What's The Proper (Best) Way To Exclude Long Range Z-Wave Devices?
I think I managed to exclude a ZEN04 plug just now, but I was not to confident about it.
I am using @jtp10181 's smart start manager app.
My sequence, likely wrong, was to first exclude the device.
The message said: "unknown device excluded".
Then I deleted it from the ss mgr app.
Still in the device list.
I then did a force remove.
No ghost, apparently.
What's the right way to do this?
Thanks.
You need to remove or disable in SS first, otherwise it will just re-include itself right after you exclude it, which is possibly what happened in your case.
Not sure it sometimes says unknown device, another bug in z-wave since they added LR support.
Best thing to do would be to run the exclusion and then reboot the hub, then check the z-wave details again. This will clear up any leftover LR nodes that get stuck in the list sometimes (cache maybe?).
