Any difference between 'Soft Reset' and using 'Reboot' (on Details page)?
There is a big difference. Hub Reboot restarts the platform while Soft Reset removes the database that contains drivers, settings, rules, custom code, etc - allowing you to restore a backup. Soft Reset doesn't remove devices from your radios, so unless a backup is restored, devices remain connected to the hub without a driver (becoming standed devices).
So if something really goes wacky and a regular reboot and/or shutdown doesn't fix it, Then use a soft reset followed by a Restore operation.
That is correct.
Great, thanks. Are user apps, device codes, and File Manager files also part of the backup?
Yes... But if you were to do a full reset you would lose both your zigbee and z-wave radios... You would then have to manually pair everything back...Hopefully you will never have to do that and only on the instructions of support.
Not to my knowledge. Files uploaded to the hub via File Manager have to be backed up manually.
Really? Could have sworn the few files I have were backed up and restored...Dammit now I have to look
Yes
What he said ![]()
Learned something new today
This topic has been marked solved by the community and subsequently closed.
