I just switched from ST to HE and am curious, before I work to start porting from ST, do any integrations exist for:
Kevo Plus [fought with the ST DTH a bit, but finally WORKING!]
Ring (doorbell plus floodlights)
AlarmDecoder [WORKING!]
DLNA speakers [WORKING!]
MyQ [A lot of fighting but now WORKING!]
I'm trying to fully migrate over and want to know what I may need to port myself vs what already exists.
For Ring Doorbell, many of us use Amazon Alexa as a bridge between the two systems. Use the Ring and Hubitat Skills for Alexa. Then use Ring as a trigger for an Alexa Routine. Have the Alexa Routine turn on a virtual switch/motion device using a driver like the following.
Hello, newbie here. I thought a virtual device (switch, motion ect) could be actuated by Alexa without any added code, as long as it is exposed in the hubitat Alexa app. Not true?
Enlighten us o obiwon.
An Alexa Routine can activate a standard virtual switch. However, it cannot change the state of a virtual motion sensor. I wanted my Ring Doorbell to show up as a Hubitat motion sensor. So, a custom driver that implements both the Switch and Motion Capabilities was a simple solution. It also automatically turns it self back off after a few seconds so it is ready for the next Ring Motion event.
@helene7t7 Do you actually have the myQ Lite app working? I have a Craftsman opener that works fine in ST. I am using the exact same username and password yet I get: The username or password you entered is incorrect. Try again.
ok so my first suggestion would be to open the myq app and sign out. Then try to sign in. MyQ shut down one of its apps and switched to a new one. I had to reset my password to sign in to the new app.
