I had a ghost device called "generic zwave lock", so I got rid of it (with the built in remove command). (last week).
I checked and the device was removed from my list of devices. (I cleared the cache, and reloaded my list of devices, many times since I got rid of that device.)
However, it still shows up under Settings-> Zwave Details.
Why is there a difference between the list of devices and the zwave details?
First of all, thank you for the reply.
I have gone into the list of devices, and hit the "remove" button, which has now made the two lists consistent.
May I suggest that there should be a consistent list that is presented to users?
That is, if a zwave device is removed (via the builtin remove button), then it should automatically be removed from the list of devices?
May I recommend this small enhancement?
(I'm not sure, but I believe that was the approach in the past, and I think it has changed.)
This topic has been marked solved by the community and subsequently closed. If the issue persists, or for further discussion on this topic, feel free to create a new thread under a different category to continue the conversation.
If you are logged in, click [HERE] to get started.
