00 00 0000 00 00 E600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E6, 00]]
dev:53172022-09-29 11:32:15.679 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 D53F 00 00 0000 00 00 E600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E6, 00]]
dev:53172022-09-29 11:32:14.914 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 D53F 00 00 0000 00 00 E700, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E7, 00]]
dev:53172022-09-29 11:32:14.910 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 D53F 00 00 0000 00 00 E700, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E7, 00]]
dev:53172022-09-29 11:32:14.748 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 D53F 00 00 0000 00 00 E600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E6, 00]]
dev:53172022-09-29 11:32:14.744 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 D53F 00 00 0000 00 00 E600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E6, 00]]
dev:53172022-09-29 11:32:14.434 pmtracedescMap:[raw:catchall: 0000 8021 00 00 0040 00 D53F 00 00 0000 00 00 E600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E6, 00]]
dev:53172022-09-29 11:32:14.430 pmdebugdescMap:[raw:catchall: 0000 8021 00 00 0040 00 D53F 00 00 0000 00 00 E600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E6, 00]]
dev:53172022-09-29 11:32:14.019 pminfochild device exists
dev:53172022-09-29 11:32:14.011 pminfochild device exists
dev:53172022-09-29 11:32:14.006 pminfochild device exists
dev:53172022-09-29 11:32:14.002 pminfochild device exists
dev:53172022-09-29 11:32:13.993 pmdebugdescMap:[raw:catchall: 0000 8005 00 00 0040 00 D53F 00 00 0000 00 00 E5003FD504010203F2, profileId:0000, clusterId:8005, clusterInt:32773, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E5, 00, 3F, D5, 04, 01, 02, 03, F2]]
dev:53172022-09-29 11:32:13.369 pmtracedescMap:[raw:catchall: 0000 0013 00 00 0040 00 D53F 00 00 0000 00 00 2C3FD58BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[2C, 3F, D5, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:32:13.365 pmdebugdescMap:[raw:catchall: 0000 0013 00 00 0040 00 D53F 00 00 0000 00 00 2C3FD58BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D53F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[2C, 3F, D5, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:32:13.294 pmwarnconfigure...
dev:53172022-09-29 11:32:02.935 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 79 (method parse)
dev:53172022-09-29 11:32:02.855 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 79 (method parse)
dev:53172022-09-29 11:32:01.345 pmtraceskipped descMap:[raw:025F03E0010810D03000, dni:025F, endpoint:03, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264]
dev:53172022-09-29 11:32:01.341 pmdebugdescMap:[raw:025F03E0010810D03000, dni:025F, endpoint:03, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264]
dev:53172022-09-29 11:32:01.245 pmdebugdescMap:[raw:025F0300061C0000100101402100000240210000, dni:025F, endpoint:03, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]]]
dev:53172022-09-29 11:32:01.126 pmtraceskipped descMap:[raw:025F02E0010810D03000, dni:025F, endpoint:02, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264]
dev:53172022-09-29 11:32:01.124 pmdebugdescMap:[raw:025F02E0010810D03000, dni:025F, endpoint:02, cluster:E001, size:08, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264]
dev:53172022-09-29 11:32:01.016 pmdebugdescMap:[raw:025F0200061C0000100101402100000240210000, dni:025F, endpoint:02, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]]]
dev:53172022-09-29 11:32:00.907 pmtraceskipped descMap:[raw:025F01E0011010D0300030D03001, dni:025F, endpoint:01, cluster:E001, size:10, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, additionalAttrs:[[value:01, encoding:30, attrId:D030, consumedBytes:4, attrInt:53296]]]
dev:53172022-09-29 11:32:00.904 pmdebugdescMap:[raw:025F01E0011010D0300030D03001, dni:025F, endpoint:01, cluster:E001, size:10, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, additionalAttrs:[[value:01, encoding:30, attrId:D030, consumedBytes:4, attrInt:53296]]]
dev:53172022-09-29 11:32:00.623 pmdebugdescMap:[raw:025F0100063C000010010140210000024021000001803001028030000050300100801000, dni:025F, endpoint:01, cluster:0006, size:3C, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386], [value:01, encoding:30, attrId:8001, consumedBytes:4, attrInt:32769], [value:00, encoding:30, attrId:8002, consumedBytes:4, attrInt:32770], [value:01, encoding:30, attrId:5000, consumedBytes:4, attrInt:20480], [value:00, encoding:10, attrId:8000, consumedBytes:4, attrInt:32768]]]
dev:53172022-09-29 11:32:00.514 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 79 (method parse)
dev:53172022-09-29 11:32:00.424 pmerrorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 79 (method parse)
dev:53172022-09-29 11:32:00.305 pmtraceskipped descMap:[raw:025F01E0002003D0420C414141414167414142414141, dni:025F, endpoint:01, cluster:E000, size:20, attrId:D003, encoding:42, command:0A, value:AAAAAgAABAAA, clusterInt:57344, attrInt:53251]
dev:53172022-09-29 11:32:00.300 pmerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: genericZigbeeMultiepSwitch.autoPoll() is applicable for argument types: () values: [] (method autoPoll)
dev:53172022-09-29 11:32:00.295 pmdebugdescMap:[raw:025F01E0002003D0420C414141414167414142414141, dni:025F, endpoint:01, cluster:E000, size:20, attrId:D003, encoding:42, command:0A, value:AAAAAgAABAAA, clusterInt:57344, attrInt:53251]
dev:53172022-09-29 11:31:55.121 pmtracedescMap:[raw:catchall: 0000 8001 00 00 0040 00 025F 00 00 0000 00 00 83008BCBDE108038C1A45F02, profileId:0000, clusterId:8001, clusterInt:32769, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:025F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[83, 00, 8B, CB, DE, 10, 80, 38, C1, A4, 5F, 02]]
dev:53172022-09-29 11:31:55.116 pmdebugdescMap:[raw:catchall: 0000 8001 00 00 0040 00 025F 00 00 0000 00 00 83008BCBDE108038C1A45F02, profileId:0000, clusterId:8001, clusterInt:32769, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:025F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[83, 00, 8B, CB, DE, 10, 80, 38, C1, A4, 5F, 02]]
dev:53172022-09-29 11:31:53.614 pmtracedescMap:[raw:catchall: 0000 0013 00 00 0040 00 025F 00 00 0000 00 00 245F028BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:025F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[24, 5F, 02, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:31:53.610 pmdebugdescMap:[raw:catchall: 0000 0013 00 00 0040 00 025F 00 00 0000 00 00 245F028BCBDE108038C1A48E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:025F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[24, 5F, 02, 8B, CB, DE, 10, 80, 38, C1, A4, 8E]]
dev:53172022-09-29 11:31:50.481 pmwarndescription logging is: true
dev:53172022-09-29 11:31:50.480 pmwarndebug logging is: true
dev:53172022-09-29 11:31:50.479 pminfoupdated...
dev:53172022-09-29 11:31:46.505 pmwarndescription logging is: true
dev:53172022-09-29 11:31:46.502 pmwarndebug logging is: false
dev:53172022-09-29 11:31:46.501 pminfoupdated...
dev:53172022-09-29 11:31:28.816 pminfochild device exists
dev:53172022-09-29 11:31:28.813 pminfochild device exists
dev:53172022-09-29 11:31:28.809 pminfochild device exists
dev:53172022-09-29 11:31:28.805 pminfochild device exists
dev:53172022-09-29 11:31:28.315 pmwarnconfigure...
dev:53172022-09-29 11:31:00.383 pmerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: genericZigbeeMultiepSwitch.autoPoll() is applicable for argument types: () values: [] (method autoPoll)
dev:53172022-09-29 11:30:49.262 pminfocreate child device, endpoint F2
dev:53172022-09-29 11:30:49.180 pminfocreate child device, endpoint 03
dev:53172022-09-29 11:30:49.096 pminfocreate child device, endpoint 02
dev:53172022-09-29 11:30:48.825 pminfocreate child device, endpoint 01
dev:53172022-09-29 11:30:47.841 pmwarnconfigure...
dev:53172022-09-29 11:30:39.373 pmerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: genericZigbeeMultiepSwitch.isRefreshRequestClear() is applicable for argument types: () values: [] (method isRefreshRequestClear)
dev:53172022-09-29 11:30:35.938 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:30:35.843 pminfoTuya Zigbee Metering Plug configure()..
dev:53172022-09-29 11:30:11.083 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:30:11.017 pminfoTuya Zigbee Metering Plug configure()..
dev:53172022-09-29 11:29:58.021 pminfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug was turned on [physical]
dev:53172022-09-29 11:29:55.128 pminfoTuya Zigbee Metering Plug Child Lock is off
dev:53172022-09-29 11:29:55.126 pminfoTuya Zigbee Metering Plug Power On State is off
dev:53172022-09-29 11:29:55.124 pminfoTuya Zigbee Metering Plug LED mode is Lit when On
dev:53172022-09-29 11:29:50.445 pminfoTuya Zigbee Metering Plug Child Lock is off
dev:53172022-09-29 11:29:50.443 pminfoTuya Zigbee Metering Plug Power On State is off
dev:53172022-09-29 11:29:50.441 pminfoTuya Zigbee Metering Plug LED mode is Lit when On
dev:53172022-09-29 11:28:44.618 pminfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug was turned off [physical]
dev:53172022-09-29 11:28:34.316 pminfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug was turned on [physical]
dev:53172022-09-29 11:28:33.672 pminfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug switch is off
dev:53172022-09-29 11:28:33.171 pminfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug switch is on
dev:53172022-09-29 11:28:32.189 pminfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug switch is off
dev:53172022-09-29 11:28:25.177 pminfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug switch is on
dev:53172022-09-29 11:28:23.818 pminfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug switch is off
dev:53172022-09-29 11:28:17.695 pminfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug was turned on [physical]
dev:53172022-09-29 11:28:15.030 pminfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug was turned off [physical]
dev:53172022-09-29 11:26:55.237 pminfoTuya Zigbee Metering Plug Child Lock is off
dev:53172022-09-29 11:26:55.235 pminfoTuya Zigbee Metering Plug Power On State is off
dev:53172022-09-29 11:26:55.233 pminfoTuya Zigbee Metering Plug LED mode is Lit when On
dev:53172022-09-29 11:26:49.674 pminfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug switch is on
dev:53172022-09-29 11:26:49.198 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:26:49.129 pminfoTuya Zigbee Metering Plug configure()..
dev:53172022-09-29 11:21:02.866 pminfoTuya Zigbee Metering Plug Child Lock is off
dev:53172022-09-29 11:21:02.862 pminfoTuya Zigbee Metering Plug Power On State is off
dev:53172022-09-29 11:21:02.852 pminfoTuya Zigbee Metering Plug LED mode is Lit when On
dev:53172022-09-29 11:20:56.228 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:20:56.189 pminfoTuya Zigbee Metering Plug configure()..
dev:53172022-09-29 11:20:41.155 pminfoTuya Zigbee Metering Plug Child Lock is off
dev:53172022-09-29 11:20:41.153 pminfoTuya Zigbee Metering Plug Power On State is off
dev:53172022-09-29 11:20:41.151 pminfoTuya Zigbee Metering Plug LED mode is Lit when On
dev:53172022-09-29 11:20:35.202 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:20:35.162 pminfoTuya Zigbee Metering Plug configure()..
dev:53172022-09-29 11:20:19.595 pminfoTuya Zigbee Metering Plug Child Lock is off
dev:53172022-09-29 11:20:19.593 pminfoTuya Zigbee Metering Plug Power On State is off
dev:53172022-09-29 11:20:19.591 pminfoTuya Zigbee Metering Plug LED mode is Lit when On
dev:53172022-09-29 11:20:14.220 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:20:14.164 pminfoTuya Zigbee Metering Plug configure()..
dev:53172022-09-29 11:19:58.551 pminfoTuya Zigbee Metering Plug Child Lock is off
dev:53172022-09-29 11:19:58.550 pminfoTuya Zigbee Metering Plug Power On State is off
dev:53172022-09-29 11:19:58.548 pminfoTuya Zigbee Metering Plug LED mode is Lit when On
dev:53172022-09-29 11:19:53.200 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:19:53.161 pminfoTuya Zigbee Metering Plug configure()..
dev:53172022-09-29 11:19:38.390 pminfoTuya Zigbee Metering Plug Child Lock is off
dev:53172022-09-29 11:19:38.388 pminfoTuya Zigbee Metering Plug Power On State is off
dev:53172022-09-29 11:19:38.386 pminfoTuya Zigbee Metering Plug LED mode is Lit when On
dev:53172022-09-29 11:19:32.581 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:19:32.542 pminfoTuya Zigbee Metering Plug configure()..
dev:53172022-09-29 11:19:19.374 pminfoTuya Zigbee Metering Plug Child Lock is off
dev:53172022-09-29 11:19:19.372 pminfoTuya Zigbee Metering Plug Power On State is off
dev:53172022-09-29 11:19:19.370 pminfoTuya Zigbee Metering Plug LED mode is Lit when On
dev:53172022-09-29 11:19:13.064 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:19:13.010 pminfoTuya Zigbee Metering Plug configure()..
dev:53172022-09-29 11:18:53.232 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:18:53.190 pminfoTuya Zigbee Metering Plug configure()..
dev:53172022-09-29 11:18:17.476 pminfoTuya Zigbee Metering Plug Child Lock is off
dev:53172022-09-29 11:18:17.474 pminfoTuya Zigbee Metering Plug Power On State is off
dev:53172022-09-29 11:18:17.472 pminfoTuya Zigbee Metering Plug LED mode is Lit when On
dev:53172022-09-29 11:18:11.211 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:18:11.170 pminfoTuya Zigbee Metering Plug configure()..
dev:53172022-09-29 11:18:07.116 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:18:07.074 pminfoTuya Zigbee Metering Plug configure()..
dev:53172022-09-29 11:18:07.072 pminfoTuya Zigbee Metering Plug configuring the switch and energy reporting..
dev:53172022-09-29 11:18:07.070 pminfoTuya Zigbee Metering Plug Auto polling is enabled, polling interval is 1 minutes
dev:53172022-09-29 11:18:07.036 pminfoTuya Zigbee Metering Plug Debug logging is false Description text logging is true
dev:53172022-09-29 11:18:07.034 pminfoTuya Zigbee Metering Plug Updating null (Tuya Zigbee Metering Plug) model TS0003 presence: present AlwaysOn is false
dev:53172022-09-29 11:17:58.126 pminfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug switch is off
dev:53172022-09-29 11:17:57.992 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:17:57.113 pminfoTuya Zigbee Metering Plug Energy (total:0.0 kWh) was reset on 2022-09-29 23:17:56.972
dev:53172022-09-29 11:17:57.056 pminfoTuya Zigbee Metering Plug hourlyEnergy is 0 kWh
dev:53172022-09-29 11:17:57.055 pminfoTuya Zigbee Metering Plug energy is 0.0 kWh, energyCost=$0.0 (rate=$0.12), duration=0 Mins
dev:53172022-09-29 11:17:56.355 pminfoTuya Zigbee Metering Plug Child Lock is off
dev:53172022-09-29 11:17:56.353 pminfoTuya Zigbee Metering Plug Power On State is off
dev:53172022-09-29 11:17:56.351 pminfoTuya Zigbee Metering Plug LED mode is Lit when On
dev:53172022-09-29 11:17:55.846 pmwarnstate.lastResetEnergy = null, resetting it back to 0!
dev:53172022-09-29 11:17:55.802 pmwarnTuya Zigbee Metering Plug Initialize()...
dev:53172022-09-29 11:17:51.198 pminfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug switch is off
dev:53172022-09-29 11:17:50.844 pminfoTuya Zigbee Metering Plug refresh()...
dev:53172022-09-29 11:17:50.813 pminfoTuya Zigbee Metering Plug configure()..
dev:53172022-09-29 11:17:50.691 pmwarnstate.lastResetEnergy = null, resetting it back to 0!
dev:53172022-09-29 11:17:50.689 pminfoTuya Zigbee Metering Plug Installed()...
You are using a custom driver. That is a question for the driver author, but he is no longer around on this forum (if you're using the one I think you might be, based on only the name that I can see). There may be other drivers that work differently.
I am not familiar with this exact model to know what other options there may be. @kkossev is familiar with lots of Tuya devices and might know if he is nice enough to share; others may as well.
I think you're right.
He's the best expert.
When the particular device fingerprint does not match any of the installed custom drivers fingerprints, then it is assigned the best match from the HE inbuilt drivers or ‘device’ driver if none found.
In this case, the fake F2 switch may be created by the inbuilt ‘Zigbee Multi Endpoint Switch’ driver. As it is a generic driver, aimed to cover as much as possible different manufacturers devices, the inbuilt driver does not have manufacturer specific clusters filtering .
F2 is Tuya specific ‘green power’ cluster.
For both devices, please share the model and the manufacturer values from the device’Data’ section.
ata * endpointId: 01
  • application: 50
  • driver: v1.0.1.1123b
  • hasMultiEP: true
  • isMultiEP: true
  • manufacturer: _TZ3000_udtmrasg
  • model: TS0003
  • application: 5A
  • hasMultiEP: true
  • inClusters: 0000,0004,0003,0006,0005,0002,000A,FCC0,0B04
  • manufacturer: LUMI
  • model: lumi.switch.n3acn3
  • outClusters: 0019,000A,FCC0
  • softwareBuild:
Can you also check what driver is being used when paired like @kkossev pointed out. This could help him diagnose the problem.
Actually, I don't think there is any problem. Even in Markus's 'Zigbee Generic Switch (with presence)' there is an option and a warning:
So Markus's driver will probably also create a 'fake' child device, except there was a dedicated code inside "... if this is a Tuya device, do not create child devices for endpoint F2 "
