If I want the lights to turn off after no motion activity for 2 minutes (both motions must not show activity), what is the difference between these two fields? Currently, with them both populated, lights are turning off a strange intervals when the motions should definitely be active.
The top circle is fairly straightforward. Motion inactive and stays for two minutes will turn off the Room Lighting instance. The lower circle starts a timer from the last activation event. Room Lighting will turn off in two minutes unless another activation event occurs to reset this timer.
