Which driver type to use with Phillips Hue solo Lightstrip
I added my first string of Phillips Hue solo lightstrips to hubitat - it paired quickly but did not have a "type" driver. I set it to Advanced Zigbee RGBW bulb and that works OK.
Is there a better driver to use ?
I'm surprised it did not get added into hubitat with that driver like other zigbee devices do...
That or Generic Zigbee RGBW Bulb should both work for that one. Be sure to run "Configure" after you switch drivers.
If you wanted to temporarily switch back to the "Device" driver, run the "Get Info" commands, and copy the fingerprint from Logs here, that could be added to one of the drivers above so that does happen in the future. :slight_smile:
