Why can't I simply set the Thermostat to "off"?
I would like to create a rule that turns the Thermostat to "Off" when the mode changes to "Away". I get into the logic and get stuck on the screen:
which will not let me exit after selecting "Off" in the Select thermostat mode dropdown (which doesn't acknowledge the "Off" transition. It seems that I can move on to the next screen to complete the If/Then only if I set a heating point as noted above.
What am I missing here?
Not sure, I can do that with all my thermostats. I have 4, three are using a virtual thermostat app, VThermostat and the 4th is an Ecobee. using the Ecobee suite manager from sandood,
What thermostat and driver are you using?
It looks like you are trying to edit a broken action. Is that the case?
It may mean the rule has got corrupted.
If this is all you have in the rule then maybe try deleting and starting again.
Thermostat driver is the Generic Z-Wave Plus Thermostat driver. Regarding the broken rule, I think that came about when I couldn't set the thermostat to "Off" and then tried setting the temp to "70" which was accepted and allowed me to continue the If/Then. I then tried to back up and apparently broke the rule. Deleted rule and tried again but still got hung up when trying to select "Off" in the "Select Thermostat mode" dropdown. Nothing apparent to select that allowed me to move on to complete the rule. Very strange.
Hitting the back button, assuming this is what you mean, is never a good idea in RM.
Hhmm. Not sure why you cannot select 'off' and then move on.
Could try custom action and find it in there?
I'm not seeing this problem. Here is the setting of the Thermostat Mode:
and the result:
Screen Shot 2022-02-13 at 3.08.37 PM
