When motion detected, activate different scene based on lux intensity
Hi All,
I'd like to turn on a specific scene based on the lux intensity; is it possible with motion lighting built-in app? OR should I go down to the RM path?
What I'm after is something like this:
  • If motion is detected and lux is less than 20, run scene 'bright'
  • else, if motion detected and lux is between 20-40, run scene 'semi bright'
  • else if motion detected and lux is more than 40, run scene 'dark'
What I have found so far, I can only select scene based on mode & lux to turn on/off the switch; unless if I missed it:
You're going to need to do something like this in Rule Machine, not Motion Lighting.
