Yes, correct company. I can send message when the zigbee modules become available and a link to the pricing.
Do you have a rough estimate of the ETA on those?
Those screws have triggered my OCD...
Sorry, no idea at all. That will be a business decision.
Does anyone know the starting point for writing drivers? I feel like the documentation is like reading a dictionary. It is meant for reference for someone who already knows what they are doing. There isn't even a good definition of what a driver is. I can see the list of capabilities but there is no description of what exactly a capability is or descriptions of the individual capabilities. I have created a driver for just turning an outlet on and off but I just did that from copying existing drivers. Also the zigbee commands are not defined anywhere in the documentation. Tokens like "he" or "rattr" are not described in the docs anywhere. I assume "he" is "hub transmit", "rattr" is zcl read attribute etc but I don't want to be reverse engineering the sample code to figure out what the commands are.
For official answers, @mike.maxwell would be the one to talk to.
For community answers, I would post questions in a new topic in the developers section.
I have a couple swidgets (from the original Kickstarter) and more on order (but on hold while they work out Z-Wave details supposedly) for a very long time. Happy to help them with stuff also as they were very responsive to some questions (and letting me know about the initial delay). The price is pretty high, part of the problem with them being modular in a setting where users will almost never change them.
I have done a lot of re-writing of the Z-Wave outlet driver for mine... but stopped doing much until the newer ones arrive. Plus I got busy with my other drivers at the time.
Anyways, to the OP, I have the GE/Jasco Z-Wave Motion dimmers and switches are one of the main reasons I have Z-Wave around in general. There are just more of them and they work well (since Z-Wave Plus at least, I still have some WD500Zs from when Z-Wave did not automatically tell you someone manually turned on a switch). But have yet to spot a ZigBee equivalent.
I have noticed there are more z-wave options when it comes to switches, but I'm committed to ZigBee now and I don't want to mix the two.
UPDATE
I ended up ordering motion sensor pucks. I'll just have deal with batteries once in a while.
Thanks all for your input.
Inovelli released their latest roadmap for 2021 and 2022 and they have a ZigBee motion sensor switch on there...
Cool!
I don't see it on their website thought. Do you remember when it's coming out?
Their Roadmap says Q2 2022...
Looking forward to the zigbee switch would make a great bathroom switch.
I think I'm screwed on Hubitat support and will have to somehow go back and change my software. The trouble is is that Hubitat supports zigbee (and Z-wave) as if it is WiFi, that is on WiFi. WiFi has no standardized app layer and no standardized discovery of capabilities. For example all zigbee dimmable lights work the same way. A hub like Alexa discovers a dimmable light and knows that it will support a certain set of commands and behave a specific way to those commands. Hubitat requires a fingerprint to recognize a specific device. I then declare a set of Hubitat capabilities - a contract stating that my driver will support a set of commands for my light.
Here is where I'm screwed, my single radio module comes has different capabilities depending on what it is plug into and what sensors it has. Currently there are 48 different sets of capabilities but this number will increase. Alexa, while not supporting everything my device can do, will discover most of the capabilities and just work. Hubitat will require 48 different drivers but I can't use the fingerprint because the way Hubitat calculates the fingerprint all of my devices will have identical finger prints.
I'm going to need to write a completely generic zigbee driver that dynamically can add or remove capabilities based on the endpoint discovery results. Of coarse if I'm able to do that then it will work for all zigbee devices, not just swidget ones.
You can't dynamically add and remove capabilities. However you can dynamically add and remove child devices. So you could make a parent driver that creates the needed children devices based on which module is used/specified.
In fact that is how I would strongly recommend doing the driver for a device like this.
Do you have an example of that somewhere? Ideally I would remove or add child devices based on the endpoints present.
So here is an example of the code to add different children I threw together. In this example you would need drivers "MotionChild.groovy" and "DimmerChild.groovy" for it to work properly. With the new bundles that 2.2.8 allows (or HPM) this is a bit easier to deal with than loading them individually. It is something I am thinking about doing for some of my areas due to the lack of dynamic capabilities (once 2.2.8 is more readily in use so I do not make life a total hassle for people that have not upgraded yet):
def addChild( String DNI, String ChildType ){
try{
Logging( "Adding Child ${ DNI } of Type ${ ChildType }", 3 )
switch( ChildType ){
case "MotionChild":
addChildDevice( "MotionChild", DNI, [ name: "${ DNI }" ] )
break
case "DimmerChild":
addChildDevice( "DimmerChild", DNI, [ name: "${ DNI }" ] )
break
default:
Logging( "${ ChildType } is unknown, correct the code.", 5 )
break
catch( Exception e ){
def Temp = e as String
if( Temp.contains( "not found" ) ){
Logging( "Child driver of ${ ChildType } is not loaded, this is required.", 5 )
} else {
Logging( "addChild Error, likely child already exists: ${ Temp }", 5 )
OK this helps. What calls addChild()? Where does the DNI come from and String ChildType?
In my drivers I call AddChild when I want to send an Event or State to the child device, but it determines that child does not exist yet. That is when I would send the ChildType string also. Mind you, I do not actually HAVE this implemented in any of my real drivers at this time. The ChildType needs to be passed through from wherever in your code you actually know what it should be. In the below example, my PostStateToChild does not have any way of "knowing" directly, it is just meant for posting data through to the child device.
But typically when I am calling PostStateToChild (or the similar PostEventToChild for events) I would know when they are being called what it would be for. As an example, if I implement this with my UnifiProtectAPI driver, I could eliminate the more generic UnifiChild driver and make ones more specific to each type of child device. Such as the cameras, lighting, NVR, etc... Then I would not have to worry about the fact that everything thinks it can on/off or everything has dimming functions when they only apply to lights or such.
Combined with the bundle feature AND the library feature (so a lot of the duplicate code between the various child drivers could be just put in the library) this could really make my life easier while making my drivers more specifically targeted and functional. Just need to do it.
I am sure that before, if you told a user "here is the parent driver... and you also need to install these (up to) eight child drivers individually... and update them individually..." a lot of people would give up right there. HPM made that easier, but now I think Hubitat itself is making it a lot more doable.
EDIT: Forgot to mention about the DNI. In this case it is passed as "Child" from the PostState... Usually, in drivers where I know there are going to multiple of the same general thing, I send the child name as something identifying the type but with something unique also.
Example call:
PostStateToChild( "Camera ${ UniqueCameraID }", "Camera", "Is Recording", "yes" )
Example:
// Post data to child device
def PostStateToChild( Child, ChildType, Variable, Value ){
if( "${ Child }" != null ){
if( getChildDevice( "${ Child }" ) == null ){
addChild( "${ Child }", "${ ChildType }" )
if( getChildDevice( "${ Child }" ) != null ){
Logging( "${ Child } State: ${ Variable } = ${ Value }", 4 )
getChildDevice( "${ Child }" ).ProcessState( "${ Variable }", Value )
} else {
Logging( "Failure to add ${ ChildParent } and post ${ Variable }=${ Value }", 5 )
} else {
Logging( "Failure to add child because child name was null", 5 )
So in my case depending on what my insert (radio module) is plugged into I will have different endpoints. I see in the example Hubitat/useelink-sm-so301-uz-zigbee-power-strip.groovy at master ยท RMoRobert/Hubitat ยท GitHub that the children are dynamically created but from a static list.
@Field static Map <String, String> childEndpoints = ['01': 'Outlet 1', '02': 'Outlet 2', '03': 'Outlet 3',
'04': 'Outlet 4', '07': 'USB Ports']
Can the capabilities be dynamically added and removed?
If my insert is put into a dimmable device then I want the capabilities to include changing level . If the insert is in an outlet I only want the ability to implement commands from a switch (the switch capability)
You can add the children however, that example used a map, mine did not.
Unfortunately, capabilities cannot be dynamic. That is the whole cause of having multiple child drivers. Each driver is "locked in" for what capabilities and attributes it has.
You would need one for the outlet (that excluded the level) and one for the dimmer that included it. Of course if all the other code was common, you could call the outlet driver as a library in the dimmer one to minimize the code you would duplicate.
