I added an older but supported ge switch to habitat and it works fine in the habitat but has no response in HomeKit. I m running the new architecture of HomeKit. Any help would be appreciated.
Is it Non plus? If so then it won't report.... You would have to install the poller app in HE then it "should" pass that to HK... Another option would to do a virtual switch with mirroring
Thank you for the reply, The switch is an older non-plus switch. I installed the poller app and included this switch and it's still the same. I looked for instruction on how to do a visual switch with monitoring and Had no success fining a tutorial. Could you point me in the right direction. Thanks agian
I actually watched that earlier today and had some “aha moments”.
Quite informative
This topic was automatically closed 360 days after the last reply. New replies are no longer allowed.
