What type of LED bulb is this? What switch(es) will work?
I just moved into a new house and tried to install a Zooz Zen 26 switch in a three-way configuration on the stairway. After powering up, I got a pretty bright flicker when it was supposed to be off. I would estimate 30%. So, I did what I should have done first and removed the translucent bulb cover to discover this:
I have never seen this type and Google Image Search didn't help much other than to say that it's an LED bulb. Any suggestions on a switch that might work with that type of bulb w/out a flicker? I am assuming it is a bulb issue and not a wiring issue with my skills as an electrician.
Additionally and unfortunately, I discovered after it was too late that all of the other bulbs are the two-prong variety so all of my Zigbee bulbs are useless. UGH!!! Is that grounds to sue for a failure to disclose??? :grin:
Almost as if there’s a small current leak. Perhaps you need something like the Lutron MLC to be wired in series parallel (thanks @Sakman) with the bulb.
Is the Zen26 connected to a neutral?
Yes.
My only other brand of switches are GE and I think they require another GE switch in 3-way configurations.
In parallel with the bulb?....https://assets.lutron.com/a/documents/041294_lut-mlc.pdf
I have several of these in my house and Lutron's dimmers work fine with them. If you preferred Z-wave, I would look at Leviton as they are most likely to work too.
I have various similar modules throughout our house, mostly running Zen77 dimmer (both one-pole and 3-way).
The only one that I can think of on a switch is controlled via Zen52.
It might be worth reaching out to Zooz - they are aware of some LEDs not behaving:
https://www.support.getzooz.com/kb/article/312-my-bulbs-glow-when-my-zen26-or-zen27-switch-is-turned-off/
Download the Hubitat app
