@bravenel I was wondering if hitting the pause button on a motion lighting rule will cause all actions to be paused, or just the motion-based ones? In other words, if I had the automation configured to use a button controller to also turn on/off the lights (in addition to a trigger based on motion sensors), does pausing the automation prevent that button controller from functioning as intended?
I think that it's anything that would turn the lights on or off. Easy enough to test.
Fair enough, I'm away from home for a bit so will test when I get back to be sure. Thanks.
