Does anyone know what's wrong here?
It means that you have multiple instances of the same rule being executed at the same time. This happens when there are triggers configured that could happen simultaneously. While it is not necessarily causing an issue, it is advised to make "simple" rules or debounce rules, especially when you are dealing with delays. You can debounce rules by using the private boolean. Here is an example of debouncing with a variable which is the same as using the private boolean:
Can I just do the following?
If Private BOolen is False Exit Rule
After THEN
Private Boolean False
ELse
Private Boolean True
Cancel Delayed Actions
Almost, you also need to set the private boolean to true after the delay is over (e.g. right before open() on Echo - Xbox) to reset the PB when the rule finished
You mean Private Boolean after the Echo Xbox Close?
Yes
You want to move the
IF (Private Boolean is false) Then
Exit Rule
End-if
all the way to the top of the rule. It should be the first thing to test so you don't have simultaneous rules calling Cancel Delayed Actions
This doesn't look right.
Because it would exit and never cancel the delayed actions if the motion sensors become active again.
You are correct. Sorry about that. Move it back to where you had it and then add another one with the inverted condition in the else part
IF (Not Mode Pause) Then
IF (Any Motion inactive) Then
If (Private Boolean is false) Then
Exit Rule)
End if
Set Private Boolean False
Delay
Off
Open
close -> delay 5
Set Private Boolean True
Else
If (Private Boolean is True) Then
Exit Rule
End If
Cancel Delay Actions
End if
End if
Looks good to my eyes
Okay this makes sense. The private booleans are there to not re-run the rule basically.
One motion sensor is active and another one becomes active it won't re-run the whole rule. And vice versa.
Is that correct?
That is correct
Awesome.
Thanks for the help. I have to update another rule I have just like this one.
I have anothe rule.
WOuld this work
Trigger:
All motion sensors Inactive
Actions:
If all motion inactive AND iphones all not preset and OccupancyAway is off THEN
Delay 45 (Canceable)
On: OccupanyAway
Private Boolean on
ELSE-IF Motion Sensors any active AND OccupancyAway is on THEN
Off: OccupancyAway
ELSE-IF Private Boolean is False THEN
END-IF
No, there are some logic breaks in your design and you will still have way to many instances running of that rule due to all the motion sensors used as triggers. The Else-if construct you have is getting you into trouble
How about something like this:
Trigger: Motion sensor **changes**
Action:
IF all motion inactive and iphones not present and Occupancy Away is off Then
If (Private Boolean = False)
Exit Rule
End If
Delay 45 (cancable)
On: OccupancyAway
Set Private Boolen True
Else-if (occupancy away is on)
If (Private Boolean is true) then
Exit Rule
End if
Off: Occupancy Away
End If
Problem is nothing will cancel the delay if it doesn’t match the switch being on.
Than make the else-if just an Else without condition
